Display shows disk error
Hello, When I put disk in my DVD Home cinema LG LH6530D the display shows disk error. I've tried with different type of discs and the result is the same. I also used a cleaning disk and again no results. Please help! Marin
I dumpet the device.
With best regards,
Marin
Posted on May 14, 2009
I have a Philips HTS5550 home theater. The dvd machine has of late been displaying a "No disc error" when i insert a dvd in the machine to play. I have already tried using the cleaning kit. What might
if there's no flashing red light on lens?.. the ribbon connector of lens is not properly connect, or change it if you notice that it has lines cracked. the bad performance of the disk spinning motor is also causing why was your unit displaying "no disc" error.
Aug 04, 2014 | Philips HTS5550/12 DVD/DivX Home Cinema...
What is the solution to HTS5550 no disc error
try cleaning the lens. if there has no red light on the lens?...check the lens connector ribbon. if you notice that the ribbon has cracked or damaged,,, change it. also the bad performance of disk spinning motor causing the unit displayed no disc error.
Jul 23, 2014 | Philips HTS5550/12 DVD/DivX Home Cinema...
"Loading" error. RCA DCR69702 DVD can't read discs anymore.
Replace unit - the laser assembly has lost the ability to focus on surface of disk.
May 04, 2017 | RCA Televison & Video
My player often displays 'wrong region code' error on disks that I have played before. Also it is recently skipping when playing back all cd's. Can you help?
If you've tried a DVD Laser Cleaning Disc and get the same results then the Laser is failing.
Replacements are sometimes available but not normally costs effective.
Jun 28, 2011 | LG RHT397H DVD Recorder
Dvd sometimes reads error
If this problem occurs only at this dvd it's a disk problem. If it occurs on various disks try using a cd/dvd cleaner set, a wet one is better. Follow the instructions on the set. The main idea is to put one drip of the included liquid at the set (usually isopropyl alchohol) at a specific place (like small brush) on the disk surface and play this disk. That way the "brush" will clean up the laser lens and after that the cd/dvd player will be able to read the disks. BE CAREFULL not to put too much liquid on the "brush".
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs".
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
May 11, 2010 | Samsung HT-Q20 Theater System
When I install disk, ' No disk' shows on display.
IS the disc on a CD-R or CD-RW (burnt disc) some portable players will not support those types of disc's.
It could also be a different region dvd that doesnt match the region codes of the dvd player. There are no known region hacks for your make and model of dvd player.
Sorry and thank you for choosing Fixya! Post back with more info for further help.
May 18, 2009 | Durabrand 8.5'' Portable DVD Player
Ht-x30 samsung cinema system display unknown disc
TThe player does not play this type of dvd disk! only pre-recorded movies and CDs Try hooking Up a player that plays DVD+ and DVD- disks!Hope I was of help!
(please use The ratings to keep this site free!)
Dec 14, 2008 | Samsung HT-X40 System
HTS 3300 - No Disk Error
i had the same ploblem sometime last year and all i did was to put a cleaning disk(the ones with a cleaning brush on) in it a couple of times...and it works fine since then!
Aug 07, 2008 | Philips HTS3500S System
Philipe home cinema - No Disk Error
Hi, the best thing to do is to reset the device back to factoy settings, how to do that is mostly written in your manual. Also unplugging the power for 5 to 10 minutes might help.
Aug 07, 2008 | GE MA90559 Rear Speaker
DISC ERROR MESSAGE
Usually it helps a lot if you take off the upper case of the DVD player (7 screws) and search for the lens of the DVD/CD. Clean it with alcohol or terpentine or something like that and it will probably work afterwords. Good luck.
Jun 22, 2008 | LG LH-C6235 System
Televison & Video Logo
163 people viewed this question
Top Televison & Video Experts
Electro Med Services...
