Question about Hitachi Televison & Video
Television (rear projection) will start to power up and then shuts back off. I let it sit for a few weeks then it will work fine for months. I moved it to another room and it is doing the same thing again. Any ideas?
  • 10,515 Answers
This is the proverbial "kiss of death" for a Hitachi set.
The protection circuit is shutting the set down. The reason it comes back on after few weeks or so is because the protection circuit resets itself after a while but detects the same fault when it is ON for a few weeks.
It is the protection circuit that is causing the set to shut down. Unfortuately we don't know which of the many sections of the tv is the one causing the problem in the first place.
Since it comes on for a few seconds before shutting down it may be assumed to be a circuit that builds up slowly after the main power has come on. That would be the high voltages. Since the picture is off color that also indicates a power supply problem. So, I am going to predict the main power supply as the source of the difficutien this set.
I don't think this is a home repair unless you are skilled in electronic circuits and have at least an VOM to do some checks and measurements.
Let me know if you have a voltmeter and know how to use it.
Thanks for using Fixya.
Do rate the solution as "Fixya" if 100% satisfied.
Posted on May 11, 2009
53udx10b hitachi rear projection big screen. replaced convergence chips 2 months ago. Worked awesome. Started having power issues 3 weeks ago. Turn on - kicks right back off. Used to be able to turn...
Sounds like the problem started out with an intermittent solder connection possibly on the deflection PWB unless the power relay has a bad connection or is breaking down under load. If it is not the power relay, I would check the connections under the deflection board - paying close attention to the area from T701 and T752 including the Horizontal output Transistor for a short. You also have a possibility of defective filter capacitors causing the problem as well.
Jan 29, 2011 | Hitachi 53UDX10B 53" Rear Projection...
Our D52W198 was mfgr'd. Aug 2004. Sometimes it
A television shutting itself off may mean a few things:
  • Bad lamp (most likely the cause)
  • Overheating
  • Bad power supply
  • Bad ballast
To properly diagnose your television, i'll have to know more about the symptoms. You can start by moving the television away from any walls. This will give it better ventilation and cooler operation
Mar 26, 2010 | RCA D52W19 52" Rear Projection Television
Video is taking on a red tint which is getting worse over time
check the cable connections. look at different inputs. VGA and Component cables have the colors split, so if it's turning red, green, or blue; it's likely a cable or connector.
Dec 29, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Mitsubishi VS-45607 turns off immediately when I try to power up
STK ICS replace Both of them STK393-570 big black ICs will have STK on them Call mats for parts 1-800-628-1118
Dec 20, 2009 | Mitsubishi VS-45607 45" Rear Projection...
I have a GE model 46GW945 and it will work fine
I have a 1997, 19inch GE TV it comes on for about 10 to 15 minutes then shuts off and will not come back on until a few hours go by or so?? Anything will help Thank You
Dec 18, 2009 | GE Televison & Video
55" mitsubishi timer light flashes
I just had the same problem have you figured out how to fix the problem?
Nov 26, 2009 | Mitsubishi WS-55511 55" Rear Projection...
I have a 50 inch hitachi ultravision that has no picture or sound but power light is on
Probably a 'cold or detatched' solder joint on a component on that perticular circuit board you are 'wedging' with a plastic rod.
Apr 16, 2008 | Hitachi 43UWX10B 43" Rear Projection...
Televison shuts makes a sound and shuts off repeatedly
Probably needs an original SONY lamp instead of the "replacement" lamp you put in.
Dec 23, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
Hitachi 51F500 Shuts down during summer months
I am finding out that these sets have almost the same problems mostly going back to middle power supply broad ck all connections,then try looking for leaky caps.
Nov 08, 2007 | Hitachi 51F500 51" Rear Projection...
Televison & Video Logo
24 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
