Question about BEL 890 Radar Detector
Beltronics 890 Problem
The unit goes into a constant alarm mode and flashes: ?L03,  then flashes: ?MARKERS.  I turn it off and on - then it works ok. What gives and how do you make it stop doing this?
  • Lesh Jan 08, 2008
    I have a similar problem which seems to be increasing in frequency. I mailed Beltronics for advice (the unit was purchased in UK from a now defunct dealer) The reply was that they "thought" it could be a failure in the self-test routine and suggested that it should be returned for repair. Lordy knows how much that would cost. Most annoying as the unit works perfectly in other respects.
  • dravenjun Sep 11, 2008
    i have the same problem my code reads ?lo1 cal
    New Friend:
Most likely its the socket on the side were your power cord goes' is not getting good connection. either from corrision or damage.
Posted on Nov 30, 2012
I am looking for a fix as well mine says" ?LO1 CAL "
Help!!!!! now mine wont go back to working mode at all
I will restart and get the same error message and of cource nothing in the instructions I say " W T F !! "
Posted on Mar 12, 2008
Two of my smoke alarms went off (no fire/smoke in or near house), one has a green light blinking and one has a solid green light, which need a new battery/reset?
The constant green LED means the alarm has AC power.
A flashing green light every 2 seconds without an audible alert means the unit recently sounded ( was the one activated ) and is now in latching mode to let you know that it was the unit that detected the problem. To clear the latching mode hold down the test button for 5 seconds.
Red LED flashing once per minute means that the back-up battery is connected and functioning.
Red light flashing constantly during alarm means that it is the unit that initiated the alarm siren.
Sep 04, 2014 | Cars & Trucks
How to set and remove alarm set
Turning on/off the alarms
To turn alarm 1 on/off, follow these steps:
  1. Turn the system off
  2. On the radio, repeatedly press the Alarm Mode button until the desired alarm mode indicator below "Alarm" is displayed. The music note indicates radio and the sound waves indicate the alarm tone. If no icons appear on the display, that means the alarm is turned off
wr_alarm_set_icon_both.gif Radio and tone
Radio only
Tone only
Alarm off
To turn alarm 2 on/off, follow these steps:
  2. On the radio, press and hold the Alarm Set button. "Alarm" flashes on the display
  3. While holding Alarm Set, press the Alarm Mode button once. "Alarm 2" flashes on the display
  4. Release Alarm Set, and repeatedly press Alarm Mode until the desired alarm mode indicator above "Alarm 2" is displayed. If no icons appear on the display, that means the alarm is turned off. The "Alarm 2" indicator will continue to flash on the display for 10 seconds. When the flashing stops, alarm 2 is set
wr_alarm2_set_icon_both.gif Radio and tone
Radio only
Tone only
Alarm off
Jul 20, 2014 | Bose Wave Radio
Alarm went off but no smoke was found and no other smells were detected. I do not believe that there was CO present. All the units were activated. after a period of time they stopped. This occurred 3 times...
http://www.kidde.com/Documents/User-Guide-900-0102-A-ENG.pdf Remember that smoke take presidence over C/O detection so notice whats going off first . LED Indicator Operation
Red LED
The red LED will flash as described below under the following
conditions:
--During smoke or CO alarm, with every beep
--During testing (same as alarm)
--Low battery, single flash with chirp
--End of product life, double flash every 30 seconds with chirp
--Unit error mode, single flash with chirp
--Unit error mode, a Fault Code is flashed every 30 seconds (can
be observed and reported to customer service for
troubleshooting. Above is the user guide.
Sep 09, 2013 | Kidde 9000102 Night Hawk Combination...
Heat blows cold air
The LH models (LHS, Concorde, New Yorker, Intrepid, Vision) do have self-diagnostic capability with the standard type heater controls. I don't know about the Sebring heater controls (my '95 manual doesn't mention it) but if you have the various controlknobs/buttons that I will describe you could give it a try.
There is a rear window defogger that is initiated by a push button with an LED light. That light is the readout, by its blinking. To begin the diagnostic mode, run the vehicle at idle with the controls set as follows: the blower speed knob should be on any position other than OFF, the temperature knob should be set in full COOL, and the mode knob should be set on Defrost mode.
To enter the diagnostic mode, press the defogger switch in for five seconds, until it begins to blink, then release it. It will continue to blink for about 30 seconds while it calibrates. If it goes out, the calibration is OK and you can skip 3 paragraphs to "Position...mix mode" below.
If the light stayed on, switch the mode knob to the MIX (defroster-floor) position. If the light stays on there is a problem with the control head unit.
Switch the mode knob to the FLOOR position, if the light stays on, it indicates a problem in the blend door or the blend door actuator wiring.
Move the knob to the Bi-level (panel-floor) position where a continuous light indicates a problem with mode actuator or circuit.
Position the knob in the MIX mode. The LED light should now flash twice then pause, and continue a two-flash sequence, indicating that the MIX mode is OK.
In the FLOOR mode the light should flash three times, meaning that the FLOOR mode is OK.
In the Bi-Level Mode, a four-flash sequence indicates that mode is OK.
