Question about Liebherr Refrigerators
I have a problem with liebherr ice maker, it almost 2 years i have bought it and the ice maker doesn't release the ice cubes in the ice bowl.When i test the mechanism with the test button it works ok so thw problem is in the activation of the timer may be.Can you give me some help about it?
SOURCE: no water for ice maker
make sure wire is in down position this is like the on and wire up is off
Posted on Jul 14, 2007
SOURCE: 550 Ice Maker Making Hollow cubes or Small Cubes
Hollow cubes are usually a result of lack of water supply
Posted on Jul 19, 2008
  • 2692 Answers
SOURCE: ice maker makes small cubes
Check or change the water filter, leading into the machine.
If that is not the problem ,disconnect the water lone from the machine and see if their is sufficient flow comming through the line.
Posted on Dec 25, 2008
  • 531 Answers
SOURCE: Blue substance in Liebherr ice maker cubes
flush the water on till it get clean
Posted on Mar 31, 2009
ginko
  • 19396 Answers
SOURCE: Ice Maker will not release the frozen ice cubes from tray
The icemaker use an avaporator system with an heatinc coil and a fan to release cubes.
In your case either the heating coil or the fan in the icemaker must be replaced.
parts can be purchased from partselect.com.
Posted on May 31, 2009
Help! Our ice cubes are frozen but not dumping and our tray is filling up with water fitting a solid sheet of ice. Can anyone help? Thanks
Hello;
My name is Peter. I am a retired field refrigeration technician.
It sounds like your ice maker has a bad motor module/circuit board.
It is like a control board. This module reads a temperature sensor that indicates the water is frozen and ready for harvesting the ice cubes. Then it turns on a electric heater under the ice cube mold, then turns on the motor to harvest the ice cubes. After the ice cubes are harvested, it opens the water supply solenoid valve to fill the mold with water. The ice maker needs to be replaced.
Feb 27, 2016 | Liebherr Refrigerators
Just recently, the ice maker stop dumping the ice cubes from the tray into the bin.
I believe the "tray" is supposed to get heated at end to let the ice release. Faulty "heater connection?" May need repairman diagnostic.
Jan 09, 2018 | Liebherr Refrigerators
What is the cost of the spare part ice cube tray for refrigerator liebherr CNes 5066 ?
Why not contact Liebherr or your dealer yourself? What does it help if I can buy one in Germany and can't ship it to you?
Jun 19, 2014 | Home
I have a Liebherr free standing french door frig (two freezer drawers). The plastic component that shapes the ice cubes has fallen out of the ice maker into the ice receptacle below. I don't know how to...
I don't know about this ice maker, but you could always check the Owner's Manual (either the one that came with fridge, or an online copy) for re-attachment info. That's something basic that the manual may very well cover.
Sep 18, 2013 | Liebherr CS2062 Bottom Freezer French Door...
Have a jennair refrigerator mdl#jfi2589aes took the ice cube storage box out to fill cooler, when i put it back in the ice cube maker will not dispense ice cubes to the storage box, ice maker is making...
Hi
This usually is because the drive on the ice box is not engaged,
1. Remove the ice box and empty it into a bowl
2. Replace the ice box and turn the auger (spiral metal inside) until it locks into the drive motor
3. Ensure the box is pushed back as far as it will go
4. Put ice back into ice box
5 Try dispensing ice again
This is a common problem as there are teeth on the back of the ice box that have to align with the drive motor in the back of the freezer
Hope this helps
Gordon
Apr 22, 2011 | Jenn-Air Refrigerators
I have a 13 year old refrigerator with an icemaker. I installed a water line to get water to the fridge. The hose is connected to the water main and the fridge. I am not getting any ice.
Obviously, your ice maker problem could be any number of things... Now that you have water to the ice maker, is the inlet valve opening to allow water to get to the ice maker itself? If it is, is the line that runs between the inlet valve free to allow water to get to the ice maker? if it is, is the ice maker cycling ( meaning the motor rotates the drive mechanism that times the cycle of opening the valve, rotating the mold tray then releasing the ice with a small mold release heater? An ice maker that's ~ 13 years old probably has a removable front cover so that you can see the drive gears.. Also, is the lever that senses the ice cube bin is over full in a position ( normally down) that allows th eice cube maker to cycle? Hopefully, these simple checks will help you trouble shoot the problem and get your icemaker functioning again. Hope this helps !
Aug 14, 2008 | Amana Refrigerators
Refrigerators Logo
1,298 people viewed this question
Top Liebherr Refrigerators Experts
Charles T Nevin
Charles T Nevin
Shehu Pro
Shehu Pro
Are you a Liebherr Refrigerator Expert? Answer questions, earn points and help others
