Question about Motorola Cell Phones
How to remove face plate
I bought a new battery cover and faceplate for my phone. the battery cover is easy but the face plate requires disassembly.How do I remove the face plate on my Motorola V323?
  • 3 Answers
All i did was slip a knife blade between the silver part and where the face plate meets it. It simply pops out after aplying some upward pressure. There are a few places where the face plate has to be popped before the entire thing is free
Posted on Oct 19, 2007
How to remove a contact person in "my fave". motorola zoom 4x
Posted on Aug 01, 2008
Tighten the outside faceplate of a qwikset dead bolt.
The inside face plate snaps on. To remove it remove the T handle and use a small flat head screwdriver to genty pry it off. Behind the cover you will find 2 screws to remove the lock halves.
Don't forget to rate
Mar 12, 2009 | Kwikset Professional Door Lock...
Alpine 7835 display lights not working, everything else is fine
if it's not under warranty, I would advise taking the face plate apart and checking for burned spots on the board and using compressed air to remove anything that is conductive that may cause a short in the face plate. The face plate should be really easy to take apart.
Feb 10, 2009 | Alpine CDM-7835
Remove schlage deadbolt
Schlage B160 - need small screwdriver to insert at bottom of faceplate to pry cover off. Face plate appears flush, but with a penlight you can see the recess at the bottom to pop it off. Screws lie under the cover for disassembly. Seems to be a lock design improvement once you figure out how to remove the faceplate.
Feb 08, 2009 | Schlage B362 605 KA4 DBL CYL DEADBOLT 4 EA...
Faceplate
You can't take the faceplate off you have to buy a snap on cover. This makes the phone thicker but if you want a different look that is what you have to do. You can also buy phone stickers and decorate the front and back.
Nov 22, 2008 | Motorola Mobility RAZR V3x Cellular Phone
Need to replace faceplate for nokia 5300
Start by removing battery. Then remove the camera plastic panel. After that you will need to loosen the screws holding the faceplate in on the top. You will require a special tool for this but it can be purchased from most places that sell DIY faceplate kits.After careful prying the faceplate should come loose. Keep in mind that the screen over the LCD screen is taped on and will need to be removed separately.
Oct 24, 2008 | Cell Phones
Replacing the facepale
that hole on that model is for a locking screw, the locking screw is installed to minimize theft and for other precautions. If the face plate is having any odd reactions its normally do to the flex cable. The best sign for a dying or dead flex cable is at the joint. The joint can be viewed at the point when you remove the face plate. Immediately after pulling the face plate off look behind the pivoting frame at the orange colored ribbon, you should only be able to see a small portion of it. If there is any sign of a yellowy residue its a sign that the protective covering of the ribbon is deteriorating. A bad flex cable is everything on the moving face plates.
Sep 06, 2008 | Kenwood KDC-716S CD Player
Replace battery in a garmin
to crack the case on a garmin c550 or probably any other similar case styles is pretty easy. Facing the unit take you finger-nail (you don't need a flat screwdriver) and proceed to separate the chromish looking faceplate from the front of the unit. This is the shiny part that says 'garmin' on it. Just use your finger-nail and right above the garmin name start to work your way around the face plate and carefully remove the cover. There are 4 clip type connections that should slip out if you take your time. Once the face plate is off, remove the 4 black screws. There are 2 at the top and 2 at the bottom. Once removed separate the case and the batter is the long round thing between the speakers. I don't know what kind or type it is but at this point you can take it from here.
Jul 22, 2008 | Garmin GPS
Complete cover change
Go to my site and download the service manual for the N95. The link will be there for 1 week from today.
http://www.sunnyjersey.com/one.htm
Mar 29, 2008 | Nokia N95 Cellular Phone
KYOCERA SLIDER REMIX FACEPLATE INSTALLATION
I had the same problem and I was lookin on a forum/blog on how to do this,but not many helped.I'm about to attempt to change my faceplate and I noticed when you take the battery cover off,there are 4 screws under the cover,and one near the antenna.You probably have to take apart the back part of the phone to get to the screws that are attatched to the sliding part of the phone.Its probably a little risky and tricky,but Im guessing thats how you get to the 2 hidden screws.
Nov 20, 2007 | Cell Phones
How to change my faceplate
The face plate snaps on, unless your talking about changing the front LCD cover. Then I would take it to my local service provider store and let them do it. It's there job.
Jul 02, 2007 | LG C1500 Cellular Phone
Cell Phones Logo
489 people viewed this question
Top Motorola Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a Motorola Cell Phone Expert? Answer questions, earn points and help others
