Question about Microsoft Windows XP Home Edition
Not opening drives
 Sir , in xp os i'm in domain administrator or domain user mod, I'm not able to open my copuer,mynet workplace, recyclebin,mydocuments. it showes acces denai please help me....
  • 116 Answers
Re: Not opening drives
You are sure your user has administrative privilages on the local machine?
Right click My Computer
Click Manage
Click Users and Groups
Open Groups
Open Administrators
Are you listed, or a group your a member of listed?
Posted on Oct 12, 2007
0 characters
3 Points
Profile locked out
YES dear your user account has been locked . if you are connect by domain so tell to IT person if you''re not so open by administrator user and and follow some step .
Right click on my computer ==> Manage > user and groups >find you user>duble click > uncheck from lock user.
Mar 30, 2014 | Microsoft Windows XP Professional
Access local disc C
You may have to remove it from the domain and deleted the object in AD. Then re-add it. You locked out all trusted domain users, and possibly including yourself.
You also try logging in locally and adding the domain account to the Administrators group. You need rights for all this, so you may have to have a domain administrator do this for you.
May 01, 2013 | Operating Systems
I could not remember passoward giving for company open how can I see the passoword given
in windows xp os u can login by administrator
for than in login screen press ctr + alt +del for 2 to 3 time screen will apear type administrator on user name and enter u will login
Feb 03, 2011 | Operating Systems
I have forgotten what my adminstrator domain password is. Is there a way to redo it or retrieve it?
The best and easiest way to reset the local or domain admin password. Reset domain password with Windows Password Rescuer Advanced. By this small software you can easily reset the domain password without lose anything and do not require any tech operation.
Get to the point, now let us see the step-by-step guide to recover domain password with Windows Password Rescuer Advanced. To recover Windows Server 2000/2003/2008 domain administrator/user password, follow four steps below:
Step 1. Download and install Windows Password Rescuer Advanced and use it to burn a Windows password recovery disk with CD/USB..
Step 2. Set the locked computer to boot from CD/DVD-ROM or USB drive.
Step 3. Boot the locked computer from Windows password recovery disk.
Step 4. Reset Windows 2008/2003/2000 local or domain administrator password by a few clicks.
Jan 24, 2011 | Microsoft Windows XP Home Edition
Cause of user profile not loading
The question is:
What causes a user profile not to be loaded in Windows domain based network?
the answer is:
there are probably 3 broad reasons for this,
1. the user corrupted their profile somehow, such as shutting down without logging off (hard power off)
2. the connection to the domain was lost ungracefully, and offline information was not copied entirely, causing a mismatch of some encrypted profile data, (effectingly corrupting again) and preventing the logon.
3. an unknown event took place between the last time the user sucessfully logged on, and this time where the profile is now not loading. this could be hardware related (faulty Hard disk), RAM parity errors( bad memory), a change to the user profile SID details on the domain controller or other domain change.
Usually the cause is not so much a problem, unless it consistantly reoccurs.
Fixing it however, in XP is fairly easy.
with an account with domain admin rights, just navigate to the UNC path "\\computername\c$\documents and settings" - note the name of the folder/user affected, and just .old their profile folder.
example, username is Philip. - you see in their c:\documents and settings\ folder the folder called Philip, rename it to philip.old or something else.
You have to ensure this is done while the user is logged off, as files in this folder will be in use otherwise. potentially useful to reboot the computer before navigating to the profile folder.
Jul 11, 2010 | Microsoft Windows XP Professional
User profile cannot be loaded on Windows domain-based network
The only way i found to stop it was to copy the profiles to a new spot and then delete the user and then remake the user and log in as the user and then log out and then copy the setting back to the user replacing the files.
If your not the administrator of the domain, contact the domain administrator, only he can give you the
relavent permissions.
Jun 14, 2010 | Microsoft Windows XP Professional SP2
Forgot my administrator passwords
Hey, Offline Nt Password can reset any users on your PC.
Use this utility to reset forgotten Win XP/Windows Server/Vista Administrator Password (or any other account).
Unzip, Burn to CD, Boot from this CD and follow on screen instructions.
Jan 08, 2009 | Microsoft Windows XP Professional With...
Changed domain, now Im locked out... NEED HELP!
Use the administrator default user to login press CTRL,ALT and DELETE type administrator for the user and hit enter
Apr 14, 2008 | Microsoft Windows XP Professional With...
Logging on to server
You need to go into administrative tools and look for group policy.
In the local computer policy
Computer Configuration
Windows Settings > security settings > Local policies > user rights assignment. In the right hand pane find the policy for "Allow log on locally" Set the user accounts for those users which are allowed to log on interactively on the server. Be careful you dont lock the administrator account out.
Use in conjunction with the "Deny logon locally policy" if you need to.
Hope this helps
Mar 22, 2008 | Microsoft Windows Server Standard 2003 for...
Forget administrator password
this is how you remove the password go to start ,control panel on the right hand side double click that and go to user account click on the icon computer administrator and that will open to a new window and you will see remove password you got to type in your current password and then go remove
Sep 07, 2007 | Microsoft Windows XP Professional With...
Microsoft Windows XP Home Edition Logo
47 people viewed this question
Top Microsoft Operating Systems Experts
Brian Sullivan
Brian Sullivan
Scott Fryer
Alex Krenvalk
Are you a Microsoft Operating System Expert? Answer questions, earn points and help others
