If your fridge is a frost free , your evaporator fan motor is not working , this can be caused by one of three things , 1. the defrost timer is faulty. 2, the air lever is not opened enough to let the right amount of air through to the bottom and or the fan is seized inside the freezer section behind the back wall cavity 3. the door seal could be letting in air from the bottom of the door (very common) . inspect the door seal and take note if the fridge goes into defrost of not . if it just seems to stay running then the defrost timer is definitely stuffed and needs replacement
