Question about Sony VAIO PCV-V210P PC Desktop
Video card how do you test if  the video card is working
  • Sony Master
  • 3,051 Answers
Posted on Feb 16, 2009
  • 116 Answers
Working and Working properly are 2 different things.
Unplug your pc. Let it set for 1 minute.
Plug in your pc.
Press the power button.
Does your monitor do anything?
No? Then it doesnt work
Yes? Then it works
If you get any video such as your BIOS or WIndows loading then the video card is fine.
Also, if you boot and you hear noises like:
Long Beep short Beep short Beep short Beep
(Long short short short)
Then your pc is not detecting the video card.
Posted on Oct 13, 2007
My lcd monitor become very dark
The issue you are describing may be with your video card rather than the monitors. Do you have an onboard video jack? If so, hook one of the monitors to this jack and disable the video driver for your installed vidio card. If it works, you have the answer. If you do not have an onboard card perhaps you can borrow a video card from another computer to test if it is indeed your video card or monitors. You might also try to uninstall and then reinstall the driver from your video card maker. They usually have driver downloads on the site. Lastly, you can buy a cheap video card for testing and if you discover it is your video card buy a new one.
Oct 27, 2012 | IBM 9512-hb0 - 15inch Lcd
My monotor don't switch on but my power supply seems working gooid, how can i know if my monotor is over ? tne turn on buttom don't send thegreen light please tell me abouit that my model is fujitsu...
You can test for a display by plugging another monitor or borrowed monitor. You will know exactly where the trouble if you only have the other monitor which is really working and test it to your computer. If there is a display that means your monitor is over. But if there is no display that means you have to focus on your video card or memory. You must have the small paint brush and hard eraser because you are going to clean your video card and memory pin. First you must discharge electro static by holding the computer casing chassis for about 2 minutes because computer components are very sensitive to electro static which is present in our hands or body. After discharging unscrew the video and gently slide the eraser to the pin of the video card and same with the memory then use the paint brush to remove the dirt on your video card and memory pin. Then plug again the video card and memory test for a display. If there is a display test the two monitors for making sure that the monitor is still working or need to buy a new monitor. Have a nice day.
Feb 26, 2011 | Fujitsu Siemens Premium Line 3816 FA-M 15"...
My x1650 will not start up at all has been in daily use about 8 months, was not new when I got it. was running xp but changed onto windows 7 about a week ago. is it a case of the scrap bin?
Have you already have this item tested with another board, or has already bought a replacement and tested out the new video card and it was working, if so Yes indeed this video card is history. If not, it may not be the card, and could be something eles. When you mean your x1650 does not startup, do you mean the fan isn't starting up and you are getting nothing on to the screen? or the fan is blowing but you get nothing on to the screen? If you get nothing and have not test it with another board, it may not be your video card and could be something else. But like earlier, if you have already tested or bought a replacement and is working, then yeah trash it, even on ebay, i don't think you'll be able to make a sale.
Jan 28, 2011 | ATI RADEON X1650 Graphic Card
E-machine t6212 won't boot. I actually have two e-machines that are not sending a signal to the monitor. One is a t6212. It is booting up because I can shut it down using the windows key + up arrow +...
If you get only one BEEP at boot then the computer is working..
Do you have a 2nd monitor to test with?
if it BEEPS more then once...
pull out your mem chips and test,,
If itt works them one of the mem chips are bad if not..
pull out all pci cards and test.. if it works its a bad card...
if not unplug all HD and CD roms and test.......
If not fixed yet it maybe a onboard video problem...
But IF you put a video card in b4 the problem started then your bios may have auto set it sellf to PCI/AGP mode.
Check bios setings,, look for onbord setings for the video
Feb 21, 2010 | E-Machines T6212 PC Desktop
Video freezes on hp e9105z on a random and intermittent basis Nvidia gt 120 video card
Test these three things:
1 - GPU could be overheating, can you swapp your video cards with a known working card?
2 - PSU could be bad, again try swapping with known working PSU, makes sure card is recieveing proper input power.
3 - I have seen a bad ram module do this before also, but, try reseating the RAM, run memtest86 for errors
Great testing tool, HIRENS bootCD
Oct 22, 2009 | HP Pavilion a6700f PC Desktop
Video cards are causing 3 beeps
The 3 short beeps indicates a video card memory problem.
The video card uses video RAM that is part of the video card. Try reseating the video card and if the problem is not resolved then the fault is the video card and it needs to be replaced.
Aug 30, 2009 | PC Chips (M925G) Motherboard
Are you using the onboard video or a display card adaptor?
1. If you are using the onboard video then try installing a known working PCI or AGP display card to test if the problem is onboard video or the actual motherboard.
2. If you are using a display card then try another known working display card (PCI or AGP) to test whether it's your displaycard that is faulty.
3. If it still doen't work then try removing your memory modules on the motherboard and replace them with known working memory.
4. If it still doesn't work then try removing your CPU and reinserting it again (be carefull as you do not want to damage your CPU!).
5. If it is still not working then you may need to replace your motherboard or take your PC into a repair facility.
Apr 03, 2009 | Cornerstone FIC AM37-L Socket A XP...
No color on secondary display
Dear Huzzah,
please try to re-install the software( driver) of Radeon 64mb 9550/X1050 secondary series maybe the software is crroupt, if still face the same problem then please contact to Vendour to replace this card, if this card is in warranty period.
Oct 07, 2008 | Diablotek RADEON 9550 Video Card - 64MB...
Monitor does not come on
The video card you used may work for the 2nd computer but not for the 1st because of the system requirements. They might be different simply because they are different models. check which video card is RECOMMENDED, NOT MINIMUM, and get the recommended video card.
However, if it is the right video card, then get it checked at a pc shop, like pcworld or somewhere like that and see what they think of it.
Sep 14, 2008 | Apple 64MB NVidia NV-11 Video Card for...
Monitor stays black. Says no video.
I'd try running windows in safe mode by holding down f8 at startup. If that ends up working it's probably a setting that is wrong. If all still remains black i'd look at testing another video card and monitor. Either one could be it.
May 30, 2008 | ATI RADEON X1650 Graphic Card
Sony VAIO PCV-V210P PC Desktop Logo
153 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
