Scorn (Noun) /Skorn/
1.A feeling that someone or something is not worthy of any respect or approval.
2.harsh criticism that shows a lack of respect or approval for someone or something
1.
feel distaste for or hostility towards.
"she disliked any kind of unnecessary rudeness"
synonyms:
hate, detest, loathe, abominate, abhor, despise, scorn, shun, execrate; More
noun
1.
a feeling of distaste or hostility.
"he made no secret of his dislike of the police"
synonyms:
aversion, distaste, disfavour, disapproval, disapprobation, disesteem, enmity, animosity, hostility, animus, antipathy, antagonism; More
Have you tried the USB on another computer? If you have and it is still saying the same thing then it could mean that the USB is faulty and you might need to get a new one. But if it works on another computer then that could mean that the USB ports on your computer have burnt out. Please let me know if I can help you with anything else.
In DIAGNOSTICS menu select "paper path sensor test" Pay attention to E, it refers to "tray 2 pre feed sensor". You say that you " tried changing Rollers,and all the sensors". I'm confused, does that mean that you tried and couldn't change the sensors. You could also have a bad paper tray. Did you also try and succeed in changing the tray 2 jam access door roller? 13.01.00 means that the pre feed sensor never sensed paper, so either the sensor is bad or the paper never fed out of the tray. Try a different tray.
you can know if the camera is charging by the indicator light in the usb cable, green light means it was full charged..red light means that unit still charging.
Error 5100 is carriage error. Carriage is printer's cartridge holder. This means that there is some problem with printer's carriage, you'll need to check the plastic stick (around 1/4" wide). Also, check for any obstructions in the printer's carrriage path ( like small bits of paper stuck under carriage or any kind of paper jam).
Turn off the printer and remove the cartridges and reseat them after cleaning the carriage's bottom area with a Q-tip.
The "magic needles" while making the camera easy to load are about as intuitive as a dead skunk, I had a similar confusion when I got an ME Super. Put the film can in the left side of the camera back (the side with the little thing sticking out is the bottom, it looks upside down this way, but that is correct). Next push the film winder down, this will semi-lock the can into place. Now pull the film-lead across the camera and push it down between some of the white "magic needles on the opposite spool(push it in a bit so that it will stay). Next advance the lever; release the shutter. If the spool starts to turn you are doing it right. Now close the door and continue advancing and clicking until the little frame number window on top reads 1.
Find the paper in the envelope on the back of the stove. (Behind the console.) This will tell you what those fault codes mean. Be sure to replace the paper. If it is needed again, that is where a technician will look for it.
Make sure there is no paper jammed in machine, H5-01 means 5 jams same location. Use quality paper not recycled and make sure it is fresh not old stock
PROGRAM INTERUPT CLEAR INTERRUPT must be SUPER FAST then 14....WILL RESET CODE
