Question about U-Line Refrigerator Ice Maker
Does nothing at all.
Hello, My U-Line SS95 Ice Maker does not work at all.Makes no noise at all when turned on. This was winterized for the off season and when turned back on,nothing. Tested outlet and there is power. It's about five years old and this is the first problem. Thanks,for any help you can give, Larry
    Guru:
  • 1,524 Answers
Test the power cord where it connects to the unit.
Posted on May 11, 2009
Amana French Door Bottom Freezer Refrigerator making noise but not making ice
hello sir
if ur ice maker
Makes no ice
Jul 08, 2008 | Amana AFD2535DES French Door Refrigerator
Stand alone ice maker makes hollow cubes. Any ideas?
Clean the condensing coil. Run ice machine cleaner through the evaporator coil on a wash cycle.
Jul 07, 2009 | U-Line SS95 Stainless Steel
Frigidaire won't make ice & dispenses only about 4 oz. cold water
Water frozen in the freezer supply line - you need to thaw out the freezer. About six hours, door open, turn freezer OFF. You'll need a cooler with dry ice for your frozen food. 99% certain it'll work after that.
May 26, 2009 | Freezers
The ice maker is working alone, and makes a noise.
does it have a lever that you can lift up and turn it off since you are not using it to make ice.this will eliminate the noise which is trying to add water but you don't have the water line hooked up to it or your water solonoid is not letting water feed yhe ice maker tray. good luck,hope this works.
May 09, 2009 | Maytag MSD2756G Side by Side Refrigerator
Ice-maker problem
if the water runs constantly when you turn the water on its your valve but if it does it periodacally it probably your icemaker
Apr 29, 2009 | Maytag MSD2756G Side by Side Refrigerator
Ice maker not turned on or hooked to water line
it my be not the icemaker check fan or you can remove icemaker
Feb 18, 2009 | GE Profile PSW26P Stainless Steel Side by...
ICE MAKER NOT WORKING CORRECTLY
Hello deloreslovat
welcome,
You said ,your ice maker makes the ice but does not drop it into the bucket. It just leave it in the upright position in the ice maker device. It also seems to not be making all of the ice cubes only a portion of them.
Here are somethings to check that may cause this
The ice cubes are hollow or small
NOTE: This is an indication of low water pressure.
Water shutoff valve not fully open? Turn the water shutoff
valve fully open.
 Kink in the water source line? A kink in the line can reduce
water flow. Straighten the water source line.
 Reverse osmosis water filtration system connected to
your cold water supply? This can decrease water pressure.
See “Water Supply Requirements.”
 Questions remain regarding water pressure? Call a
licensed, qualified plumber.
Let me know if this helps.
Huuum
Oct 13, 2008 | Whirlpool GS6NBEXR Side by Side...
Ice maker stopped making ice
hi there,
sounds like the i/m is making ice. if you have ice in the bucket, it means that the only problem is the dispensor. if you have frost anywhere, the problem is with the actuator, which is the ice pladdle. you may have a broken spring or just the ice paddle need to be replaced.
Oct 03, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
U-Line Refrigerator Ice Maker Logo
105 people viewed this question
Top U-Line Refrigerators Experts
mike cooper
Dale Copeland
Dale Copeland
billconfused
Are you an U-Line Refrigerator Expert? Answer questions, earn points and help others
