Question about Sentry Fireproof Safe
S3517sentry safe need to reset
The door is open but i dont remember the combo have not used in a while i changed batteries everything works just need to know how to reset digital code
  • Anonymous Mar 26, 2014
    its a four digit safe
I bought a sentry gunsafe model#gs1459e i have the previous owners combination but i want to chnge it does anybody know how
Posted on Feb 05, 2012
  • 3 Answers
Press: Program 2x, enter a digit user-code (green led remains on), enter the 5 digit user pin (of your choice except 00000). After 5 digits entered, the green LED turns off.
Posted on Feb 02, 2010
Key pad won't work after anew battery
Electronic locks on gun safes are great when they work well. They provide us quicker access to the interior of the safe than a tumbler lock and dial set. However when you change the batteries on one of these safes you have to follow the manufacturers instructions. This is not something we are accustomed to doing for a simple battery change right? There are some safes that when you change the batteries in the combo lock...if you unplug the wire cable in the process and then don't plug that wire in until AFTER you put your fresh batteries into the unit...that you will reset that safe combo to factory default. Try the factory default for your brand of safe lock. Your owners manual (which should NOT be kept in your safe ever) will tell you what that preset number is. A lot of manufacturers use 123456 as their default number. Some use six 1s. Check the manual and try the default code.
Dec 11, 2017 | Locks & Locksmithing
Mother just past away,luckily safe was open at time,but dont know combo to keypad or we haven't found a key,how do i reset code to sentry10 gunsafe
To reset the combination on a Sentry safe, open the door of the safe, delete the existing codes, press the PROG or P key and enter the factory code. Finally, enter a new five-digit number as per individual preference, which is the new user combination.
It is always prudent to reset the combination on a Sentry safe when the door is open because it prevents the user from being locked out. To open the Sentry safe door, type the five-digit factory code given in the owner's manual. This factory code cannot be altered.
To delete the existing codes on newer models of the safe as of 2015, press the P button. Then, type the factory code and follow it up by inputting "00000" into the safe. On older models of the Sentry safe, press the PROG button and type the factory code two times.
After deleting the existing codes, press the PROG or P key and then enter the factory code once again. Within five seconds, type a new five-digit number, which is the new user code. To verify if the user code is working, retype it and then close the door of the safe. The user code is the primary code for opening the safe, and users can reset it as often as they want too
Mar 21, 2017 | We Home Security
Safe(DSW3607). Battery is working but door won't open when combination is entered. It stuck in the past but I was able to open it eventually. Now it appears as though the handle will not turn all
Internal batter is low...look for two pin points on the outside of the combo and attatch a new battery temporairly then work combo. Insert new battery when you get it open. Hope this helps Ed
Oct 02, 2012 | Sentry Fireproof Safe
I have a Sentry safe S5741. I have the electronic combo and the key. The door to the safe was locked with the door open. Now the door will not unlock to shut the door. Is there trip to reset the door? Is...
Try changing the batteries first. No the electronic combo would not be erased unless someone previously changed the combination. There is probably something causing the bolts to not retract. The lock may fail if there is any pressure on the bolts and or the door of the safe. Hopefully this information helps.
Jul 12, 2011 | Sentry Fireproof Safe
Get new combo on senry dial safe
Hi, There is only one way, and that is to send a letter with the serial number to Sentry and if the info matches who is supposed to own it, they will send you the factory default combo to open it. Good Luck!
Feb 14, 2009 | Sentry Fireproof Safe
Sentry Model 1610 Won't Open
I have a different model but I had the same problem. Called customer service and they had me push up on the handle and enter the code. That didn't work but then they had me tap the safe with a rubber mallet 5 times above the panel and 5 times to the right of the panel. That worked for me. Hope one of those works.
Oct 09, 2008 | Sentry Fireproof Safe
Nutool SF10 electronic digital safe
Open the safe door and press the s key press the I key twice then press the red button on the inside of door near the hinges. you will hear 2 long beeps. press the s key and then the red button and you will hear a beep enter your combination up to 12 numbers then press the E key your combination is now set. Best of luck
Sep 05, 2008 | Computers & Internet
here is the customer service phone number for you. I am sure they will be able to help you. 800-828-1438
Jul 02, 2008 | Sentry Fireproof Safe
Small floor safe Sentry Model 3877 electronic lock and key
This manual will answer both of your questions.
http://www.sentrysafe.com/pdfs/OwnersManuals/501664.pdf
Feb 21, 2008 | Sentry Fireproof Safe
Sentry Fireproof Safe Logo
1,029 people viewed this question
Top Sentry Home Security Experts
Jim London
Jim London
Computer Repairing
Computer Repairing
Hannah Johnson
Level 1 Expert
Are you a Sentry Home Security Expert? Answer questions, earn points and help others
