Got a pop up message told me 0 in memory then a second notice said something like buddy this is a brand new tablet with nothing really on it yet. when i turn it on only get eatic screen tried soft reset but it still only gives ematic start screen. i can not get into settings to do factory reset. how can i get it on and to the settings to do this
Upgrade to a better android operating system YouTube can direct you in most cases but it's a precise and complicated process. Try YouTube search "android upgrade for 'device model'" be sure when messing with this stuff you have the right info. One mistake and you may have a paper weight. You may have to root your device prior to upgrading from the manufacturers operating system but can unleash a whole new tablet with a good version of Android. Do the research. YouTube can help.
SOURCE: My Sansa Express is not responding. It won't turn
Just to be sure, First, try a soft reset. Do this by pressing the center button and the up volume button simultaneously and try turning it on. If that does not work for you, you will need to get a micro sd card (it can be a dummy) and insert it into the slot on the side of the mp3 player. If you do not have one, you can use one of the round edges of a paper clip (be careful) to get it to come on. When you put either in, it should come on automatically, but if not, just press the power button. This should work.
SOURCE: I have a mp3 player
Theres Usually a reset button on the back. Its an extremely small hole , you should use like a pin or the back of an earring to push it in so it will reset.
after uninstalling app store updates, l went to the reset button(actually a tiny hole) on the back of my ematic tablet, used a head of a needle(paper clip,etc) to press the reset button. My app store came back. Until ematics works out the kinks l just won't install anymore updates.
