Question about GE GSS20IEP Side by Side Refrigerator
GE GSS20IE Ice Maker
We have a GE side by side freezer / refrig.  The ice maker quit making ice and the motor to ice maker is making  a loud noise.  We set the freezer control to 0 to shut off but it shuts off the refrig also.  We have tried to defrost the ice maker, freezer and when we turn on again, within ten minutes the noise starts up.  Help.  This was given to us, we have no warrenty on it.  It is less than a year old.  Help.
  • 473 Answers
Even though the fridge was given to you it still has a 1 yr warranty from manufacture date.  Look on the sticker inside the fridge and see if it gives the manufacture date or get the receipt from you gave it to you.  Call 1-800-905-9505 for service.  They are nationwide (US).  If you find out it is older than 1 yr then use the model # on that sticker and go to to get the correct part # for the icemaker.  Unfortunately these come as a whole unit and can't replace parts.  Once you have the correct part # I bet will find a good price on ebay for a new ice maker.  If you need help finding the part # or any other questions let me know.  If you feel I didn't help solve your problem please let me know before you rate this solution.
Posted on Oct 13, 2007
GE side by side refrigerator-freezer daily makes loud grrrrrnng noise. Sporadic. Comes from area just above ice maker. Makes no difference if I turn ice maker off. Any ideas what is causing this?
Many ice maker sporadically turn to keep ice from freezing together and becoming a solid block of ice. This would occur even if the ice maker is turned off in order to keep the ice already made from freezing. It is generally short and not that loud. I'm surprised you find it disturbing.
Jun 27, 2016 | GE Refrigerators
Samsung refrig, side by side, won't eject ice. How do I turn off the left hand light to quit ice?
How to Repair a Refrigerator Ice Maker ' HomeTips
If your ice maker doesn't make ice, check out these expert do-it-yourself ice maker repair ... W. Branner Side by side GE fridge, stopped dispensing ice both cubed and crushed. ... But now that it's cleared the motor won't run to dispense any ice (water .... Our Samsung French door ice maker is not working & is making noise.
Jan 01, 2016 | Samsung Refrigerators
GE Side by Side Refrig - loud noise behind the ice maker section Model PSS25SGMB BS
it sounds like the evaporator fan blade is hitting some ice that has built up around the blades i have seen this happen a lot on g.e. SxS lately,if you can remove the ice maker and dispenser you can see the fan blade,if you dont want to do this then shut down the refrigerator and leave freezer door open and heat it carefully with a hairdrier to speed the process up to melt this ice then restart it and the noise should be gone
Aug 30, 2012 | GE PSS25SGNBS Side by Side Refrigerator
I have a GE refrigerator model # GSH25KGMB WW. It is a side by side with an ice maker and water dispenser. We have had it for about 9 years now. The ice maker hasn't been working right for about 6 or 7...
you could have several problems.
Since you mentioned your ice maker not working right - first check to see if your ice maker is hot (be carefull it can burn you if it is hot) - it is possible for an ice maker to hang in the heat cycle of the cycle producing excessive heat in the freezer. If this is the case unplug the ice maker and/ or just replace it.
The refrigerator gets it cold from the freezer so if the freezer is not working right, you'll soon notice it in the refrigerator side.
You can also check to make sure the evaporator fan motor is running(in the freezer) and the condenser motor(at the compressor) as well.
Also check the back panel of the freezer for excessive frost build up.
Jun 30, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Periodic loud buzzing noise
Two main possibilities:
1.) If the refrigerator has an ice maker but you are not making ice, the solenoid valve will open every hour or so to allow water to fill the ice maker. That valve wears out and makes more noise as it ages. There is a metal rod/bar that can be lifted up to stop the ice maker from cycling.
The compressor and the associated starter cap may be failing and it can make odd noises when it starts back up after the defrost cycle. Time for a professional to take a look.
May 21, 2010 | GE Profile 22.2 Cu. Ft. Side-by-Side...
GE Refrigerator GSS201EPWW is making a loud noise
This is the fan motor making noise but the fan motor is probably ok. The main board supplies voltage to the motor and can cause it to make strange noises.
Feb 27, 2010 | GE GSS20IEP Side by Side Refrigerator
My GE side by side ice maker quit making ice, no water sees to be entering the unit.what do i check for?
Pour 2 / 3 cup of water into the ice maker .
If it dumps the cubes , but does not refill with water , replace the dual water valve behind the refrig . This is the piece , the wall water line connects to , on the refrig .
If it does not dump the cubes , replace the ice maker .
Oct 12, 2009 | GE Profile PSW26P Stainless Steel Side by...
Periodically throughout the day there is a loud motor noise.
you may have a fan problem or ice maker open freezer switch on the frame freezer side press it you will know were the noise comming from
Apr 06, 2009 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
GE refrig model PSH23SGPABS
The main board needs to be replaced.
May 05, 2008 | GE Refrigerators
GE GSS20IEP Side by Side Refrigerator Logo
279 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
