PICTURE TURNS BALCK WHITE WITH DVD,VHS OR SET UP BOX
I have Palladine LCD TV 32" Model no EPT3200. When connected to Cabel, there is no problem. When Connecetd to DVD, VHS or Set up box, the picture is colour less, Black white. I am in india. The TV shows PAL and SECAM color systems.
  • 4,234 Answers
Make sure that your external devices are PAL. If they are sending out the NTSC standard, the picture will be there without color as you are seeing.
Dan
Posted on May 11, 2009
Cannott get a picture on my tv from my DVD/VHS COMBO
Your DVD player should be connected to either the Yellow White Red connections on your TV set (same color to same color -- dvd OUT to tv IN )
OR it should be connected using the RF cables and connected inline AFTER the Direct TV Box....the box would block the DVD; and possibly the Direct TV Master box would apply 19 Volts to the DVD modulator....destroying the modulator.
Always OUTput to INput on the connections...
Also try with a new set of connections. make sure all the ports are ok.
Hope It's resolve all Problem,
Or
Still having Problem Then follow Us For
Tech support
Feb 07, 2014 | Televison & Video
Tying to hook-up my 1100 dvd player to tv I have the three cables white yellow and red audio out to audio in on tv. the recoder plays but no picture. is the a certain channel i should be on?
The connection should be the cable box out to the DVD in, the DVD out to the set. The DVD should have a channel select, Either 3 or 4- set it to the channel that is not used by the cable decoder. which should also have a switch for 3 or 4.
Then all you do is switch between channel 3 or channel 4 with the TV remote or by TV channel buttons. One will be cable, the other will be the DVD.
Dec 22, 2011 | Spectroniq PD-1100 DVD Player
I have a tcl lcd monitor (l1905az) and I just connected a dvd player to it. I can see the picture and the volume is on but the colour is only black and white. How do I get colour
hi; check your lcd setting if its on ntsc or auto in picture option
if its on pal setting the picture will be balck and white ,
check also your dvd player output if ntsc.
those two has to be the same video system , if you use pal player set your tv to pal,
but most common dvd player is ntsc.
Sep 05, 2011 | Televison & Video
Toshiba dvd when plugged to componet to tv picture balck and white... The picture is fine when plugged to composite or s-video... Component from sat box plugged to tv works fine too..
Sounds like either the cables you are using are bad or the component out on the dvd player is bad. Try using a different set of cables and make sure there are no loose connections on the dvd player
Aug 21, 2009 | Televison & Video
Picture is black / white
check color system of your tv set it to auto
Jun 09, 2009 | Sharp LC32AD5E 32 in. LCD TV
Picture but no sound
Best to use the a/v cables.
Your player should have output ports for audio and video, on the ports that say output, plug the cable red to red, white ot white, and yellow to yellow.
Now, the cable going the back of the TV. Your choice, input1 or input 2. Just plug red to red, white to white, and yellow to yellow.
Now press the the input button on your remote until the picture and sound appear.
Apr 09, 2009 | Emerson LC320EM9 32 in. LCD HDTV
Hooking up my DVD/VHS player to TV & Convertor box
I would just hook up the dvd/vhs player with the red,white,yellow rca cables that should of come with your unit and just go to the input on the tv to watch your dvd/vhs player. This will give you a better picture and sound while allowing you not to have to watch dvd/vhs on a channel which helps make the dvd/vhs player independent. Also if possible I would hook the converter box up with the red,white, yellow rca cables to the tv as well if your tv has more than one set of red,white,yellow plugs since it is a better connection that coax and you probably watch more tv than vhs/dvd anyway. So bottom line try to hook up both boxes red,white,yellow and watch each box on different inputs instead of like channel 3 or 4. Also to record of converter box you can run coax from converter box to dvd/vhs combo and make sure your dvd/vhs player is on tuner input or channel 3.
Nov 16, 2008 | Insignia Digital-to-Analog Converter for...
DVD in, have sound but no picture???
Initially, a couple of ideas:
  • check the cables from the DVD to the VHS to the TV (I am assuming that the sound is likewise connected to the TV and not to a home receiver system or an amplifier);
  • I am assuming again that you are using RCA and not RF, if yes pls pay special attention to the yellow RCA on both the DVD to VHS and VHS to TV;
  • diagonal roll often indicates a loose ground or a defective cable/RCA connector;
  • verify settings/configurations in all three; DVD, VHS, TV. TV should be set to AV or Video, VHS likewise to A/V INput;
  • try playing a known good VHS tape, if normal playback, problem is between DVD and VHS, if likewise no video, problem is between VHS and TV.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 13, 2008 | KLH DVD8350 DVD Player
I have connected my DVD/VCR to my Samsung 32 inc television but I get no sound
I had a strange issue yesterday too.
Our Samsung DVD/VCr all in one combo did a similar thing.
I used the HDMI cable for the DVD into the TV input labeled HDMI/DVD. That worked okay.
But the VCR part didn't work.
At one point I got sound but no picture. Using the RCA cables in the back on another input "Component 1"
I was trying to squeeze the best picture out of the player using the S-VHS cable.
I thought it did picture only, but the Plasma seems to be more picky about input sources.
I got everything to work keeping the DVD as a separate HDMI to Plasma TV feed.
The VCR was 3 RCA's Yellow (picture) red and white for stereo sound.
I then reset (toggled through the inputs to "reset" the TV.
It finally worked but I was two days mulling it over.
See if this works for you.
My TV was a Panasonic Plasma, but shouldn't matter.
Skip the S-VHS line and connect the inoputs with the TV off.
You MAy need to go into the input of set up menu on the TV (ours had a wrench as an icon) and set the Component 1 or 2 to "VCR".
Aug 04, 2008 | Samsung Televison & Video
VCR, DVD, TV Connection
first let me say that a dvd player and a dvd recorder are different. the dvd player can only play dvd while a dvd recorder can both play and record dvd that is said. what i understand from what you write is currently is - out of your tv box into your dvd player then out of your player into your tv........ ok some dvd has two connections. line one and line two if your tv box is in line one then you should plug the rca cable in line two in. then you select line two on the dvd player then plug the other end to your vcr in line out so that is out of your vcr into line two of your dvd player.(some times one of the connection is at the front of your player hidden) if your dvd player only have one connection then you would have to plug out your tv box and replace it with the vcr cable and when you finish coping your vhs tape you plug in back your tv box to your dvd player. hope i could help.......... Tracy
Apr 02, 2008 | Televison & Video
Televison & Video Logo
152 people viewed this question
Top Televison & Video Experts
Electro Med Services...
