PIONEER DC-Z92 CASSETTE DECK AMPLIFIER
This unit suddenly stopped sound output to both channels - the twin cassette decks, CD, tuner and turntable all work fine - there is just no output to the speakers - i suspect the power supply unit has failed but have checked both fuses and they are OK.
suggestions?
  • hifidummy Oct 15, 2007
    1. this generalist answer doesn't really help fix the problem
    2. the machine doesn't have a fan so it has been incorrectly identified
    3. i don't think this represents value for money.
  • 752 Answers
Is this one of the units that has a ribbon cable ( looks alot like an IDE hard drive cable) that connects all the components together? It also has a squre plastic fan that protrudes slightly from the rear (by about a 16th of an inch)? If so, it's the power module which consists of 2 boards (along the fan housing). You can probably find replacements for about $70, but I wouldn't bother. They quit making new replacements several years ago and any board you get now is just a pull from old stck units.... and they fail about 2 minutes after you put them in. Pioneer knows this but still sells the defective parts.
Posted on Oct 13, 2007
  • Mitch
    Mitch Oct 15, 2007
    Ok, if it's NOT one of the units with the fan in the back then it's a discrete transistor amp model. First, make sure your "TAPE 2" monitor is not on.... If it's not and you still have no sound then try a pair of headphones in the headphone jack.... If there is sound from the headphones but not the speakers, then the amp is damaged and will have to be serviced by a repair shop. If you DON'T get sound through the headphones, then it means that either:
    a) you have something hooked up wrong (probably not--- you said it "suddenly" stopped...).
    b) the preamp is also damaged, which means it's seriously damaged!
    Report back with your findings.
SOURCE:
How do I connect this system together to get it to work?
The manual for the amplifier and all the other units are here. Use the search feature in the top right with just the model number 'AT-5210'. Getting the items in the right order helps. The turntable obviously goes on top. The Amplifier goes in the middle and all the other units connect to the amp.
Akai AM U61 Manual Stereo Integrated Amplifier HiFi Engine
Jan 14, 2016 | Audio Players & Recorders
Why has the sound / volume stopped working
It sounds like the output device may have failed. Check the manual it may explain it.
Nov 28, 2014 | Sony Audio Players & Recorders
How do I hook up a rsb11w dual tape deck to a technics sa450 receiver
Hi! This is normally relatively easy. You just connect the tuner output to the line input of the deck. Normally this is done with the amplifier where the tuner go to the tuner and the tape deck to its connections just line out to the cassette input and the cassette line out to the tape input of the amplifier
Oct 04, 2014 | Audio Players & Recorders
Again...how do you hook up these 3 items...i have no manual...a Pioneer stereo tuner control, power amplifier, double cassette deck, and speaker...pioneer model #CX-770, CT - W 770, & M - 770?
This would be easier to help you with pictures but I will give you the basics. There should be an input that is labeled either cassette deck or line in. That is where you will plug in the cassette player (that is coming from the output of the player) The cords should be red and white for left and right audio. The back of the tuner should have an output labeled something like preamp out. That will be any number of types of connectors but you should be able to find the right cables. From that output put that in the left/right channel of the amp. It may be labeled something like channel 1 channel 2 input. The speakers will go to the output to the speakers probably also labeled channel 1 and 2. If you post pictures of the backs of all of the equipment I will get more detailed.
Jul 26, 2014 | Audio Players & Recorders
I have a Technics Double Cassette Deck RS-TR212. On the rear it has Output and Input connections. Output goes off to the Amplifier. Can the Input be used to record or play from a record Turntable? I have...
your receiver has (or should have) input and output connections,, your turntable needs to be hooked to the receiver,, then with the output cables that feed your cassette player you need to go, in to out and out to in ( receiver output to the input of the tape player, and out of the tape player to the in on the receiver, while playing a record if you hit record on the tape player it will record the record, depending on the receiver it will show you the meter readings for either the in or out,, they vary
Apr 11, 2011 | Audio Players & Recorders
Blinking light on front of amplifier Technics SU-V10X
Blingking Light usually means that there is DC appearing in output stage and is protecting Connected Speakers.
It can be faulty Output Stage (Bad ICs/Transistors/Resistors/Capacitors) or Faulty Power Supply.
Working on These types of Problem is not user friendly at all.
Advising to take local Authorized Shop.
Jan 30, 2009 | Technics Audio Players & Recorders
No sound from turntable bought for our hi fi system
Most if not all turntables would need to be connected to a PHONO INput which is high impedance with a high gain pre-amplifier stage. It will not work when connected to an AUX, CD or any line level inputs. Alternately, if your amp does not have any Phono Inputs, you can feed the turntable output to a preamp which can then be connected to any any line level inputs. An example may be found here or here. Additionally, there are some turntables with a built-in preamp.
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Jan 16, 2008 | Audio Players & Recorders
1,557 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
