Question about Husqvarna Garden
I am trying to take the engine of a husqvarna pro flex 21 how is it fixed to the pulleys
  • 4 Answers
So your trying to take the engine off a husqvarna
Posted on May 11, 2009
  • Jess_desso May 15, 2009
    by a belt or a chain
How to put belts on a husqvarna 2014 r322t awd
There are four belts on this machine, one from the engine pulley back to the gear box, one from the engine pulley forward to an intermediate stack pulley, one from the stack pulley to the deck, and one on top of the deck, which belt are you changing?
Sep 06, 2017 | Husqvarna Garden
I have a husqvarna gth2254xp. With the pto switch pulled out engage, the clutch clicks. With the engine off and the switch on the clutch is engaged, you can turn the engine by turning the pulley. With the...
I am not sure I understand the question. If the clutch is not working but you hear a clicking sound, it could be the clutch has failed. If the clutch has worn beyond the allowable tolerances, you may hear it click, but it may not be able to hold.
Mar 24, 2015 | Husqvarna Garden
Husqvarna Proflex 21 just stopped engaging the blades after bump over brick. Was working fine, on starting the next cut the engine goes well, lever works but no mower blades turn when lever lowered. T
Sounds like you have broken a shear pin in the drive pulley.
Shear pins are made to break if you hit something. Other wise it would cost a lot of money to repair the damage.
Jan 24, 2015 | Husqvarna Garden
I have a Husky YTH1542XP and am having a problem with the motion belt. I had to replace the mower belt, no problem..I figured I would replace the motion belt also it in bad shape. Following the...
This procedure should be performed with the deck removed. Removal of the PTO clutch and engine pulley should be step one. The crank bolt is 5/8ths. Be sure to unplug the clutch before you remove the bolt. Plug is at hole in chasis on right side rear of engine compartment. Lock brake. Drop the clutch and engine pulley, remove belt from engine pulley then from transaxle pulley. Remove belt from idler pulleys. Istallation is reverse of removal. Be sure the PTO clutch is seated in its retainer ( a bracket that comes down from the chassis and fits into a notch on the PTO clutch. This keeps the clutch from spinning around when engaged. It will rip the wires out if not secured properly). If you bent any belt guides to get the belt off without removing the engine pulley be sure to bend them back.
Nov 21, 2012 | Husqvarna 22 hp 42" Yard Tractor YTH22V42
Detachable shafts will not go on.
check flex shaft,inner part of the larger housing,be sure the end is not damaged.....also check flex shaft end from the engine side,may have damged coupler
May 01, 2012 | Husqvarna 128 LD Weedeater
Looking for the blade pulley belt routing diagram on a 23 hp 48" in. husqvarna
See pages 18, 19 and 21 of this manual. This model has 2 blades. I don't know your model number so could not download EXACT model manual. These diagrams and pics are very clear. Hope it helps.
http://www.husqvarna.com/ddoc/HUSO/HUSO2010_USen/HUSO2010_USen__532436505.pdf
Sep 04, 2011 | Husqvarna Garden
Serptine belt diagram
Belt Installation, Aerostar 4.0L Engine
Item Part Number Description 1 8620 Drive Belt 2 N606068 Bolt 3 10300 Generator 4 10153 Generator Mounting Bracket 5 8509 Water Pump Pulley 6 6B209 Drive Belt Tensioner 7 N800199 Screw 8 8678 Belt Idler Pulley 9 N802096 Screw 10 19703 A/C Compressor 11 2882 A/C Compressor Mounting Bracket 12 3C718 Brace 13 N806020 Bolt 14 3A674 Power Steering Pump 15 3A733 Power Steering Pump Pulley 16 N800199 Screw 17 N606572 Bolt 18 N620481 Nut 19 8501 Water Pump 20 6312 Crankshaft Pulley A - Belt Tension Check (See Specifications) B - Tighten to 40-55 Nm
(30-41 Lb-Ft) C - Tighten to 24-30 Nm
(18-23 Lb-Ft) D - Tighten to 21-29 Nm
(15-21 Lb-Ft) E - Tighten to 40-50 Nm
(30-37 Lb-Ft)
Belt Installation, Ranger and Explorer 4.0L Engine
Item Part Number Description 1 8620 Drive Belt 2 10300 Generator 3 8678 Belt Idler Pulley 4 19703 A/C Compressor 5 3A733 Power Steering Pump Pulley 6 8501 Water Pump 7 6312 Crankshaft Pulley 8 6B209 Drive Belt Tensioner 9 N806020 Bolt 10 2882 A/C Compressor Mounting Bracket 11 3A674 Power Steering Pump 12 N606572-S2 Bolt 13 N800199-S8M Bolt 14 N620481-S2 Nut 15 3C718 Brace 16 N606068 Bolt 17 10153 Generator Mounting Bracket 18 8509 Water Pump Pulley 19 N605805-S2 Bolt A - Belt Tension Check (See Specifications) B - Tighten to 21-29 Nm
(15-21 Lb-Ft) C - Tighten to 40-55 Nm
(30-41 Lb-Ft)
Belt Installation, Ranger 2.3L Engine
Item Part Number Description 1 8678 Belt Idler Pulley 2 10300 Generator 3 8509 Water Pump Pulley 4 3A733 Power Steering Pump Pulley 5 2E884 A/C Clutch Pulley 6 6312 Crankshaft Pulley
Belt Installation, Aerostar 3.0L Engine
Item Part Number Description 1 10300 Generator 2 3F671 Belt Idler Pulley 3 3A733 Power Steering Pump Pulley 4 6B209 Drive Belt Tensioner 5 6312 Crankshaft Pulley 6 8509 Water Pump Pulley 7 19703 A/C Compressor 2010&c18=modelyear&c35=wsm%2cdrive%20belt%20replacement%2cssk%2c03-05%2cremoval%20and%20installation&s=1366x768&c=32&j=1.3&v=y&k=y&bw=995&bh=405&ct=lan&hp=n&[aqe]
Mar 07, 2011 | 1995 Ford Aerostar
How do you remove tension from power steering belt
Hi Jeremy, Over here in Australia the Montero is badged as a 'Pajero'. I have a 2003 model but I presume the serpentine belt or accesory drive belt would be similar in both models and drives the power steering.
The belt most likely has an automatic tensioner as mine does. The tensioner looks like two small pulleys about 21/2" in diameter. The top one should have a square hole cutout for inserting a square peg handle to rotate the tensioner clockwise to release tension on belt.
If you can't find it - start your engine and with the hood popped rev the engine a few times. You should see the belt flexing and the tensioner will be the unit which flexes up and down to maintain the tension - all other pulleys should be rotating in a fixed position only.
Just to the right of the afore mentioned square hole is a small 1/4" hole which lines up with another hole when you rotate the tensioner clockwise to release the tension. Line up the holes and put an allen key or small screw driver through the holes to keep the tension released.
Naturally, I didn't have a square pegged hadle to lever the tensioner so I used a small gemmy or crow bar (whatever you call them in the USA) and levered between the crank pulley and the tensioner to rotate the tensioner clockwise. Be gentle and remember to remove the allen key/screw driver when you have finished.
Good Luck.
Mar 19, 2010 | 2002 Mitsubishi Montero
Husqvarna 2448 pto switch kills engine,bldes
try unplugging the pto, start the mower, then engage the pto switch. If the fuse still blows trouble is somewhere in the mowers wiring if not the ploblem lies in the pto. hope this helps
Jul 15, 2009 | Husqvarna Garden
Garden Logo
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
