Question about E-Machines (T2958) PC Desktop
CPU power problem
My desktop is LG brand, yesterday we had a power cut at home and the pc that time was operating. So after the power got back, I tried to power on the CPU it did but with a sound of ambulance beep and the monitor is not showing any restart.
so how can i solve this problem?
  • libra_1977 May 11, 2009
    i don't think it's a UPS, i mean normal socket extension is what i am using.
  • sabharish
    sabharish May 11, 2010
    Did you connect the system thru a stabiliser or UPS??
    Sergeant:
    Champion:
  • 225 Answers
Good morning! based on your statements, you had no UPS (uninterrupted power supply) connected to your PC which will still supply the needed power for a certain period of time, even during electiricty brownout. However, I presumed that there is an AVR (auto voltage regulator) connected to your PC that will regulate the sudden fluctuation of electricity current. Now, common computer hardware parts that are affected & give beep sound signs in the computer are: Memory card, VGA card & keyboard. Their indicative beep sounds are as follows: Memory Card - continous short beeps; VGA card - start at long beep then followed by two short beep sounds; Keyboard - short alternate beeps continously.
I suggest to reseat the placement of your memory & VGA cards, then check your keyboard if certain key/s that is stuck-up. If still beep sound exists, then possible part is defective based on the sound beeps examples that is enumerated . best regards
Posted on May 11, 2009
  • 297 Answers
Check whether all connection are good and take out any CDs in the tray. I guess this must be a SMPS problem.
Pc just cuts offf and wont come back on for a while how do i trouble shoot it
You might try cleaning out the inside of the case with some compressed air.Make sure pc is unplugged before doing this.
Dust and dirt accumulating inside pc will make it overheat and pc's do not like too much heat buildup.Also, if the thermal grease on the CPU is getting old, the CPU will overheat and that could shut it down. How old is your pc?Realplying New thermal grease onto the Processor will allow heat to transfer off of it better than before.It just sounds to me as a heat related issue.Make sure too that all your fans are operating ok.
including the CPU fan.
Aug 15, 2014 | Gateway ZX4351-47 21.5-Inch All-in-One...
Cpu temperature error
Turn off PC, Unplug PC from power. Open PC case. Examine all fans including CPU fan and heatsink. clean the fans and heatsink. With case open but everything inside connected properly, Plug pc back in. Power up the PC and check that all fans are running. If not replace fan that is not running. Place PC in a well ventilated area when operating. I use a new small paintbrush for cleaning dust from inside of PC.
Sep 25, 2013 | ASUS Essentio Desktop with Intel Pentium...
HP Pavilion a6532f Desktop PC cuts off without warning
These symptoms are typical of a system that is overheating. Check that air is flowing freely over the memory and CPU.
1 is the system dust-free (if not **** out the excess with a vacuum cleaner nozzle, then blow out the rest)
2 check that the CPU fan is revolving properly and is noise free)
3 check that any case fans are operational
4 check the power supply fan is exhausting air
Oct 15, 2012 | HP Pavilion a6532f Desktop PC
Power button turns system on for about 10 sec then cuts off
One reason is.. CPU got over heat. Remove aluminum heat sync over the processor, detach the CPU carefully and clean the top surface, clean also the fan and the bottom of the aluminum heat sync...apply another silicon compound to the top of CPU. turn them back properly and test if there has good results.
Jul 06, 2012 | HP Compaq Presario SR2023WM PC Desktop
Computer wont start acer aspire L-100
CPU overheated? When you cool it down it will start. You can check whether there are lots of dust on the CPU fan and the chase of the machine, they might block the air flow and overheat the CPU.
Jul 08, 2010 | Acer Aspire L100 PC Desktop
My gateway desktop does not want to start,
Check you bios configuration with Date and time correction.
See if your computer need cpu fan cleaning. Try to run F8 and scan your computer after you have accessed to safemode. Goodluck
JMC
Aug 15, 2009 | Gateway Computers & Internet
Emachine 5220 keeps tuning its self off
I think the problem  may be that your operating system  may have gone corrupt
try  to enter the Safe mode  (if you can )
and see if you can  revert back to old settings and whether it helps or not
else   you would have to
  reinstall the whole operating system
Nov 09, 2008 | E-Machines eMachines Desktop PC
E-Machines (T2958) PC Desktop Logo
171 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