In the PANEL mode the light should flash 5 times to indicate no problems there, and in the recirc-panel mode 6 times and seven times in the recirc Bi-level mode.
The temperature control can be checked by switching the mode knob to Defrost and rotating the temperture knob. If the temperature contol is OK, the light will flash faster the more you turn the temperature knob up, until the light goes out at the hottest setting.
Switch the knob between Panel and Recirc-Panel and watch the recirc door (unit under the dash). Proper operation means that circuit and components are OK.
To get out of the self-diagnostic mode, turn off the blower or push the air conditioning button once.
If this doesn't seem to apply to your control head or you get no response from an LED light for the rear defroster, then the Sebring may not have this capability. Please let me know your results if any
Dec 02, 2010 | 2001 Chrysler Sebring
Rudd model nu. VACC-024JAS. outside unit will not work. A little constant humming. Motor appears to be ok
the constant hum is probably the contactor which may be pulled in on the 24volts check your capacitor that is most common to go out its a canister either oval or round it has wires going in to it please give me a vote and rating
Sep 22, 2010 | Ruud UAMB042 Air Conditioner
Vector 940 works for a moment, then flashes ?L03 CAL ?MARKERS
just turn off the sws messages.
it probably recieved a jumbled signal from a "roadworks traffic control unit".that it couldn't understand.
Aug 31, 2009 | Pro RX65 Radar Detector
Alarm/ indicator lights keep flashing when i turn the car on
Yes.. the circuit is stuck in the safe mode. Usually when you disconnect the battery it goes in the safe mode as if someone is trying steal the car and cut the battery wire to cut the alarm off, so it goes back on as soon as the circuit completes. So just get that cleared up and you will be fine.
Jun 23, 2009 | 2001 Toyota Corolla
Uniden vs1100xr car alarm will not arm or disarm,have found valet mode button which sets & resets ok but remote just flashes led no chirps or lights flashing
I had the same problem with my vs1100xr. The remotes for these (and other) unidens have a rolling code. Seems to me that either the remote runs out of new codes and cycles back to the beginning, or the alarm base unit somehow loses track of the codes. Either way, the alarm base unit stops accepting the codes of your remote, and so needs to be purged of its code tracking memory - reset, if you like. This is essentially the procedure for training the alarm base unit to recognise new remote (and forgetting old remotes).
This procedure is:-
1) Disarm alarm, or if in valet mode, take it out of valet mode (push valet button 3 times)
2) Turn the ignition on and off 2 times within 15 seconds.
3) Put the alarm into valet mode (push valet button 3 times) within 15 seconds of completing step 2. Alarm should beep, and remote training has started.
4) Within 15 seconds of completing step 3, push the button (#1) of the first remote you wish to use for the alarm. Alarm should beep, indicating acceptance of remote. Repeat for other remotes you wish to use - up to 4 in total. (Once the first remote has been accepted, you have all the time in the world to make the alarm learn other remotes)
5) Turn ignition on and off to end remote learning mode. Alarm should beep 2 times. New remotes have now been learned and previous remotes forgotten.
Some of these details may vary from country to country - who knows. If this doesn't work, I suggest that you contact Uniden in your country to obtain the procedure. Took me a few tries to get the timing right, what with the valet button hard to get at and having only 15 seconds between steps.
Sep 28, 2008 | Car Audio & Video
GE Model 7-4837B
press the Cancel button located on the top of the alarm clock (the light next to the wake mode indicator on the front of the clock should start flashing). Then press the WAKE Mode button on the top of the device. The wake mode indicator on the front should now be off and the alarm deactivated.
To turn the alarm back on, simply press the WAKE Mode button on the top of the device.
Mar 27, 2008 | GE 74801 Clock Radio
HOW DO I SET THE TIME?
Wildbill,
My wife has the AudioPhase SPR1 AM/FM 2 AAA portable sports type music player. There is no pdf manual available on internet yet - I will scan and post when I get time. The paper manual says:
To set the Clock:
1. Turn unit off.
2. Press MEMORY once: the clock will start flashing.
3. Press DOWN/MIN to set the minutes, press UP/HOUR to set hour.
4. Press MEMORY again to complete time set.
5. There is always an AM/PM indicator on the LCD display to indicate DAY or NIGHTTIME or night.
To Set Alarm:
1. Turn unit off
2. Press ALARM once: the alarm will start flashing.
4. When alarm time setting is complete press MEMORY 3 times.
5. The alarm setting is completed.
6. Now alarm standby is ON. ALARM indicator will now show on the display.
--> Alarm will only make a noise throught the headphones. When it goes off cancel it by pressing ALARM.
Canceling ALARM standy by.
1. Turn unit off.
2. Press ALARM twice.
3. Now ALARM standby is off.
Radio:
To Seek press UP/HOUR or DOWN/MIN to click throught the frequency or press and hold to seek.
Oct 27, 2007 | Griffin Technology SPR1 AM/FM Radio
BEL 890 Radar Detector Logo
703 people viewed this question
Top Beltronics Vehicle Parts & Accessories Experts
Steve
Jerry Greenberg
Jerry Greenberg
David Payne
David Payne
Are you a Beltronics Vehicle Part and Accessory Expert? Answer questions, earn points and help others
