Question about Acer Aspire 3680 Laptop
Disable track pad when using the mouse on advent 6311
How do I disable track pad when using the mouse on the Advent 6311?
  • 400 Answers
Do you want to disable the onboard touchpad while you use an external mouse?
To do this there should be a key sequence on the laptop like Fn+ F8 (or another key) it has a mouse symbol on it.
Posted on May 11, 2009
  • Fabio May 11, 2009
    Or you can disable it from Device Manager.
    Start ,Control Panel ,System ,Dvice Manager ,click on the mouse devices and disable the onboard mouse ,click on Apply and then OK.
How do I isolate touch pad on advent laptop when using a mouse
You can, in control panel, disable the touch pad. Remember what you do because you will need to reactivate it later!
Feb 05, 2015 | Advent Computers & Internet
Advent wireless mouse
Drivers are available at advents web site.
May 25, 2014 | Advent Computers & Internet
Advent wireless mouse AMWL13 works for 30 seconds then freezes
Sorry to hear you're having that problem, Karen. I was unable to find the model # that you posted, but I DID find something for an M312 wireless mouse made by Advent:
http://www.adventcomputers.co.uk/forums/advent-printers-and-peripherals/advent-m312-wireless-optical-mouse-freezes-problem
If you look at the response to this issue, it lists everything I would've typed in here to suggest trying. Wireless peripherals are a "strange animal", in that so many different factors can influence their optimal operating condition. Hopefully something in this article can help you, and good luck! :)
Nov 07, 2013 | Computers & Internet
How to replace the keybord on an advent 9517 laptop
Advent laptops are manufactured by DSG International, which owns the names to other name-brand computers such as Acer and Hewlett-Packard.
The Advent laptop keyboard has integrated mouse touch-pad functions that allow you to move the mouse around the screen with your fingers.
Function keys at the top of the board contain alternate ways to exit and enter software applications.
Function Keys
The Advent laptop keyboards function keys are "hot keys" that act as shortcuts to applications and functions on the computer. The function keys sometimes don't work and won't carry out the function assigned to the key. This problem is considered a hardware malfunction, and the solution is to replace the keyboard or use a universal serial bus (USB) keyboard for the laptop. b> Malfunctioning Keys b> Advent keyboards are made of thin plastic. Striking the keys too hard will cause the keys to break or stick awkwardly in the housing unit that supports the keyboard. When these keys get stuck in the housing unit, a pin tool can easily set the keys back on track. If there are too many keys that get stuck or broken, you can purchase a replacement Advent keyboard and have it installed. b> Mouse Problems b> The mouse is located at the bottom of the Advent keyboard but is connected to the keyboard data strip that sends information through the keyboard unit to move the mouse on the screen. If the mouse malfunctions, check the connector under the keyboard to see if it is loose. A loose connector can cause the mouse or other keys not to function on the laptop. b> Electrical Shortage b> An electrical shortage can cause an Advent keyboard not to work properly. A shortage is when the main board of the laptop is not getting the voltage needed to efficiently operate the computer. When this happens, certain devices underperform or become inoperable. Check to see if your power supply is extremely hot or if your system heats up around the keyboard. If so, replace the electrical adapter. b> Wire Damage From Keystrokes b> The wire that is responsible for the liquid crystal display (LCD) on the Advent laptop extends from under the middle of the keyboard to the LCD display unit. This wire is unprotected and can be damaged from striking the keys over the wire. When this happens, the display will not show the correct colors or the screen will go black. To eliminate this problem, purchase a keyboard cover that fits the keys to relieve the pressure between the keyboard and video cable. b> Keyboard Drivers b> Problems have been reported with upgrades from Windows Vista to Windows 7. Windows 7 will not recognize the system drivers that operate the Advent keyboard. To get the keyboard to work, you must load the old drivers in Windows 7 Safe mode, which is used anytime there is a hardware or software discrepancy. Advent keyboard drivers can be loaded from the original restore CD, which is included with the system at the time of purchase.
http://www.laptopkeyboard.com/Guides.php/Advent/Advent Series/9517 (Black)/KBAD3
Jan 29, 2013 | Computers & Internet
Cursor freezing
Hi
It could be trouble with Motherboard or the chip under the track pad.
Try to re-install the mouse driver. and try to check.
In case if you have any trouble then do contact us here in Fixya.
Thank you
Aug 11, 2012 | Advent Computers & Internet
I have a advent 7302 laptop the usb ports do not reconise anything pluged into them and when i plug a device in the mouse pad locks the cursa
Try and re-install the USB drivers for the Mainboard, Any problems with external devices in USB ports could be due to a lack of power (or low power ) on the ports. I hope this helps point you in the right direction.
Jan 22, 2012 | Advent Computers & Internet
Mouse disabled how do i enable this device
press and hold the fn key (on the bottom left of the keyboard) then look for the mouse pad icon on the function keys at the top.......usually F9
Mar 06, 2011 | Advent Netbook
Turning mouse pad off on Advent laptop
try going to control panel and click on mouse options and see if there is something to turn it off
Jun 10, 2009 | Advent Netbook
Disable track pad when using wireless mouse?
Go to your control Panel and right click on the "mouse" selection', then go to "Device Select" . Then click on the "Disable".
May 11, 2009 | Computers & Internet
Istalling mouseb has turned off touch pad ?
This usually happens so you dont have 2 mice running at once. Unplug the new mouse and your touchpad should come back.
Mar 12, 2008 | Recoton Advent Advent Q2035A 20" TV
Acer Aspire 3680 Laptop Logo
138 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
