Question about Garden
Ther is a container on my stiga lawn mower that runs to the gear box.what type of oil should i use
  • chipper648 May 11, 2009
    thanks for being so prompt.i really appreciate you sending this information.peace to you and yours
  • chipper648 May 12, 2009
    thanks again john. your information was very helpful to me.until next time keep the mind body and soul happy and healthy.
    peace
    chad
  • 246 Answers
Hello chipper648:
Most of these use either 80W90 Gear Oil or SAE 50 Engine Oil for the Transmission Gear Boxes.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 11, 2009
  • John C Bridgers Sr May 11, 2009
    Hello Again chipper648:
    I am Glad I was Able to Assist.
    >>Till Next Time. May All Your Mechanical Problems be SMALL ONES and as Always, May the All Mighty Bless You and Yours. Be Safe and Happy.
    Best Wishes and Good Luck
    Respectfully
    jbridger (John)
Why does it blow white smoke (when running)?
First check the oil level. If it is too high oil will push past the rings causing the white smoke. If the oil has not been changed for too long the oil has thinned out and should be changed.Do not use motor oil that does not contain lead. It is normally sold as lawn mower oil. It is 30 weight nondetergent oil and contains lead to properly lubricate the engine If the oil level is proper it is time to have the motor cylinder honed and a larger piston and rings fitted. this can be expensive. It could be cheaper to replace the mower
Mar 28, 2016 | Garden
Transmission oil drain
it should be in the owners manual for the mower. I would say its gonna be a heavy gear oil. A local true-value or anywhere that works on lawn mowers should know about what kind
Sep 18, 2013 | Troy Garden
How to change oil on 158cc briggs
remove oil check stick,Tilt it over and let it run out of the hole. New tech,lol.
Oct 26, 2012 | Yard Machines 158cc Push Lawn Mower #11a...
What type of oil and gasoline do you nee d to run Craftsman 6.5 lawn mower?
generally all 4-cycle lawn mower engines are tuned to use regular unleaded gas ,(I personally use mid or high grade unleaded)....and for engine oil use strait 30 WT engine oil...... I often put a dash of fuel system cleaner in each gallon of lawn mower gas,it is not absolutely neccessary but seems to help moisture stay out of gas..(DO NOT USE HEET or other methenol based fuel additives for this can cause overheating or scoring of piston and cylinder...but rather use a petroleum based additive,this allows the small amounts of moisture in fuel to pass through the carbeurator without clogging filters or fuel system for smoother running)..also...if you put lawn mower up for winter it is always helpful to use a fuel stabilizer such as "STABIL" or other such products (follow directions for use) and be sure to change the crank case oil in the spring before using....this will give you much longer life from your lawn mower...
Keep air filter clean!!!..... Happy mowing!!!....so, the answer?...regular unleaded and 30wt engine oil...if you would like..they have special engine oil for 4-stroke engines at most hardware and walmarts n such...but is just expensive 30wt oil... Enjoy your day,Todd
Nov 23, 2010 | Garden
Stop moving
maybe gear box shot, or hung up
Jul 25, 2009 | Garden
Garden Logo
262 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
