Question about HP OfficeJet D135 All-In-One InkJet Printer
LINES DOWN THE PAGE WHEN I USE AUTO FEEDER
HI. WHEN I USE THE AUTO FEEDER--THE MECHANISM ON TOP, TO EITHER COPY OR SEND FAXES, THE RESULTS HAS  BIG LINES (STRAIGHT AND BLACK) DOWN THE PAGE. WHAT CAN I DO?
  • iasinvest
    iasinvest Jan 26, 2013
    THANK YOU - THIS PROBLEM HAS BEEN BUGGING ME FOR MONTHS!!!!
    Novelist:
  • 208 Answers
Clean all the glass on the scanner. There is a small spot on the area where the scan lamp parks when you use the feeder.
Make sure you clean the small, about 1 inch wide glass where the lamp sits.
Posted on Dec 07, 2007
Sounds like you need to do a head cleaning. go to control panel on computer and click on faxes and copiers. right click on the printer you are have problems with and there will be a head clean and nozzle check choice run through those.
Posted on Oct 13, 2007
Printing from auto feed leaving lines down side of page
if you mean making a copy from the automatic document feeder check the slit glass (the thin narrow glass beside the big platen glass) for debris, white out, dirt, etc... a small dot on that glass will make a line on the copy.
Aug 20, 2013 | Kyocera FS3140MFP AllInOne Laser Printer
UN WANTED LINE APPERS ON PRINTED PAGE WHEN PAGE
I do not know what kind of copier you have but lines (when you run thru the feeder) are usually caused by something on the glass under the feeder. If you open the top, you should see the big piece of glass and also a piece about an inch or two wide next to the big one. Look closely at the smaller glass for any spots on it. A spot will show up as a line on the copy. You can use windex to clean it.
Mar 18, 2010 | Office Equipment & Supplies
I have a Ricoh 2050L that is leaving vertical lines on copies by not transmitted faxes. How do I clean my fax or who can perform the needed service. What is a fair price in the market?
What you are saying cannot happen. When you send a fax or make a copy, you are using the same mechanism. Do you mean print outs instead of copies?
Open the doc feeder and clean the scanner glass.
Feb 10, 2010 | Ricoh 2050L Laser Fax
Lines on Outgoing Faxes and Copies from Feeder Is there a way to clean the doc feeder scanner? I have a big line going down the center of the page when I copy or fax from there. Thanks!
If you lift the top of the unit so that you can see the scanner glass and clean the surface on the left side and the very end of the scanner you should be ok. The sheet feeder runs the pages through the feeder and down to the glass at the end then back to the feeder and out to the stack of pages. If you try to scan anything with wet ink, highlighter, marker, etc some may come off on the glass and cause the lines to appear. Just use windows on a paper towel, not sprayed on the unit.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com
Dec 02, 2009 | Brother MFC-5840CN All-In-One InkJet...
Brother Intellifax 1" black line on right in send & copy modes
lift up your document feeder and check for something on the **** glass
Nov 16, 2009 | Brother IntelliFAX 4100 Laser Fax
Two lines, one on each side of copies made from feeder and faxes
Try cleaning the rollers inside the scanner including the glass inside and out with a soft damped cloth. Look also for a piece of paper, staple wires, paper clips or pencil lead jammed inside the rollers or somewhere in the corner.
Also, look for a foreign object or substance on the cold cathode tube light and clean it. Try also cleaning the mirror.
May 24, 2009 | HP Photosmart C6180 All-In-One InkJet...
Panasonic UF-490 - Two streaks down page
Either the glass is scratched or the sensor has gone bad that is used to scan the image.  Are you using a document feeder or laying it flat on the glass?  If you are laying it flat on the glass then it is most likely a sensor going bad.  If you are feeding it through the document feeder it could be that the feeder itself needs to be cleaned, or the paper path through the feeder.
If it is the sensor you will need to send it out for repair.  There may be an option to re-calibrate the scanner in the software, that may help if the sensor has just degraded and not failed.
I hope that helps.
May 02, 2009 | Panasonic PanaFax UF-490 All-In-One Laser...
Black line going down the middle of the page
lift the auto feeder and clean the scanner glass that your pages scan across -it is dirty. You can make a copy afterward and this will tell you if you have solved the problem.
Mar 05, 2009 | Brother IntelliFAX 775 Plain Paper Thermal...
MFC-9440 CN--Lines in my auto feed scanned/faxed copies
clean the thin strip of glass located under the document feeder with something non abrasive
Feb 06, 2009 | Brother MFC-9440CN Laser Printer
Faxes I send are reduced in size and have series of black line down right hand side.
If its reduced in size during transmit or copy then simply place a letter size document in the feeder and close the two sliders up to the sides of the paper. If you don't close the slider up to the paper it will go into auto reduction
Apr 27, 2007 | Canon LaserClass LC 8500 Plain Paper Fax
HP OfficeJet D135 All-In-One InkJet Printer Logo
179 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
