Question about Electrical Supplies
I have a dewalt generator that will crank and run fine for about 5 mins before it cuts off.
    Scholar:
  • 79 Answers
I am going to guess that this is an air cooled engine. When a genset shutsdown after 5 minutes it could be that the the oil pressure switch is not operating properly, or that output voltage is dropping out. Also, check the speed of the genset using a frequency meter at the outlets. It shouldn't be no more than 62Hz.
Posted on May 12, 2009
Will only run for 10- 15 min. then shuts off.
You might have a thermal issue with the ignition coil shutting down after it gets warm. Happens.
Aug 27, 2015 | Dewalt Electrical Supplies
Why does my Kohler 7.3 generator start and runs great for about 5 min. then shuts downRestarts fine but shuts down seconds later. Upon removing rad cap, fluid is seen moving upon warm up. How do I...
change the oil to the correct specification first. As the engine runs the heat changes the viscosity and overheats or trips the oil alert switch. If its over 10 years old change the oil alet magnetic switch
Jun 12, 2014 | Kohler Electrical Supplies
Need user's manual
crank run 2 min.cut off no fire from coil 24 hour later crank run 2 min
Nov 21, 2013 | Honeywell 2000 Watt Inverter Generator...
2003 crown victoria cranks wont start, was running fine, just cut out.never started again
As with any no-start situation, you need to know if you have spark to the plugs, fuel to the injectors, and normal compression to proceed.
Jan 28, 2013 | 2003 Ford Crown Victoria
Cranks fine then dies out
check for spark when it cuts off also check the oil level some have a low oil shut off also dry and run it with the gas cap loose to see if the vent is plugged
Sep 01, 2012 | Generac 5622 portable generator,5000 rated...
My Coleman Powermate 5000 cranks fine and runs for 10 mins and seems to over heat and cuts off. Fresh gas, oil fine and carb cleaned very well. The muffler gets cherry red at night. Carb adjustment? ...
Carb is probably the problem as you thought. It sounds as it might be running too lean, meaning the mixture does not have enough gas in it. Try turning the high speed mixture screw (remembering the position that you started from) counterclockwise in 1/8 turn increments (adds more fuel to the mix) until it starts to run rough then turn back to mid point from where you started from. Have you tried checking for obstructions to the proper circulation of air through the fins for cooling. Make sure all the shrouds are installed. Some people think by removing any covering over the engine will help for cooling, it doesn't they are designed to have all the parts on it for proper cooling. Hope this helps a bit. Good luck.
Jan 11, 2011 | Coleman Powermate Powermate 5000W...
Electrical Supplies Logo
65 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
