RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
Tammy Marlow Posted on Dec 05, 2013
Reset button how to set it back to factory setting
I have a sonic TV and can't retune, because of a code lock which I don't have
If you have forgotten the code lock for your Sonic TV and cannot retune it, you may be able to reset it back to factory settings by performing a factory reset. However, please note that this will erase all custom settings and data, and revert the TV to its original state.
To perform a factory reset on your Sonic TV, follow these steps:
  1. Turn off the TV using the power button.
  2. Unplug the TV from the power outlet.
  3. Press and hold the power button on the TV for 15-20 seconds.
  4. While still holding the power button, plug the TV back into the power outlet.
  5. Continue holding the power button for another 15-20 seconds, then release the button.
  6. The TV should now reset to factory settings.
Please note that the steps may vary depending on the specific model of your Sonic TV. If you are unsure or if this method does not work, you may want to consult the instruction manual for your TV or contact the manufacturer for further assistance.
Mar 19, 2023 • Cell Phones
Netgear 26 router will not reboot after a storm
To perform a factory reset:
  1. Verify that your router's Power light is on.
  2. On the back of your router, locate the Restore Factory Settings or Reset button.
  3. Use a paper clip or similar object to press and hold the Restore Factory Settings or Reset button for seven seconds.
  4. Release the Restore Factory Settings or Reset button.
    Your router resets.
When you log in to your router again, use the default login credentials:
  • User Name: admin
  • Password: password
2answers
How to reset router SMC SMCE21011 to it's factory settings?
There suppose to be a reset button on it mainly on the back of it
How to reset to factory settings on a piranha max210 depth finder
To reset a PiranhaMAX 210 depth finder to factory settings, follow these steps:
  1. Turn off the unit by pressing and holding the power button.
  2. While holding down the "Zoom-in" and "Zoom-out" buttons on the keypad, press the power button to turn the unit back on.
  3. Release all three buttons when the unit beeps and the "PiranhaMAX" logo appears on the screen.
  4. The unit will now ask if you want to restore factory defaults. Press the "Menu" button to confirm.
  5. The unit will ask if you want to restore all settings to the factory defaults. Press the "Menu" button again to confirm.
  6. The unit will then reset all settings to the factory defaults and reboot.
Note: Resetting to factory settings will erase all user settings, including saved waypoints and custom settings, so be sure to back up any important data before resetting.
Jun 02, 2018 • Boating
I lost my romote to my roku and it got reset. how do i set it up again without the remote
Hello
Reset Roku without Remote:
Soft Reset
From Menus (Newer Models - 4, Premier, & Ultra)
1. From the Home screen, select "Settings" > "System" > "Power" > "System restart".
Using Button (Older Models)
1. Find the "Reset" button on the back or bottom of the device. Some models will require a paper-clip to press the button.
2. Press the button, then release after about one second. The device should reset successfully.
Power Pull If none of the above soft reset options work for you, you may need to disconnect the power cord for about 20 seconds, then plugging it back in.
Hard Reset
A hard reset will clear all settings from the device and reset it to factory defaults.
Via Menu (Newer Models - 4, Premier, & Ultra) If a soft reset doesn't fix your problem, a hard reset may be your only option. This will clear all data off the Roku and reset it to factory default settings.
From the Home screen, select the following depending on your device:
1. "Settings" > "System" > "Advanced system settings" > "Factory reset".
2. "Settings" > "Factory reset" > "Factory reset" > "Yes".
1. Remove all cables except the Power cord.
2. Press and hold the "Reset" button on the back or bottom of the device for about 20 seconds. Some models will require a paper clip to press the button.
3. Continue to hold the "Reset" button, then remove the Power cord from the back of the unit.
4. Release the "Reset" button, then plug all of the cords back into the device.
The Roku should factory reset, then walk you through the setup process again.
For any help Visit us: www Support Roku Com
2answers
Zoom R16 factory reset
To perform a factory reset on the Zoom R16 recorder, follow these steps:
  1. Power off the Zoom R16 by pressing and holding the [STOP] button.
  2. While holding down the [STOP] button, press and hold the [REWIND] button and the [PLAY] button.
  3. Continue holding all three buttons for about 5 seconds until the display shows "Factory Reset."
  4. Release all three buttons and the unit will automatically restart and restore all factory settings.
Note: Performing a factory reset will erase all user data and settings, so be sure to back up any important data before proceeding.
1helpful
How to restore HTC One V T320e smartphone
Performing a factory reset using hardware buttons
If you can't turn HTC One V on or access settings, you can still perform a factory reset by using the hardware buttons on HTC One V.
1. Press and hold the VOLUME DOWN button, and then press and hold the POWER button.
2. Wait for the screen with the three Android images to appear, and then release the POWER and VOLUME DOWN buttons.
3. Press VOLUME DOWN to select FACTORY RESET, and then press the POWER button.
[img title="unlock HTC ONE V hard reset forgotten password" alt="HTC ONE V hard reset" src="http://www.hard-reset.com/images/htc_one_v_hard_reset.jpg" height="350" width="180">
will remove any applications you've downloaded and installed. Be sure to back up
any data and files you want to keep before you do a factory reset.
Performing a factory reset from settings
1. Slide the Notifications panel open, and then tap Settings.
2. Tap Storage > Factory data reset.
3. Tap Reset phone, and then tap Erase everything.Performing a factory reset via settings
The most convenient way to do a factory reset is via the settings.
1. From the Home screen, press MENU, and then tap Settings.
2. Tap SD & phone storage > Factory data reset.
HTC One V not responding?
If HTC One V frozen and does not respond when you touch the screen or press the buttons, you can still restart it by press and hold the POWER button for at least 10 seconds, and then release it. HTC One V then restarts.
4helpful
2answers
My htc hd2 refuse to respond to my screen password, can you help me to do factory reset
  1. On the Home screen's Settings tab, tap Menu > All Settings > System > Clear Storage.
  2. Enter 1234.
  3. Tap YES to perform the reset, or tap NO to cancel the reset.
Performing a factory reset using phone buttons
  1. With your phone powered off, press and hold the VOLUME UP and VOLUME DOWN buttons.
  2. While holding the volume buttons, press the END/POWER button briefly and then release it.
  3. When you see a warning message on screen, release the VOLUME UP and VOLUME DOWN buttons.
  4. Press the VOLUME UP button to perform the reset, or press any other button to cancel the reset.
By the way, do remember to backup your data first before hard reset
Feb 12, 2011 • Cell Phones
I need the reset code to preform a factory reset
soft resetting :
-Back to factory settings: This should maintain your data (contacts/messages/calendar/notes etc), just returning your N97 back to all previous settings
From menu:
Settings> Phone>Phone Management>Factory Settings
hard resetting:
The traditional method won't work as the N97 doesn't have the old keypad. After you've backed up your data onto memory card/pc/ovi, turn your phone off and simultaneously press these four buttons circled in red.
  • Caps shift
  • Space bar
  • Delete button
  • On button
You'll know it's worked when you see the initial set up screen, asking country of origin.
2helpful
HOW TO RESET BACK TO FACTORY DEFAULT SETTINGS FOR CWA-854
You need to login to the router and go to the save/reload settings section.
You can reset this Wireless Access Point back to its default settings by clicking on Reset button, and then press OK button to confirm your decision. Note: you can also hold down the reset button on this Wireless Access Point’s panel for more than 10 seconds to reset its default settings back to factory default.
Please don't forget to rate me!
Thanks
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
