PUTTING IT BACK TOGETHER AFTER A MOVE BUT CANT GET SOUND.
I have an old JVC MX G9 hifi radio,cassette, cd system. I am unable to get sound from a new ABBA cd and may have put the speaker wires into the wrong sockets when I tried to put the four items and two speakers together There are so many possible places to put speaker wires in - my two speakers have a black wire and a green/white wire to each one. Also I cannot get fm because I have no coax aerial. Where can I get one of these? It says 75 coax by the plug socket.
SOURCE: Sound not coming from left side surround sound speaker or my right side front speaker
it is highly likely that you're TV is outputting mono sound, hence the left channel only. check your physical connections to the TV and the balance / channel volume on the television as well.
Posted on Aug 28, 2007
SOURCE: Wish to install a pioneer cd/radio in a 89 honda civic
what can i do to install my Ipod
Posted on Sep 29, 2008
  • 5 Answers
SOURCE: no sound from back speakers
Remember the rear speakers are called surround... Did you select surround on the unit? if it says stereo then you will only get fronts, select surround to get the rest.
Posted on Dec 22, 2008
  • 11 Answers
SOURCE: installing acoustic research ar94 speakers
Appart from the wire clips what type of connectors are there? are they RCA like on a TV?
If you are driving these speakers with an external amplifier then the red and black cable clips are your safest bet.
these connections are designed to carry an amplified signal. Unlike the RCA connections which are normally Line level.
Posted on Jan 31, 2009
KMusselmann
  • 247 Answers
SOURCE: Aiwa XR-EM20 Micro System - radio will only receive MW
The loop antenna is for AM. The FM connection is just like the speaker hook up. Pull down the tab and insert the bare wire.
Hope this helps. If not let me know
Kurt
For trial purpose you and use an old electrical cord . Strip the insulation off about 1/2 in and insert it into the connections on the back
Posted on Mar 18, 2009
Speakers for Philips fwm154 stopped working
So the speakers are working but the mini hifi is not generating any sound to them. Replace the mini hifi, keep the speakers.
Dec 15, 2013 | Philips FWM154/05 MP3 Mini HiFi System
No sound on speakers, only on earphones.
Indicates to me that the headphone socket is faulty, assuming that previous to this putting a headphone jack caused the main speakers to cut off.
Not an expensive repair.
Aug 07, 2013 | JVC MX-J900 CD Shelf System
I have an old JVC stereo model number MX-D301T. There are two issues with my stereo. First, the volume wheel has stopped working. It is stuck on the highest volume setting and does not change when the...
The volume is probably controlled by an IC that does all the work. It most likely has failed. It's unlikely that the wheel is the cause of the trouble, unless it has broken leaving the circuit fully open. But I think that unlikely.
If the unit has not been used for sometime then the second fault will probably due to the belts turning to goo!
Oct 01, 2017 | JVC MX-D301T Shelf System
Have a jvc MX-J500. (purchased as a previously owned unit) When a cd is inserted in any of the three trays it just says "no Disc". Radio works as well as the cassette player. System was dusty but appeared...
You could try a CD lens cleaning disc which will clean any dust off the laser lens. But it is possible the laser power can be low if it is an old player. this will stop the discs being read fence the fault No CD as it cant see the disc. This will mean either a new laser assembly or complete CD deck. Try the cleaning disc first and if that does not work take it to a service centre or just use it as a radio cassette in the garage.
Jul 21, 2010 | JVC MX-J700 3-Disc, Triple-Tray CD Changer...
Radio will not come on
is a fatal error (these radio is micropocesor controled), needs to go to jvc repair center, they are only one who have necessary software tools to power on again.
Jan 18, 2010 | Audio Players & Recorders
Stereo
it sounds like the cd cassette is stuck, we had the same problem on a JVC unit, we had to pull it apart, remove the cd and put it back together. this did work
Jan 24, 2009 | 2000 Toyota Camry
JVC MX-J900 CD-RW
just connect the hifi to the player of your cd rw disc and put the speaker output.check it out.
Feb 19, 2008 | Audio Players & Recorders
Cassette player will not work
common fault on the JVC tape decks is the belt stretch and then it does a clicking sound its trying to pick up the audio heads. changing the belt is quite hard if you have`nt done it before.
craig:)
Sep 09, 2007 | JVC MX-J900 CD Shelf System
156 people viewed this question
 Grubhead
Grubhead
