Question about Garden
Difficulty starting. When it does start it will only run for a short time at a slow speed before stopping.
  • 246 Answers
Hello
>>The Following is a Basic Instruction File for Doing a Diagnostic on the Engine for this Problem. Any Input is Appreciated.
>>**Remove the Muffler and Make Sure the Exhaust Port is Clear.
>>If it is, then Try to Start the engine with the Muffler Off.
>>If it Starts and Runs Properly, then Clean the Spark Arrestor Screen in the Muffler or Replace the Muffler if Required.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 11, 2009
My laptop won't start up normally. The fans and everything begin to turn and start when I press the power button, but within seconds, they start to slow down and eventually stop.
You did not post anything about make and model. This is kind of a guess.
My laptop has "battery saving" setting that operate the fan based on temperature. When I start up, the fan comes on and the computer checks itself, Then the fan slows down. Later when the laptop warms up, the fan speeds up. See if you have some power management scheme set that makes the fan run like this before you take it to the shop.
Your laptop should be under warranty.
May 09, 2015 | Computers & Internet
Why is computer slow fungsation any time hang
Do you mean slow function ? .a computer hangs when you do not have enough memory (RAM) installed and to many program.
Jun 05, 2013 | Computers & Internet
I was cutting 2" dense foam insulation board,
The problem you have is a faulty field coil, the Bosch saws unfortunatly have a bit of an issue with this. The coil can be replaced separatly so you won't have to replace the whole motor. Bosch has a 1 yr warranty on thier table saw so this is a warranty replacment provided the saw was purchased within the year. If not the coil replacment is still cheaper than buying a whole new saw, but should really be done by a service center because of the level of difficulty of the repair.
Nov 10, 2010 | Bosch 4100 10" Worksite Table Saw
Maruti zen engine stops working when running on slow speed.
you may try replacing the clutch lining, it may be too thin. hope this helps
Jul 15, 2009 | 1996 Suzuki Esteem
Have kelvinator smart drive 503, water won't run
I have exactly the same issue, which first appeared yesterday. Following your advice, the lights that are lit are 3rd, 5th, 7th and 8th. The SLOW & HOLD spin speed lights are lit, along with constant beeping :)
Jun 16, 2009 | Fisher and Paykel GWL11 Top Load Washer
Hard starting after rebuild
My name is Dennis and I also have the model you are having difficulty with and I can only repeat the instructions from the owners manual (with personal comments) because they have always served me adequately I hope that will serve your needs.
IDLE ADJUSTMENTS:
There are three adjustment screws on the carburetor labeled
H (for High speed MIXTURE)
L (for low speed MIXTURE)
T (for idle SPEED SETTING)
They are located just above the primer bulb. If your saw floods so soon in the starting process the idle mixture setting can be set too rich and the speed may be set too slow. Remember the chain will not move when the idle speed is set correctly with a WARM ENGINE!
Adjust the idle speed to just below chain movement WITH A WARM ENGINE this is just below the activation RPM of the centrifugal clutch. Let the engine run at a higher speed than idle until it is warm -- 3 min -- you may have to keep goosing it until then.
Please don't exceed the limits of the plastic limiters when making adjustments.
If you haven't adjusted the mixture screws you may just have to adjust the idle speed and that can start my turning that screw all the way in to the stop and then back out 4-1/2 turns for a good place to start. FAST IDLE -- Adjust the speed until the engine runs with out the chain moving. Adjust clockwise to increase speed. C clockwise to decrease engine speed.
Accelerate the engine and if it stumbles and makes too much smoke it's too rich turn the
LOW SPEED MIXTURE (in) clockwise in 1/16 a turn increments NO MORE at a time because a two cycle needs to run at a setting for a short time to really prove the setting. don’t run it wide open to warm it up but it should be at a fast idle. Nothing you do will be proven correct until the engine is warm.
Good Luck
Glad to be of assistance - please rate the solution because I will learn from your rating. Thank you
Nov 07, 2008 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan 2450 Woodmaster 2.3 ci eng.
Hi Guest,
IDLE ADJUSTMENTS:
If you haven't adjusted the mixture screws you may just have to adjust the idle speed and that can start my turning that screw all the way in to the stop and then back out 4-1/2 turns for a good place to start. FAST IDLE -- Adjust the speed until the engine runs with out the chain moveing. Adjust clockwise to increase speed. Cclockwise to decrease engine speed.
Accelerate the engine and if it stumbles and makes too much smoke it's too rich turn the LOW SPEED MIXTURE (in) clockwist in 1/16 a turn incriments NO MORE at a time because a twocycle needs to run at a setting foe a short time to realy prove the setting. dont run it wide open to warm it up but it should be at a fast idle. Nothing you do will be proven correct untill the engine is warm.
Good Luck
Your IDLE MIXTURE may be too rich causing the engine to flood.
Oct 17, 2008 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
