Question about JUMP START SYSTEM
How do I know it's charging
How do I know this is charging? I don't see an indicator light. It's all plugged in ...
    New Friend:
  • 22 Answers
If you can get your hands on a volt meter attach the meter to the charger clamps, red to red and black to black, turn the volt meter to DC volts (20V scale on most) and turn on the charger. You should be reading at least 12V.
Posted on Dec 06, 2013
SOURCE:
How do you know when the battery is done charging
  1. Plug the charger into the mains, the light should come on GREEN.
  2. Now clip your battery in, the light should go to RED, indicating that the battery connected and is charging.
  3. Once the battery is fully charged, the light will go back to GREEN, indicating that the charge procedure has completed.
    Hope tis helps :)
Apr 08, 2016 | Worx Garden
I am trying to to charge panasonic lumix dmc-zx1 camera battery with it. As soon as I plugged it in showed a red light (power) on the charger. Even after inserted the camera battery the the red light on...
IF YOUR CAMERA USES AA OR AAA BATTERIES...TRY USING REGULAR BATTERIES, YOUR CAMERA BATTERIES MAY BE BAD AND NEED TO BE REPLACED.
HOPE THIS HELPS!
Aug 31, 2011 | Cameras
Package, manuel and receipt were accidentally thrown away and we don't know how to charge the radios. They work, but are running low on battery power! They have a power supply cord that you plug both...
From what I just read on the Cobra website, you may be misinterpreting the battery indicator lights:
My radio keeps showing low batteries
This may simply be a matter of misinterpreting the low-battery indicator. We use two different types of battery indicators:
  1. Battery Level Indicator: This battery indicator is always visible, and has several segments. When all the segments are lit, the batteries are full. When only the last segment is lit, the batteries are almost exhausted.
  2. Low Battery Indicator: This type is usually NOT visible. It only appears when the batteries are low, at which time it flashes on the display to warn you of a low battery condition.
Please note that when you turn on your radio it first performs a display test. Everything on the display will light up for a few seconds, including the Low Battery Indicator. This does not mean that the batteries are low. After a few seconds the display test will end, at which time the Low Battery Indicator should go away.
Here is a link to the Manual for your radio:
https://www.cobra.com/downloads/manuals/PR260WX_MANL.pdf
It is a PDF file, which requires that you have Adobe Reader or equivalent installed on your computer for it to open and display properly. If you don't have it, it can be found here (it's free!):
http://get.adobe.com/reader/
Jul 16, 2011 | Cobra microTALK PR 260-2 WX Two Way Radio
I'm borrowing a Jet 3 Ultra from the local Am. Legion for my Mom to use. They know nothing about it except they were told it had a new battery. I plug it in and all the LED's light up with the...
The batteries need charging and when you plug in the charger and the power is on the lights wil flash indicating that the charger is plugged in. Now look at the rear of the chair near where the charger cord plugs into the chair and you should see a voltmeter. With the charger plugged in the voltmeter will indicate about 5-6 amps and after charging overnight the voltmeter should be reading 0 amps. If when you plug in the charger cord and the voltmeter indicates 0 amps then I would suspect that the charger is not working or that the fuse is blown in the charger circuit. The only way to see if the batteries charge would be to borrow or find an offboard charger that will plug into the charger port located under the front of the joystick and after charging for 10-12 hours see if the battery level lights show full charge Hope this helps
Jun 25, 2011 | Pride Used Mobility Jet 3 Power Wheel...
Don't have a manual. Charging in electrical outlet at home and don;t know how long to charge for. Plug in shows a red and green lite, both on and I have been charging for over 4 hours. Comments
Most garmin nuvi satnavs take 4 hours to charge with a mains charger or a car charger. It takes 8 hours with a computer. There's a batter indicator on the screen that shows WHERE TO and VIEW MAP. It will probably only appear when the charger is disconnected if it's the same as other garmin nuvis.
You can get the manual in Adobe Reader format from http://static.garmincdn.com/pumac/nuvi680_OwnersManual.pdf
Jun 14, 2011 | Garmin Nuvi 680 GPS Receiver
Re: Battery Charger BC-45W I just purchased a Fuji JZ500 and the battery needed to be charged. When I plugged the charger into the power outlet, the indicator light (yellow) turned on but after a few...
Ok all mine had the same problem however problem has been solved! The power cord that plugs into the charger is a common cord you may have laying around the house. I switched the power cord to my charger and the dreaded blinking stopped! Its just a bad power cord to the charging unit! Hope this helps!
Dec 23, 2010 | FUJIFILM BC45W Rapid Travel Battery...
The unit suddenly stopped working; contact is plugged in but on-button does not work. No lights on, it does not seem the unit has power.
I faced a similar problem with Mine a couple of days ago.
Try these below
1. Keep the unit plugged to the wall socket (and charge). Green light (indicating charging) may not glow. It doesnt matter. Keep it on for a few hours.
2. Then try to turn on the unit.
3. If it still doesnt turn on, fold the unit and keep it aside for a few mins (say 10 mins).
4. Open it and then try to turn it on.
Mine worked with step 4.
See if this helps.
regards,
Lakshmi
Nov 21, 2010 | Altec Lansing Inmotion-IM600...
Power indicatoror
From the manual:
"Attach the barrel tip of the AC Charging Adapter to the AC Charging port of the POWER TO GO® and plug the standard two-prong plug into an appropriate, functioning 120 volt AC outlet. The red Battery Status LED indicator will flash, indicating a proper connection has been made and the unit is charging. The green Battery Status LED indicators will gradually light as the charge level rises. The POWER TO GO® must be charged for approximately 11-17 hours prior to first use. All Battery Status LED indicators will be lit solid (the red indicator will stop flashing) when the unit is fully charged.
Aug 29, 2008 | Black & Decker Power To Go Cordless AC/USB...
Charging H550
The indicator light turns red when the battery is
charging. It may take up to 1 minute for the
indicator light to turn on. When the headset's
battery is fully charged (about 2 hours), the
indicator light turns off.
Jan 09, 2008 | Motorola Mobility H550 - Bluetooth Headset...
JUMP START SYSTEM Logo
119 people viewed this question
Top Vector Vehicle Parts & Accessories Experts
Sheldon Dedek
Norman Al-Anbar
Are you a Vector Vehicle Part and Accessory Expert? Answer questions, earn points and help others
