Rinnai freestanding Royale ETR flame fire (mains gas): All of a sudden my heater cuts out when it reaches the set temperature and I cannot work out why. I have the ''Auto Off'' turned off. I cannot work out how to disable the timers - I do not want them on, I just want to be able to turn the heater on and off as needed. It works ok when the room is cold, but once it reaches a certain temperature it seems, it just cuts out and cannot be started again until the room gets cold again. Very frustrating. I hope someone can help please - we are freezing our butts off here. Never used to have any problems before. Thanks, Leanne
  • pigsti555 May 17, 2009
    My Rinnai built in Royale ETR will also switch off when it reaches a set temperature say 22'C. The only way to get it back on is to turn it off and on again. It has to be left on High otherwise it will continually turn off when the room heats up.
I had the same problem with this unit and had the heater serviced which fixed the problem. The problem is caused by the pilot flame not being big enough to keep the thermocouple hot, so the heater thinks the flame is out and it turns the gas off! The thermocouple is effectively a switch that is on when hot and off when cold. The pilot flame is supposed to keep it hot, so its on and the main burner will get gas. When its off (ie cold) gas is blocked from the main burner for safety reasons! This manual is for a very similar heater: http://www.rinnaisales.co.nz/tradesmart/rinnai2/pdfs/service_info/171.pdf
You need to get at the pilot and clean it out!
David
Posted on Jul 14, 2009
My pilot stays on on my propane furnace but will not light up
The Little Giant units use a Unitrol gas valve very similar to a water heater in the home. #1,urn the Unitrol gas valve to the "PILOT" position to ignite the pilot. Depress the plunger and hold it down then push the spark igniter button until you can see the pilot flame ignite.
You have a lit pilot so this is not a problem for you.
The pilot light stays on continuously by design.
Once the pilot flame is established, you then turn the on/off/pilot valve to the "ON" position and set the thermostat to the desired temperature range., it should then fire its main burner until the desired temperature is reached. Once the temperature is reached, the main burner will shut off and the heater will go into a standby mode with the pilot flame still burning.
If you have turned the pilot valve to on and set the temperature high, it should come on, if not a new gas valve is required, they can be very difficult to replace due to rust.and most cases require a new unit,
Mar 19, 2015 | Unitrol Propane Heater Valve - Little...
Rinnai IB35ETR shows error 12 after room temperature reaches the set value, restarting it will show error code 11
Hi there, i have same unit and its got error 70 coming up. Which is faulty on off switch as per manual. I can confirm on off button on control panel, up on top is not working however remote is working. When i try to start it with remote it comes up but turns itself off with error 70 again. I tried to remove this control panel (pcb) from unit however it is still doing same. Now i am not sure if it is actually pcb panel which is faulty ? Please help ;)
Jul 15, 2014 | Rinnai Heating & Cooling
I have a rinnai flame fire inbuilt royale 1b35etr but not igniting . what do i do. electrics come on and no smell of gas- pipes all look good and gas bottle on
First, be sure that the inline gas shut off valve is turned ON. The gas tank valve is On, but the inline valve may not be. if you do find that the inline gas gas shut off valve is ON, there may be air in the gas line that needs to purged.
In case you have your Owner's Manual, I have included a link to it, that you can download & print for future reference. it will explain how to purge the line, if necessary.
http://www.rinnai.com.au/images/stories/operating_instructions/Heating/Flames/Royale%20Inbuilt.pdf
Hope this helps you troubleshoot & solve the problem. Thanks for choosing FixYa. Cheers.
Aug 16, 2011 | Heating & Cooling
Hi i have a Rinnia Royale ETR heater and every time i run my gas hot water the heater goes out. It seems as if there is not enough gas to run both at the same time.can you help. thanks Brian
Definitely sounds like there is a gas pressure problem. Are the gas lines feeding both appliances the proper size (at least 1/2" diameter)? Are they natural gas or propane units. If propane, what's the Btu rating of the regulator on the propane tank? If it's to low to handle the two appliance at one time, that could be the problem too.
Jul 18, 2011 | Rinnai Vent Free Gas Heater/
Rinnai gas log heater (royale) keeps cutting out. now it wont stay on at all. the ignition is fine, the gas flow seems fine and the fan works fine. we vacuum the dust out regularly
When you say "it won't stay on at all." Do you mean the burner and the pilot flame shut off together or does the pilot remain lit? Is the unit showing any Fault Codes on the LCD display?
Apr 03, 2011 | Rinnai Heating & Cooling
Hi I have a rinnai flame fire royal model ib35etr It keeps going out and flashes number 12 on the screen we are moving and packed the book
I had this same problem last year and went through all the checklist in poshpoms suggestions ( I am on mains Gas ). The issue was caused by the Flame rods. Near the 2 pilots at the front and the back. Those small rods each that 'senses' the flame become inadequate, so they were replaced with a new pilot assembly from Rinnai that had longer rods and better coverage. Issue was fixed. Good Luck.
Aug 23, 2010 | Heating & Cooling
Does not want to start
Intermittent faults on these units are very very rare; they either work or they dont! Ive had similar reports that ended up being more of a gas regulator fault (thats the hunk of metal that the small copper tubes from the cylinders are connected to). Do you have any other applainces on gas. When the heater doesnt work try the others'; if they work keep thenm going and then go back and try the heater. Does the heater try and ignite? I also like to recomend getting these heaters serviced occasionally. Just like cars, intermittent faults can be a reminder to get a good service done.
Jul 21, 2010 | Rinnai Heating & Cooling
I have a rinnai heater and it stopped working all
rinnai, toyostove and monitor heaters are basically all the same. first you have to make sure your fuel valve is open at the tank. next you have to reset the tank lockout on the sump. then set your set point higher than your room temperature. now press on. the unit will go through a 300 second purge cycle. the pot heater should turn on when the purge cycle starts. after the purge cycle the fuel pump turns on and pumps fuel into the pot. when it vaporizes the igniter lights it. when a flame is detected the flame rod says ok to keep running so the fuel pump shifts into high speed. when plenum temperature reaches a preset level the fan turns on.
Oct 17, 2009 | Rinnai Toyostove Direct Vent Heater:...
Rinnai heater flashes code 12
Bailey,
Next time you try your stove watch the flame. If the flame goes away and then the error code comes on, you have something wrong with the over temp circuit, gas or gas valve, If the code comes on and then the flame goes away you have a flame sensor problem.
Good luck,
Tom Hawkins
hawkins111@gci.net
Mar 13, 2009 | Rinnai Toyostove Direct Vent Heater:...
Heating & Cooling Logo
941 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
