Question about Mitsubishi WD-73927 73" HDTV
DLP TV - After warm up - colors smear
Greetings,
I have a Mitsubishi 73" DLP TV, model WD73927, This problem has taken a while to manifest itself, about two months.
Initially I thought that Comcast with additional channels were degrading their signal as they had added channels and thought nothing of it. However, in the past couple of weeks the issue has gotten significantly worse.
First there was a solarization effect on blues, then on white or light colored scenes, and eventually people's faces are going to pink solarization with an occasional light flash of the entire picture, while detail is maintained in complicated portions of the image.
From a cold start (off for several hours or overnight) the picture looks fine for the first half hour (sooner on warm days), and the visual artifacts start to appear two hours later the effect is full blown. Turning off the TV for a minute and turning it back on, only reverses about 15 minutes worth of effects.
Based on the aforementioned symptoms, I suspected that it was an overheating problem, so I took the TV apart and cleaned it (there was a lot of dust except on the optic route which appeared clean), put it back together. I also ensured that the fans do operate when it is operating as there is a stream of warm air coming out of the unit, and the one that I can see from the back is operating. This only delayed the effect by a few minutes.
From what I have read, this has something to do with the color wheel.
Can anyone confirm that this is the issue, just to replace it? If so, what is the part number for it? If not, then what else could it be? I don't want to spend another fortune repairing it due to
Can anyone point me in the correct direction on a repair, as I have recently lost my job, but have no problems doing just about any kind of repair from notebook computers to 100+T cranes and anything and everything in between. It's just need the knowlege required to repair it.
Thanks in advance for your help.
Best Regards,
Jan
  • Anonymous May 24, 2009
    same problem Blues and whites are very affected
Did you ever figure the problem out? My TV is doing the same thing.
Posted on Sep 23, 2010
How do I fix white dots on my Mitsubishi DLP TV?
Hello. Please call Mitsubishi! Some models the DLP chip is covered under warranty, and all you have to do is pay labor costs, our shop charges $200.
May 11, 2016 | Mitsubishi WD-73827 73" HDTV DLP TV
After replacing bulb on WD-82738 still not working
How to replace the lamp in your Mitsubishi TV - YouTube
? 3:13
https://www.youtube.com/watch?v=_ONPuB5L-x4
Nov 1, 2012 - Uploaded by Mitsubishi3D
Your Mitsubishi television is powered in part by a 180 watt lampthat illuminates your TV's vivid colors. ... The first time they delivered my TV it was broken. ... I just barely got myreplacement bulb in today and it still only blinks orange light. .....I was watching my mitsubishi 73 3d model wd-73740 and ...
After replacing bulb on WD-82738 still not working - Fixya
www.fixya.com/.../t26028385-after_replacing_bulb_wd_82738_still_no...
6 mins ago - after replacing bulb on WD-82738 still not working bulb went out and burning smell. Replace the bulb, turned it in - Mitsubishi WD82738 82 ...
Mitsubishi WD-82738 Blinking Green Light - Tom's Guide
www.tomsguide.com/.../id.../mitsubishi-82738-blinking-green-light.html
Jan 12, 2015 - I have a Mitsubishi WD-82738 with the blinking green light of death as I have seen it called. ... Sounds like you replaced the parts, and it still is not working.... It would not work for us if we did it after the blinking. ... overnights. an ive already t akeing out the bat Forum; blinking green light changed bulb help!
Amazon.com: Mitsubishi WD-82738 DLP TV Asse
Dec 29, 2015 | Mitsubishi WD82738 82 1080p 3D DLP Home...
Mitsubishi 73 in made a loud sound now it does not work
do any of the lights on the TV light up a solid color or blink? Please respond to this same post for assistance.
Feb 07, 2013 | Mitsubishi WD-73827 73" HDTV DLP TV
How do you do a convergence on the wd73286?
Mitsubishi WD-73286 is DLP tv that does not have any convergence circuit inside.
Convergence is required in old model rear projection tv that has three basic colors picture tubes to generate color picture that projected on front screen of tv.
DLP tv has light engine to generate picture, it is similar to multimedia projector that throws its picture on wall.
Hope this info will help.
Thanks.
Mar 05, 2011 | Mitsubishi WD-73827 73" HDTV DLP TV
My tv turns blue and turns itself off
optical block assembly going bad. repair is pretty costly. try vacuming out the fans. DO NOT USE CANNED AIR!!!! you will blow all the crud into the optical block.
Jul 12, 2009 | Mitsubishi WD-73827 73" HDTV DLP TV
Mitsubishi 1080p 73'' DLP HDTV - Color distortion
This would be the little sensor on the light wheel. Its cheap, you can get them online for around $2. You will need to take the light engine out and remove the color wheel cover and remove the color wheel and then remove the sensor. You will have to desolder the sensor and remove it to replace with the new one.
What is happening is the sensor is overheating and not tracking the color wheel properly there for the colors get messed up. Once you replace the sensor the tv should work like normal. The part is
(Sharp GP2S40 Photointerrupter). It is very difficult to find because they are not made anymore. Most major online part stores do not carry them but I found a lot of them at Wright Hobbies. Good luck.
Nov 11, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-73927 73" HDTV Logo
711 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
