Question about Kenmore 63942 Dryer
Kenmore Dryer stopped running
I have an old Kenmore Dryer Model # 110 86673800.  I recently had to replace the element and then about a week ago the timer quit working and we have to manually turn dryer off by opening the door.  Today my daughter forgot to turn the dryer off and left it running for about 4 hours.  The lint filter was full (we had been drying blankets) and she said that she opened the door to stop it, however when I came home to put a load of clothes in to dry the dryer will not start when you push the button.  The light does come on on the inside and I did check the breaker prior to that and both appear to be fine.  Is there a way to reset this dryer?  Where should Iook from here?
Cindy Vandiver
  • Anonymous May 13, 2008
    I'm having hte exact same problem. Timer doesn't turn the load off and it keeps running when you open the door.
  • 240 Answers
This sounds like you may have blown the thermal fuse.  If you turn the dryer around facing the back, remove the screws holding the back panel on (be sure to unplug the pigtail from the wall!!!).  When you remove the back panel, down towards the bottom, you will see a plastic piece (could be long and square, or rounded type.  Do believe it will be the long type) with 2 wires going to it.  It has a screw that holds it it.  This fuse protecs the unit and motor from excess heat and electrical issues.
THERMAL FUSE
Part Number: 3392519
Posted on Oct 14, 2007
Dryer won't heat. How can I keep troubleshooting?
You may have to get a new heating element when they go out the jet dryer where the heat comes out will not work normally this is caused buy a bad heat element. If not take back panel off and check the little white fuse and replace it, Almost all dryers are the same in that area.. Hope that helps....
May 15, 2017 | Kenmore Dryers
Kenmore Dryer
What is the model number of your unit?
Nov 26, 2012 | Kenmore Dryers
DRYER RUNS BUT NO HEAT.WHERE CAN THE FUSES BE ?MODEL NO 970-17802-20.SERIAL NO XE73210031.KENMORE
If it runs but no heat that is probably your heating element.
I recently worked on one of theses and got my grandson to snap a few photos of the repair.
417.91702000 Broken dryer belt and felt replacement
Jan 30, 2011 | Kenmore 98702 Stacked Washer/Dryer
Kenmore dryer, heat element ALWAYS on
Good day,
Sounds as if the element inside the canister has shorted to the canister body. You will have to remove the element to check it. I'll include a tutorial on how.
If that doesn't resolve the issue, please reply back.. Whirlpool makes Kenmore dryers.
Jack
http://www.applianceaid.com/wp_element.html
P.S. Look close. It doesn't take much....
Feb 01, 2010 | Dryers
My kenmore dryer stopped heating.
yes the price of fixing it is less then a new unit most of the time.
you might need new heating element or cut-off switch only.
Jan 19, 2010 | Kenmore 94702 Front Load Stacked Washer /...
Maytag Atlantis electric dryer Model
Check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Aug 08, 2009 | Dryers
How do I install the element?
you dont want to reuse the old element because it could cause more damage to the dryer if and when it shorts out
Feb 27, 2009 | Kenmore Elite HE4 Electric Dryer
Dryer not hot
Tht means that the element is not heating on.
You need to call a technician to test the element, the thermic sensor, and the control assembly.
The most likely is a defective heating element, that must be replaced.
Jan 31, 2009 | Kenmore 73952 Gas Dryer
No Heat
go to servicematters.com
Jan 15, 2009 | Kenmore 63942 Dryer
Dryer runs for minutes then stops timer keeps going and going and .....
remove the vent on the dryer that goes to the outside start the dryer if it continues to ru n and not cut off you have a venting problem of the house
if it cuts off after 5 mins with the vent off you have a motor that is going bad
Jun 11, 2008 | GE DBXR463EBWW Electric Dryer
Kenmore 63942 Dryer Logo
1,757 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
