Question about Fisher and Paykel GWL11 Top Load Washer
Loud noise when draining
I have a gw712 top loader. it makes loud noise when draining. i would appreciate any help . thx
  • DandJTech May 11, 2010
    What type of loud noise,
    clicking like tuk-tuk-tuk fast, bra wire in drain motor. hope this solves. if not please clarify noise.
  • 144 Answers
You need to tilt this machine back and remove the drain pump from under the machine and check for anything stuck in there eg a hair clip or coin etc. If there's nothing stuck in there you may need to repalce the drain pump. Cheers
Posted on May 15, 2009
Fisher & Paykel GW712 washing machine Hi Fixya ,
follow this steps and fix it. God bless you
Level
If it is shaking and not sitting flat ( should have no rock corner to corner) check the leveling legs. Make sure to tighten up the locknut after adjusting.
Timer
Sometimes a Timer will start making noises before they fail. I would highly suggest replacing the timer as soon as the noise develops. This can cause problems with your motor and other components if left alone. This is easy to identify just listen up near the console when running.
Transmission
The transmission does not usually fail but to check this on a direct drive remove the motor and rotate the inner tub and listen for noises it should be quiet. If not the transmission is expensive and you will need to evaluate wether it is worth repairing.
Motor Coupler
On direct drive machines this is a common failure and can be very noisy.
Motor
You will need to disassemble the motor to listen to the motor running. If the motor is noisy it will need replacing. On direct drive models check the motor coupler first.
Suspension Rods
The Suspension Rods support the tub under the cabinet on some models. The washer must be disassembled to access. These usually do not fail. On direct drive types there will be springs instead of suspension rods. Either usually fails but can from being overloaded.
Drain Pump
The drain pump can be the cause of noise. On belt drive types remove the belt and rotate the pump pulley it should spin freely and make no noise. If it is noisy replace. If it does not spin freely remove and inspect for obstructions if none found replace the pump. Check the impeller on the pump it should be tight and spin freely. On direct drive types remove the pump and inspect it
Jul 09, 2013 | Washing Machines
I have a problem with white depost on black clothig after final spin in my new eco top loader
it is either he detergent or limescale got to espares and but the lime scale and gunge remover
Jul 29, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
GE Top Loader 10 years old. won't drain
Timer is faulty and should be replaced.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 10, 2009 | GE WBSR3140DW Top Load Washer
Won't spin
Will it drain if it will drain your motor coupling broke inbetween the motor and transmission
Mar 30, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 series 110 washer making loud noise during final spin
Make sure all springs are still in their place tilt the machine back and look under it and you can see them. 2nd all legs must be level as well as the floor.
Dec 21, 2008 | Kenmore 24032\24036 Top Load Washer
Loud banging on spin cycle frigidare washing machine model no. fws235rft2
If this is a front loader this is a common problem. Unfortunately, it is also a very extensive project (about 8 hours). The tripod supports that attache the drum to the center spindle commonly break. The remedy is to replace both the front and rear tub, and the basket as well. It is also recommended that you replace the drain pump as well. Generally, they will cover the parts (not including the drain pump) under warranty but the labor will be a customer pay.
Oct 19, 2008 | Frigidaire Washing Machines
Fisher and Paykel GWL11 Top Load Washer Logo
388 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
marley mcelhinney
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
