No document in the copy of canon copier NP6317
No documen apears on the copy in Canon NP6317 and also one side of the paper is coping black. this is my id if you please fix my this problem baktash_neumaticbeleive@hotmail.com
Hi my name is Muhammad Kabir from afghanistan, I had a Nashuatec iR622J Copier Machine it had a paper jam problem and it was giving erorr massage to open left cover and remove the paper but when i was opening the left cover there was not even a small piece of paper inside of them even i checked the fuser unit but there was no paper what was the problem, the problem was with the sensors that they were not placed in their place and also the electricity lines had stoped the gararies of the fuser and when i removed them and put them in their own place the paper jam problem solved...if you need any more information please contact me this is my email id baktash_neumaticbeleive@hotmail.com
Best regards,
Muhammad Kabir Barakzai
Posted on May 13, 2009
Ir3300copier machine when coping top side view is cutting print out
Same thing happen to me, so I used to keep paper little bit down. Till U get printer engineer from Canon to solve your issue, try to follow the above technique.
Apr 04, 2015 | Canon Ir 3300 Black & White Copier
Service manual canon np 6317
Hello friend, you can find the canon np6317 service manual in below link:
Canon np6317 service manual:
http://goo.gl/F1keAH
thanks
Jan 29, 2014 | Canon NP 6230 Copier
We have a Canon imageRUNNER 3230. Starting this morning, it has been printing everything off center. If you send a document to the copier for printing, it shifts the image to the left so that the far...
I would make sure that the paper guides in the paper tray are tight against the paper. And make sure the adf guides are close togather so the paper will not go in crocked Good Luck.
May 20, 2013 | Canon imageRUNNER 3230 Black and White...
Canon Pixma mx300 printer has paper jam message.
Canon Pixma MX300
- new cartrige for Black ink
- can scan
- can photocopy documents
BUT can't print documents from my MacBook eventhough the paper feeds and goes out at the other side
Aug 10, 2009 | Canon PIXMA MX300 All-in-One Printer
Continuous run when coping
The machine is trying to feed toner to the developer assy.Check if you have toner in the cartride and that the cartridge is propperly set.
Mar 29, 2009 | Canon NP 7130 Black and White Copier
I want copy from A3 (2*A4 pages) to A4 (landscape)
While coping A3 paper it result in A4 portrait not in landscape which is incomplete.How to manage it?
Feb 19, 2009 | Canon iR 2016i Black and White Copier
Canon D860 - I get a solid black line when I use paper feeder.
I'm pretty sure you might have solved this problem already, but this might help others.
Make sure that the platen glass is clean near the right side of the machine, where the document is scanned when going through the document scanner. Remember, when placing a document on the glass to copy it that way, you would place it on the glass on the left side of the machine. When scanning through the ADF, the scanning unit itself moves to the right side of glass and scans the document as it moves through.
We had the same issue and found out that there was a little spec of dirt on the glass. After cleaning it, the problem was solved.
Feb 03, 2009 | Canon ImageRUNNER 1670F Copier
Coping from Canon MP610
Unfortunately this model does not have document feeder on top. So you can only do it one sheet at a time. I think the 31ppm indicates that you can print 31 copies of one document in one minute. The models above this tend to have document feeders for this purpose but not the mp610.
Good luck.
Please rate my advice, good or bad.
Feb 01, 2008 | Canon MP610 Photo All-In-One Printer
Canon imagerunner 7130 b/w copier
Is it copying the size of a Letter paper?
If yes it's not set to Legal, go in the menu and set to Legal.
Oct 20, 2007 | Canon NP 7130 Black and White Copier
Paper shifts
Does it happen both off the copy glass & thru the document feeder or only off the document feeder. If both - check the side guides inside the cassette to make sure they are tight against the paper. If it only happens when using the feeder- the feeder tray needs to be adjusted. There is usually 2 screws under the document tray that when loosened allow for side to side adjustment. Moving the tray should solve the problem if it is only happening when you use the document feeder.
Mar 30, 2007 | Canon imageRUNNER 2000 Copier
122 people viewed this question
jasbo
jasbo
