OS is Windows 7 Starter Ease of Access feature still works
SOURCE: hdd master password
PLEASE REPLACE UR MOTHER BOARD BATTERY. I GUESS UR BATTERY MODEL WILL BE CR3212... PLEASE CHAGE IT AND TRY IT AGAIN. NOT YOUR LAPTOPS BATTERY... THIS IS A BATTERY ON THE MOTHER BOARD. PLEASE TAKE IT TO UR NEAREST DEALER AND GET IT DONE.. PLEASE DO NOT OPEN IT WITH ANY KNOWLEDGE.
CHEERS
AVI
SOURCE: type in password get message access denied or incorrect passwork and reboots
I was given an old computer years ago that was password protected I was told to pull the battery out for 10 sec. then reinstall it. It cleared the pass word protection. Note: pull the power cord push the start button to drain any power from the system, ground your self to protect the computer of any static electricity first.
SOURCE: Key board not working
It's a hardware issue,
Maybe RAM or hard drive..
Did you get it used? If so the password was set b4 you purchase it, and will not show up when you type,,,It stays hidden.
Your getting this screen because there is a hardware failure. Fix the problem and you wont need the BIOS password.
Press<esc> to enable startup message, This should give you more info on the problem.
SOURCE: hitachi laptop hdd password
you can try removing the bios battery for a couple hours and see if it resets.another option could be to flash the bios. i heard that you can take it to best buy andthey take care of it for you
SOURCE: Dell Latitude error #field **-595B protected
u will need to open the laptop, there on the mainboard u will find a battery, u have to remove the main battery and remove the laptop from current. its a small round battery u have to remove it for some 5secs just to clear the bios memory, then put it back back. the password wont be here. if there is no round battery then u will find a jumper that u have to short it. else remove the hard disk use a USB cable transfer cable to use it on another pc or laptop to recover your information
