I need a driver for Cipher Wave 3.5'' external harddrive
My dell laptop recognises the usb adaptor, but I can't get the hard drive to work.
  • Fabio May 11, 2010
    If you open My Computer is the harddrive there?
    Does it give an error during installation?
    Try it on another USB port.
    Problem Solver:
  • 26 Answers
Hey esteg345 i have the same problem what you should do if you using a desktop is plug it in the back usb slot. not sure about laptop leme know if this helps. B
Posted on Jul 12, 2010
Neither my desktop or laptop is able to pick up my new cypherwave 3.5 external harddrive. What do I need to do to get it working?
Posted on Nov 19, 2009
Toshiba DWC120 2TB Harddrive not recognised
Before connecting anything to an USB port you need to install the software for the device. Then you can connect it.
But when you have an old laptop it could be it can't handle the 2 TB.
First install the software that came with the drive. Then see if the laptop can handle the 2TB.
Dec 20, 2013 | Toshiba 2TB Desktop External HDD Hard...
My laptop does not recognise my external harddrive
click start control panel administration tools computer management device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
if this fails to fix the problem
type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318} And remove upper filter and lower filter.
Then restart computer then check.
Also locate the below key and make sure it's value is 3 not 4. HKLM\system\currentcontrolset\services\usbstor make sure start value is 3 not 4
if still no luck
you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap
hope this helps
Apr 26, 2012 | Seagate FreeAgent Pro 1TB External USB...
I have a brand new samsung G2 500gb (MU050DC/GB) external harddrive and I want to use it to transfer between computers (work and home). My work laptop operates Win7 and recognises the drive. I have WinXP...
A computer that is running Windows XP cannot detect a USB flash drive, an Apple iPod, or an external hard disk drive
To fix this problem, delete the UpperFilters registry value and the LowerFilters registry value. These values may cause access problems. (from Microsoft website)
http://support.microsoft.com/kb/925196#letmefixit
Jul 11, 2011 | Samsung G2 Portable External HX-MU050DC/...
My 1tb hard drive external don'tseem to be recognised.the driver is in device manger but it is not showing in my computer
First make sure usb cable connected to harddrive is working fine. try it in different usb ports. Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers. then check. Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318} And remove upper filter and lower filter.Then restart computer then check. Also locate the below key and make sure it's value is 3 not 4. HKLM\system\currentcontrolset\services\usbstor make sure start value is 3 not 4. Let me know if you need further assistance. Thanks for using FixYa
Jun 18, 2011 | Samsung S2 Portable HX MU010EA 1 TB...
Windows 7 is not recognizing and comes up as a cd drive?
then check.
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11­CE-BFC1-08002BE10318}
If your harddrive still not recognized then you need to repair your harddrive.Try your harddrive in different computer if it is not recognized on another computer then your harddrive has internal issue.
Jun 22, 2010 | Buffalo Technology 1TB DRIVESTATION COMBO...
My usb port dosnt recognise my external harddrive and i would like a driver will you tell me were i can get a driver?
For the hard drive, you need to isolate the problem first. The questions are:
1. Have you tried connecting the HD into another USB ports?
2. Have you tried using another USB cable?
3. Have you tried connecting it into another computer?
4. Did you check Disk Management of your computer while the HD was connected?
5. Do you hear a clicking noise on the HD?
6. What kind of driver do you need?
Most external hard drives are Plug-n-Play and does not require any additional driver.
Please get back to me so that I could further assist you.
Have a great day!
Sep 10, 2009 | HP Computers & Internet
WD 500gb external hard drive 'elements' not recognised by laptop
Windows 98 does not properly work with drives > approx. 130 GB. This has something to do with the FAT* being not large enough for more cluster entries.
*(FAT = File Allocation Table; this tells the computer in which clusters on the HD a file is stored. What is the FAT good for? A computer stores files on HD like a very messy person: The first next free space is used; if it is not sufficient, the second next free space and so on. This leads to fragmentation, i.e. one file may be stored on many different sections of the HD. But unlike a messy person the computer keeps good track of where he puts all the pieces; this list is the FAT.
Here's how I worked around that problem: Partitioned them so that each partition was about 125 GB. Also: Cluster size must be 32 kB; if it is smaller you get more clusters and the FAT can't handle so many.
For example I have a 500 GB hard disk that is partitioned into four 122 GB partitions (just to be on the safe side; a couple of GBs not allocated). This works trouble-free.
You might do the partitioning with Windows's FDISK, though it gives you wrong indications about partition sizes. Use percent values (e.g. ''24%'' when specifying the required partition size in FDISK.
A partitioning utility I can recommend for ease and reliability is Acronis Disk Director Suite.
Sep 07, 2009 | Western Digital Elements powered by WD 320...
Portable Harddrive - Works on Newish Lappy, not on old Thinkpad
Time to install an XP driver for your PCMCIA card.
Sep 15, 2008 | Computers & Internet
External hard disk and pcmcia cardbus
Try reinstalling the drivers for the PCMCIA card and get drivers for the external hard drive..if that doesn't work then get this here. Don't buy dell they have bad quality products.
May 20, 2008 | Dell 4-Port USB2.0 PCMCIA CardBus Card...
Open Questions:
can you please help ms drunel broussard who just received custody of 2 of her abused grandchildren in nov 2017 have a great xmas not having a home with furnishings..she no longer have stable housing ms drunels daughter and boyfriend had been abusing her children..shes a great person with such agood heart and shes struggling to keep the kids..while in moms care the kids was sleeping on the ..have very min clothing..ms drunel took her car notes monies to get the kids basic clothing and hygiene needs..shes help so many7 ppl and always been an strong person..not knowing where they would lay their heads at..i watch her go and visit ,pray for ppl in the hospital..when you ask herhow is things going shell say all will be well..but today i seen her breakdown and crying..letting the kids know she might have to let them go to foster care because she cant provide them with a stable place..to know her is to truly love her..and to see her not be able to care for them the way she cared for hewr children and other ppl children is taking a toll on her.but she keeps smiling..she really need help and an agency in jax fl where she lives told her to give them up or go to a shelter...she replied ok ..and left..doors is not opening and due to the NATURE OF THE abuse..and physical abuse these babies been through she said no..they have nothing i mean nothing for xmas...less alone shes facing losing her means of transportation to get them to and from school...counseling ...and dr.appt...PLEASE PLEASE I BEG OF YOU HELP THIS FAMILY...THANK YOU FOR YOUR TIME
Dec 14, 2017 | The Computers & Internet
Computers & Internet Logo
598 people viewed this question
David Payne
David Payne
