Question about Sony STR-DE597 Receiver
TurnTable Believe it or not, I have a Turntable from the '80's. The audio level to the receiver isn't high enough for the receiver to amplify it up to a level compariable to the other components like the CD player. Any help would be greatly appriciated !
  • 979 Answers
Re: TurnTable
Chances are, you have what is known in years past as a "magnetic" type cartridge on your tonearm. This unit is a much better device than the old ceramic type, but does require a "preamp" to bring it up to the level you need to make it comparable to other sources. Many audio dealers carry such a device, or can order one for you. It's simply called a stereo preamp...Accordianman
Posted on Nov 01, 2007
0 characters
3 Points
Where do I connect earth wire from turntable ?
Should be able to connect it to the chassis of the receiver.
Jan 07, 2016 | NAD Audio & Video Receivers
Using turntable (audio technica at-lp 120) with built in pre amp the sound is distorted and broken up. the turntable requests phono turned on to use. Does the receiver have a pre amp or boost signal...
A turn table produces sound voltage in the millivolt range. If you have it connected to a receiver that has a phono input and the turn table is pre-amplified, you are overdriving the receiver and it is clipping the audio and making it sound bad.
Jan 17, 2015 | Yamaha RX-V592 5.1 Channels Receiver
Can I connect a turntable to my Sony mhc nx3av system which I got 12/13 years ago and it is great. Will it be accessed via the MD option? And must I get a turntable with a pre-amp? Thanks in...
YES, you can not only connect a turntable but also a VCR or DVD player or other analog audio sources using either of the top two RCA INPUT jacks on your unit. Now, for a turntable, you will need to buy a pre-amp because typically a turntable provides too low a signal level for most components to handle. These pre-amps cost $35 and up. Most turntables do not provide a pre-amp. Usually an amplifier or receiver will contain the pre-amp and have PHONO inputs specifically for a turntable. So you are correct, you need a pre-amp of some kind. Be sure to select the inputs on your Sony where you connected the turntable when you want to play records. Hope this helps.
Mar 14, 2011 | Audio & Video Receivers
When i hook up my B &O turnable to Audio 1 Or Audio 2, i got sound but at very low volume even when jacked up to max. all other components blast out audio from my speakers.
It's logical, the audio output level for the turntable is very low (depending on the model about 1-5mVolts) while the line inputs (where you try to connect the turntable) can handle audio levels of 500-775mVolts. As I can see your amplifier is not able to handle this kind of inputs (assuming that your turntable is a typical one, without any include preamplifier) In case you insist on connecting this turntable on this amplifier there are some solution to suggest (mainly using a kind of pre-amplifier between the turntable and the main amplifier) but in order to be sure for what to suggest to you, please clarify me the brand / model for this turntable.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
direct fixya link:
Feb 05, 2011 | Yamaha RXV367 Receiver
I recently aquired a used rotel rx102 stereo receiver and onkyo cp101 A turntable. I bought a new stylus needle for my turntable, and plugged the turntable into the phono jacks on the receiver and from...
If the receiver doesn't have a function specifically named PHONO, yes. Very few AVR's have phono preamps. They're not expensive. I'd check eBay.
Jul 05, 2010 | Nakamichi AV-7 Receiver
Can i use a turntable with the sony str dh500 model? I am illiterate when it comes to hooking this stuff up. Planning to purchase this model only if I can hook up my record player as well as my cd player.
This particular unit only has 2 line level inputs for audio devices. You can use 1 for the CD player and the other for the Turntable. Please note that you will need a phono pre-amp for the turntable as the inputs on the receiver are line level. The preamp will amplify the phono level to line level.
Nov 17, 2009 | Sony STR-DH500 A/V Receiver
Can I hook up a photo turntable to a sony str-de435 receiver? There aren't any jacks that specifically say phono, so I'm wondering if I can just hook it up to any of the audio jacks without any problem....
If your turntable has an amplified output, go ahead and plug it in to the aux port. If not, you won't be able to use it with your receiver properly. Look on the back (or front) of your turntable for a knob labeled "level" or "volume", and that will determine if it's amplified or not. Good luck, I hope this helps!
Oct 19, 2009 | Sony STR-DE435 Receiver
No sound from my record turntable into my computer.
If you're certain there is no sound going out of the TT...
Setting the Pre-amp Switch
For increased flexibility of use, this turntable has an internal
stereo phono pre-amplifier. The Pre-amp Selector Switch
is located under the turntable platter, in the rear-center
(Fig. 1). If the system amplifier you are using has a PHONO
input, set the Pre-amp Selector Switch to the “OFF”
position. If your amplifier does not have a PHONO input,
set the Pre-amp Selector Switch to the “ON” position and
connect the turntable’s output cables to the AUX or other
high-level input on the amplifier (described later).
Turntable operates, but no sound at all
1. The stylus guard is still in place.
2. The tone arm Lift button is pressed in.
3. Amplifier controls set incorrectly: wrong input selected,
tape monitor on, speakers switched off, etc.
4. Check the stylus on phono cartridge for correct placement.
Refer to the instructions for replacing the stylus
on page 5.
Turntable operates, but no sound, or sound not loud
1. If the turntable is connected to an AUX (high-level)
input: The Pre-amp Selector Switch may be set to the
“OFF” position (phono-input level).
2. The input gain of the amplified speaker or similar
device may be too low.
3. The stylus assembly may not be fully seated in the
cartridge body.
You could also isolate the problem to either the TT or the PC by trying the TT on some other sound device like a receiver. Make sure the PreAmp Selector switch is ON and plug the TT into any AUX, CD or TAPE input.
Sep 02, 2008 | Nakamichi AV-7 Receiver
Hi Harpwailer,
I was unable to locate an owner's manual for VSX-D412 on the Pioneer website. I did find a VSX-D411, which I believe is very similar. Since there are no turntable jacks, I would try any set of open analog (RCA cable, like the ones that come out of your turntable and are probably red and white) jacks. Just plug the red cable into the red input jack, and the white into the white. The only thing to be careful of is to make sure that you use the input jacks, since some components (like tape decks) have input and output jacks, so that you can record to/from them.
This will work fine assuming that the output from your turntable is strong enough. Many turntables are designed to go through a pre-amp circuit; if this is the case with yours, you'll know it since the output volume will be very low, even when turned up very high. If this is the case, you'll need to purchase a pre-amp to put in the circuit between your turntable and the receiver, or else buy another turntable that outputs at a higher level (they can still be had rather inexpensively, surprisingly enough!). Also, you'll probably have a ground wire coming out from your turntable as well. You'll need to hook it to a chassis screw on the amp to prevent an electrical hum from being picked up and output through your speakers.
I hope this helps, and good luck listening to your vinyl. If you deem it appropriate, I would appreciate a rating on the help I have provided. Thanks!
Aug 26, 2008 | Pioneer VSX-D412 Receiver
I lost Audio output Device No audio output when using turntable. Can hear sound with headphone, can hear sound when hooked directly to speaker. Can not get sound out of audio output. Plugged RCA cables...
turntable needs high sensitivity preamp. the output level is so low that it has to be amplified more. usual inputs of turntable are phono input. needs a high sensitive input to handle.hope this help.
Aug 08, 2008 | Kenwood KR-V7080 Receiver
Sony STR-DE597 Receiver Logo
Top Sony Audio & Video Receivers Experts
Pieter Vleeshouwers
Are you a Sony Audio and Video Receiver Expert? Answer questions, earn points and help others
