Does not drain or spin
The washer goes trough every cycle but will not discharge the water nor go ito the spin cycle
  • 75 Answers
  • Test the lid switch
  • Test the timer control
  • Test the centrifugal switch
  • Test the water level switch
  • Inspect the motor coupler
  • Inspect the drive belt (belt drive only)
  • Inspect under the washer for soot (clutch)
  • Test the motor
  • Inspect the pulley
  • Test the transmission
Posted on May 11, 2009
Why did my washer quit spinning out in spin cycle
Quite often the problem with spin cycles is that the cycle cannot start until a sufficient amount of wash/rinse water has drained. So what will often happen is that the washer drains, the cycle starts, a lot of water comes out of the clothes, it stops, waits for the water to drain, then restarts. If the drain pump or drain lines are restricted or blocked or the pump is faulty, the unit may never achieve spin cycle.
Sep 18, 2014 | Washing Machines
Washer WPSR3100WOWW Will wash but not drain and spin... Stops at the rinse Cycle
Christina,
Does it leave water inside the tub? There are a couple of possibilitys. One could be the drain pump. If this fails the wash/rinse cycle will stop as it can sense the water not being pumped out. Can you hear the light sound of a small motot running when it goes into rinse cycle? Listen down at the very bottom far right side or far left side. If you hear the drain pump motor running is there any water discharging out the drain tube going into the wall? You should easily hear the flowing water. If not you have a few possible problems: Drain pump has an obstruction in or around it or, drain pump is actually bad.
Oct 12, 2013 | GE WSXH208A Front Load Washer
The washer will not go ito spin cycle
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 10, 2011 | Maytag Neptune MAH5500B Front Load Washer
At end of spin cycle the clothes are sopping wet. Put on extra spin which may or may not work. I read online that i should open filter on bottom right hand corner. Is that correct/ Many thanks Kim
If water is not removed after the spin cycle then your pump is not removing the water from the washer.
Another problem is the discharge hose. If you do not have that hook to hang on the drain pipe you have inserted the discharge hose too far into the drain pipe. Pull it close to the opening of the drain pipe without it coming off. Good Luck
Jan 07, 2011 | Washing Machines
Washes clothes perfect but will not discharge water out of machine fully on final spin.
If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems:If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly. If you can post your model number I can show you how to access the pump and drain line inside the machine.
Dec 15, 2010 | Hotpoint Washing Machines
I have a problem with my Kenmore Washer. I have tried everything in this article, and although I got the washer back up and running for a load, it's starting to show the same problem again. The water will...
If a coin goes in the drain line and is the same diameter it can stay in and sometimes flip and act as a flapper. One time it may be open and the next flip and close the line off. Take the line off and try and see if it is obstructed.
Oct 27, 2010 | Kenmore 44072 Front Load Washer
Washer won't drain.
My washer fills up with water and goes thru the wash cycle but when it's time to drain, it just sits there and clicks.
Oct 17, 2009 | Tecnik TKL9260 Front Load Washer
Whirlpool washer; spin cycle not draining
It sounds like your water pump is broken. there is a motor inside that pumps the water out when the machine computer changes to spin cycle
Aug 06, 2009 | Whirlpool 4.0 Cu. Ft. Plus Washer
Will not discharge water or go into spin cylcle.
I would have to guess you have a dead spot in the timer. If it stops moving, it would still tick like a clock but the internals of it are not catching to send it into discharge and spin.
Apr 03, 2009 | Washing Machines
Kenmore 22062 will not cycle correctly
Problem fixed. I took apart the bottom of the washer to access the pump, and found that there was underwire from bras stuck in the discharge tube blocking the water from exiting the washer and that was causing the cycle problem. I guess that the washer knew that there was too much water in the tub and kept trying to expel it.
Nov 14, 2008 | Kenmore 22062 Top Load Washer
Washing Machines Logo
21 people viewed this question
Top Washing Machines Experts
