Question about Sharp AL-1217 Copier
Often Flashes F5 shortly after power up and then cannot print or copy
Sharp AL-1217 flashing F5 Any assistance appreciated
  • solouk May 15, 2009
    Thank you very much for your reply.
    Is there any way to determine which of these items is faulty apart from replacing each in turn?
    New Friend:
  • 91 Answers
It is copy lamp lighting abnormality. It could be a mulfunction with copy lamp, ccd or the wire harness.
Posted on May 15, 2009
  • Budi Raharjo
    Budi Raharjo May 18, 2009
    You can test the copy lamp by entering the serviceman simulation mode no 5 sub 3, press the keys as follows:
    [Clear] [Density select] [Clear] [Density select] [5] [Start] [3] [Start]. The copy lamp should be on, if not check is there an output voltage from the copy lamp inverter pwb/pcb. The copy lamp and inverter pwb come as a single unit, if one is spoiled you should replace the whole carriage unit, this is the part code :
    1. DUNT-0276QSZZ Carriage unit ( for other countries )
    2. DUNT-0276QS11 Carriage unit ( for europe )
    There's also a wire harness connected to this pwb, check this harness connectivity.
    1. DHAI-0268QSZZ AZ C CCD-MCU harness (Other Countries)
    2. DHAI-0268QSZ1 AH N C CCD-MCU harness (Europe)
    To cancel the simulation mode, press the clear key.
I have a sharp al1217d the L1 light flashes i have no lock on cleaned all surfaces but still flashes any ideas?
Press stop key and press auto exposer key same time 2 trems power of the machine press 14 and press start key
if not solve
contact nasmamtrade@yahoo.com
088-01710 950340
Jan 24, 2010 | Sharp AL-1217 Copier
Sharp al-1631 copier wont copy
It probably the toner cartrisge is empty or if there's an error code H4, the heater lamp is spoiled
Apr 02, 2009 | Sharp AL 1631 Copier
My Sharp AL-1217 keeps flashing H4 and does not respond
This is a typical fuser lamp issue. This is usually caused by a fluctuation in current supplied to the fuser assembly when the copier is warming up.
This cannot be solved by powering off the unit nor by unplugging it!
Follow the simple steps below to correct the issue:
  1. Power on the unit.
  2. When the LED display starts flashing "H" and "4", Press C and Auto button(this is the leftmost button with the copier console facing you)
  3. Repress the C and Auto Buttons again
  4. Press the copies button until 14 appears on the LED.
  5. Then Press the BIG Blue COPY button(the rightmost button with the copier console facing you)
Hurray, that's all folks
Mar 25, 2009 | Sharp AL-1217 Copier
L1 is flashing on my copier
Hello, Please check out the following website and see if you can find your error code:  http://www.copier-help.com/copier-help/
Hope this helps. Good luck
Dec 11, 2008 | Sharp AL-1217 Copier
Sharp AL-1217
L4-1 Main motor problem
Aug 10, 2008 | Sharp AL-1217 Copier
Flashing "L1" error
A letter "L"  and a number "1"  appear alternately = The scan head locking switch is locked. Unlock the scan head locking switch.
Hope this helps. Good luck.
Jul 29, 2008 | Sharp AL-1217 Copier
AL 1217 noise when started
hi first u check with out drum and toner unit. that time also u getting noise u check main drive assembly and fuser assembly.
Jun 24, 2008 | Sharp AL-1217 Copier
Asharp AL-1631 won't print anything but a mess.
E7 is a few different things. Are there two more numbers flashing after the E7 appears?
F5 has to do with the copy lamp.
It should be looked at by a technician. It needs to be looked at for the E7 issues.
Jun 13, 2008 | Sharp AL 1631 Copier
AL-1540CS error code F5
i have al-1540cs and it if flashing H then 4
Apr 09, 2008 | Sharp AL-1540CS All-In-One Laser Printer
146 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
