Home | Cartier | 21 Chronoscaph W10125U2 Wrist Watch | Cartier Autoscaph is not...
Cartier 21 Chronoscaph W10125U2 Wrist Watch
Problem for Cartier 21 Chronoscaph W10125U2 Wrist Watch
Cartier Autoscaph is not automatic
By rsnatcher on May 11, 2009
My Cartier Autoscaph is not automatic!!! When worn on left arm is does not keep its reserve, when taken off at night it will stop. If the watch is fully wound manually and then left to automatic winding, it will keep going for four days (taken off each night) on the fifth moning it will have stopped!! The watch has been back to Cartier Belgium twice and Paris twice.. each time they say after checking that the reserve is 48 hours... I believe that the movement is at fault, that for some reason the automatic winding does not work. Recently the watch went back to Cartier again, where they replaced the movement with what they call a second generation movement (not a secondhand movement) at least I hope not! Although.... After a two week trial, the watch still stops after four days, HOWEVER if I wear it on my RIGHT arm it keeps going!!!!! In Belgium gear change is a right arm job, but even so are Cartier automatic only conceived for gear change arms??? Unfortunately the strap is most uncomfortable on this arm and of course my reflex is to look at the watchless left arm.
Anyone else having a similar problem????
Popular Solutions for Cartier 21 Chronoscaph
Questions and Unsolved Problems for Cartier 21 Chronoscaph
Do you recommend Cartier 21 Chronoscaph W10125U2 Wrist Watch?
Answer
Answer
sweep or second hand does not reset to 12 always stops 5 seconds short.
Answer
Where can I find a replacement band for my Cartier 21 Chronoscaph watch? I need to replace the... (More)
Answer
which connects to the metel bracelet. the rubber part is broken can I replace only the rubber... (More)
Answer
I just dropped my tank watch and the face broke...how much will it cost to repair?
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Cartier 21 Chronoscaph...:
Top Watch Experts
Rank: Guru Guru
Solutions: 1489
Experience: The Truth is a set of corrected errors. Erwin Schroedinger
Ask Me
Find more Watch Experts
Top Watch Repair
(800) 572-8263
Our techs have extensive training including at the...
Princeton Watches
(316) 683-3721
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
