Open the hood of your SRX and disconnect the connector from rear of headlight by squeeaing the tabs. Pull off rubber dust cover. Rotate the collar on the headlight counterclockwise and pull it out of the headlight assembly. Insert new light and turn clockwise to lock it in place, DO NOT TOUCH THE BULB WITH YOUR FINGERS, THE OIL DEPOSITED FROM DOING THIS WILL CAUSE THE BULB TO OVERHEAT, LOWERING THE LIFE OF THE BULB CONSIDERABLY! use paper or something that is oil and dirt free. Replace dust cover and reconnect the power connector.
HEADLIGHTS NOT WORKING
It
can be faulty headlight switch or issue with its wiring. Or its faulty head
light fuse.
To
troubleshoot the issue i suggest you few help links with appropriate solution.
So you can follow the test and confirm what exact problem is there in your case
of headlights not working:-----
Click
the link below: -----
http://repairhelpcenter.blogspot.com/2012/01/all-headlights-not-working.html
• Working of Headlight switch?
• Both headlight bulbs blow together?
• Car
headlight bulbs don't last long?
http://technoanswers.blogspot.in/2012/06/2007-dodge-caliber-low-beam-headlight.html
http://technoanswers.blogspot.in/2012/04/2001-chevrolet-tahoe-both-low-beam.html
http://schematicsdiagram.blogspot.in/2012/04/low-beam-headlights-modification.html
How to Replace a Headlight
http://schematicsdiagram.blogspot.com/2011/08/how-to-replace-headlight.html
Bulb
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-headlight-bulb.html
Switch
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-headlight-switch.html
How to Replace a Headlight Assembly
http://schematicsdiagram.blogspot.com/2011/08/how-to-replace-headlight-assembly.html
How to Replace a Park Light Assembly
http://schematicsdiagram.blogspot.com/2011/08/how-to-replace-park-light-assembly.html
http://schematicsdiagram.blogspot.com/2011/08/how-to-replace-headlight-door.html
http://schematicsdiagram.blogspot.com/2012/01/how-to-replace-hid-headlight-bulbs-for.html
These
will help.
Thanks.
How to Replace a
Headlight Switch
Low beam headlights Modification?
Headlight Assembly Removal On Honda Accord
http://technoanswers.blogspot.in/2012/06/headlight-assembly-removal-on-honda.html
Honda Headlight Assembly Removal
http://schematicsdiagram.blogspot.in/2012/06/honda-headlight-assembly-removal.html-----------
How to Replace a
Headlight Door
All headlights not working?
How to replace HID headlight bulbs for lexus
400h?
• Car headlight bulbs don't last long?
These will help.
Thanks.
