Question about Cell Phones
Dead Cell phone will not turn on. Battery is charged, phone did not get wet.
  • 10,515 Answers
Swap the battery, If you are sure that the battery is fine,.
Then :-
1. Corrupted Motherboard - lYou need to purchase a new motherboard for the phone which might cause you more than half the original value of the cell.
2. IC's blown out - More likely the reason - Open the cell phone. Take a voltmeter, Check for the blown Ic's or diodes.The blown out Ic's must be swelled in shape. Change that and enjoy.
Note - If you are not sure how to change Ic's, Take your cell to the nearest shop and get it done. It's a minor fix.
Thanks for using Fixya.
Posted on May 11, 2009
Keeps turning off. battery is 100% charged. never got wet
Your smart phone is a dead phone. If you got it under some sort of plan see if they will exchange it for you.
Oct 15, 2015 | LG Optimus Black Smartphone
Tip
How to dry a wet cell phone
If a cellphone ever gets wet usually its thought that the cell phone is dead but its not the case if you follow the bellow instruction in case your cell got wet:
Dry out a wet cell phone by taking out the battery and SIM card and placing all of the parts in a zip locked bag or any other plastic bag with uncooked rice for 24 to 48 hours. Avoid putting wet cell phones in the oven, as it may melt the plastic. Remember never turn your phone on before that time or if your phone is wet and its still on then remove the battery immediately that will save your phone.
on Aug 02, 2010 | Cell Phones
Wont turn on, it just vibrates non stop
Dead Battery, could have gotten wet, hook it up to a computer and see if it shows anything if not battery not holding charge.
May 24, 2015 | Cell Phones
Hello....my phone BLU Life play is completely dead now. The day before thanksgiving my phone was working perfectly find then of course. My battery. Was at 20% so I tried charging it and I notice that it...
Try using someone else's battery in your phone and/or your battery in their phone and try charging it and turning them on. If your phone turns on now, then its something wrong w/ the battery, if not... then its something wrong with your phone. Is there any possibility that it got wet? If so, take the battery out immediately (although its probably way too late after all the attempted charging), pour some rice into a small tupperware or other sealable container, snug your phone into the rice, then bury it completely in more rice and seal the container and LEAVE IT ALONE for at least a couple days. After u take it out and plug it in... go do something away from the phone for a bit... cuz it sometimes will take a while of looking like nothing is happening. I don't know what the notification light is like on that phone. But on mine, after probably 20 minutes of nothing while charging... the charging light started to flash (indicating that it is charging, but not yet ready to be turned on), once the light was solid on, turned the phone on no problem.
Nov 30, 2013 | Cell Phones
My samsung smooth got wet i let it dry but will not turn on
Wet Cell Phone
Immediately remove the phone from the water,turn off the cell phone remove the battery and SIM card. When you have driedthe cell phone by putting in a warm sunny place for several days or in front ofa warm fan heater for several hours then reassemble the phone. Hopefully itwill work properly but if does not work then it is faulty and you need a newcell phone.
Jul 08, 2012 | Samsung Cell Phones
Phone just wont switch on. seems dead
Assuming that you didn't do anything to kill the phone (drop it too much, get it wet, use it as a doorstop), it could be an issue with the connection between the battery and the phone.
  1. Remove battery.
  2. Using a normal pencil eraser, rub the gold terminals on both the battery and the phone.
  3. Rub the terminals with a cloth to remove any debris.
  4. Try turning the phone on.
If this doesn't work it may be that the battery is dead or the phone is dead. If it's the battery it can be replaced. To check if the phone or battery have gotten wet, look for a small patch of paper on the battery or the phone. Typically this paper will turn from white to pink if liquid comes in contact with it (this is how the cell phone company knows if you got your phone wet when you bring it in broken). If it is pink, most likely the phone is completely dead and not fixable.
Mar 01, 2011 | Sony Ericsson Cyber-shot C902 Cellular...
My LG-VX9200 wont turn on and the battery wont charge. I assume is the battery, its a practically new phone. It hasnt get wet either. What can it be? Thanks in advance
Before you conclude that the battery is the problem, i suggest, you get a similar charger to charge your phone first, if the similar charger charges the phone, then, ii means you are having charger problem, but if it does not charge the phone, you should be considering the idea of getting another battery to see if it will charge on your phone.
The problem can also be that, the charging port of your phone is bad, you can use your charger to charge a similar phone and see if it charges, if it does, then, the problem is either th battery or the charging port.
Check the following one after the other to detect what the problem is,
1. Try use a similar charger to charge your phone to see if it will charge.
2 Get a battery from someone that as a similar phone to test your phone to see if it will power up.
If it works with your phone, get a new battery for your phone, the one you have on it is dead and will need to be replace.
Take care.
Jul 18, 2010 | LG enV3 VX9200 Cell Phone
Nokia 6500 classic got wet now dead even after
try a new battery, you may have shorted out old one, if this doesnt work then you shorted out phone, needs to be repaired by a phone tech.
Aug 18, 2009 | Nokia 6500 Classic Cellular Phone
Charging problems
you need to take the phone to a mobile service center and have them fully service the phone for you.
Mar 31, 2008 | Sony Ericsson K610i Cellular Phone
Cell Phones Logo
60 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
