Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Water fill stops
When you start a load it begins to fill with water - then water fill stops and will not continue unless you slam lid and hit reset.  Been doing this consistatnly for week or so now.  Only solution is to raise and lower lid and hit reset...hope for best and repeat 6 or 7 times until it finally decides to complete the wash.  Help.  Thanks.
  • mkwright Nov 14, 2007
    I need to replace the lid switch on my kenmore washer. The model number is 110.20722. I have the part number for the lid switch. I just need to know step by step instructions for installing the switch. Can you please help me?
  • 5,911 Answers
Your lid switch is probably damaged or loose. Examine the lid switch on the right-hand side of the washer tub opening. There are two screws that hold the switch in place. Check to see if they are loose. In addtion, the lid should have a small plunger that depresses the switch when the lid is closed. Make sure it is intact and not broken. If the switch is tight and the plunger is intact, the switch has probably been damaged and needs to be replaced. If you have the type of washer that has no visible plunger and/or switch, the lid switch is locate in the rear on the left hand side and has a small arm attached to the lid that activates a contact when closed. Often this arm can get bent and will not engage the lid switch contacts. A simple adjustment (sometimes) can correct this. I've seen a lot of these switches where the casing on the switch separates and the contacts will not close. Slamming a washer lid is highly NOT recommended just for this very reason. The switch is an easy replacement and costs roughly $35. If youy post back with your model number I can research to find a part number for you. I will also give you step-by-step instructions on how to replace it. I hope this helps.
Posted on Nov 13, 2007
  • Jeff Rockwell
    Jeff Rockwell Nov 15, 2007
    Here ya go:
    First of all, unplug your washer. You will need to remove the console in order to get to the lid switch. I believe your washer has release tabs under the console at each front corner. Simply slide a putty knife straight in from the front at each corner and push in while lifting up. You should feel the release tabs push in and the console will pop up. Or, you may have a console that has removable end caps. They can be removed by gently prying up on the top of them from the rear on each side. You may have to use a small screwdriver for this. The caps should pop right off. Once removed, you will need to loosen a screw under each cap. Once you have the console loosned, carefully lift it up and lay it back over the rear panel of the washer in its resting position. Be careful not to damage the small plastic hinges that hold it in place. Now you will need to perform the following steps:
    1. Under the console you will find the lid switch connector. Unplug the switch from the connector.
    2. There will be two brass colored clips. You will need to remove these to remove the machine casing. Place a flat blade screwdriver straight down into the opening on top of the washer and into the groove of the clip. Push the screwdriver away from you while holding into the groove and the clip will release.
    3. Open the lid of the washer and place your hand under the front rim of the opening (DO NOT grab the wash tub). Now pull the case from the frame by lifting from the back first.
    You do not have to remove it all the way from the frame. Just enough to gain access to the switch. All there is to the switch is a couple of screws holding it in and a ground wire. It's a pretty easy repair job.
    Once you've completed your switch installation, make sure you get the case back on the frame correctly by following these steps:
    1. While looking down through the lid opening, place the front lip of the machine case UNDER the washer frame and start leaning it back onto the frame. There are four small cleats that must fit into four slots on the case or the washer will vibrate. Make sure the frame is seated properly, lean forward from the front of the washer, grasp both sides of the rear panel and pull towards the case. The rear panel should be seated and flush with the casing before inserting the retaining clips.
    2. Insert the brass-colored clips into the slot on the washer rear panel first, then push straight down into the opening on the top of the washer with some force. If you have the case seated correctly, the clips will snap back in.
    3. Make sure you plug the connector from the console back into the lid switch receptacle and close the console.
    I hope you find this helpful. If you have any questions please let me know by posting comments.
My washing machine fills up with water but does not continue the wash cycle. Sometimes when you slam the lid the washer will continue the wash cycle to the end. Other times the washer stays filled up...
Sounds like the lid safety switch is either out of adjustment, or needs replacement.
Most washers will fill with the lid open, but no continue a cycle where the drum or agitator spin, unless it senses the lid is closed.
Oct 01, 2013 | Whirlpool Washing Machines
My washer wnot agitate unless i slam lid
is the lid up during the filling process? the new washers will not agitate unless the lid is down. no need to slam the lid.. There is no pin to push the activator switch.. they are controlled with a magnet...
Jul 31, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
My Whirlpool ultimate II will fill up and then stop
The lid switch need to be replaced. You might try to lengthen the rod that pushes it down. You might try trimming lid bumpers with a razor blade to make the rod go down further.
Jun 30, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Must repeatedly slam top loading door shut for machine to start
on the inside of the lid there is a lid switch hole that a plastic tab goes down through the switch could be bad or the screws holding the switch in could be lose or broken
Mar 28, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Cycle stops...
replace the lid switch, or check the connections it might even be your pusing rod for activating the switch
Jun 17, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 22082
OL on my washing machine
May 17, 2008 | Kenmore 22062 Top Load Washer
Water fills Cycle won't start
Often the lid switch needs replacement. I can become cracked from the lid being dropped.
Nov 06, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
131 people viewed this question
Dan Webster
Dan Webster
Sal De
