Question about Toshiba Satellite A205-S4617 Notebook
My computer keeps turning on and off. I thought it might be an overheating problem and so i cleaned up my fan and i didn't see any change. It is not also a problem from the battery from the charger or battery because they work properly. The weird thing is my computer works properly if i put it on lap and would turn off if i put it on the floor. By the way, my computer is toshiba A205. please help!!!
  • 192 Answers
I think you were on the right track with overheating. Many laptops have more than one set of input and output air vents. Maybe you cleaned out one but missed another one. Since you said the laptop turns off when you place it on the floor I'd look for partially clogged vents on the bottom of computer. Brush away any external dust on the vents with an old toothbrush. Then try blowing air through the vent holes with one of those cans of compressed air made for dusting off keyboards. Sometimes the dust is buried inside the machine. I once worked on a Sony laptop that I had to take apart to completely clean out the vents.
Posted on May 11, 2009
Running an Acer Aspire ax5900. The video card fan vibrates loudly for the first 10 minutes of startup. I'm told I need a new video card. Area is clean and dust free. Where is the best place to find a...
Your Acer Aspire, like any other desktop computer system, contains fans inside the case to help vent the heat generated by the internal components.
These fans generally operate quietly and reliably, working in the background to prevent your computer from overheating.
A fan that sounds excessively loud could indicate a problem such as overheating or loose internal components, or it could simply be a normally loud fan.
The key to differentiating between the two involves looking for additional clues from your computer.
Normal Operation
Due to computer configuration and build quality, the fans in some desktops sound louder than others.
Depending on what other brands of computers you've owned or have had experience with, the fan in the Acer may sound louder, when it's actually functioning perfectly.
The fan will run to keep the inside of the computer from overheating, so periodic runs are normal. If the fan runs for long periods or very often, you may have a deeper problem.
Fan Damage and Overheating
A fan can sound loud due to damage, such as broken blades or to a build-up of dirt that impedes normal operation.
This dirt, as well as normal wear and usage, can wear away the lubricant coating on the fan's internal shaft, causing the blades to make excessive noise as they turn. In many cases, a loud fan indicates that the computer is overheating, causing the fan to run more often than usual to try and cool the system.
Depending on the types of components and upgrades within your Acer computer, your current fan may be too small and weak to handle the heat output, and require upgrading to a larger, more powerful fan.
Troubleshooting Take note of when the fan turns on and how long it runs to determine any distinct patterns, whether if it occurs only during certain processes or programs.
Your computer's CPU generates a large amount of heat while in operation, so programs that require large amounts of CPU usage may trigger the fan more often.
Watch for additional signs of overheating, such as sudden shutdowns or computer crashes. Check inside the case for signs of other components touching the fan and causing vibration noise.
Solution
Do not overtax the CPU by opening numerous processor-intensive programs at once.
Check that all screws, cards and wires are securely fastened and away from the fan.
Keep your computer clean inside and out, to prevent the build-up of dirt on the fan blades or air vents and minimize the threat of overheating.
Apply a drop of oil to your fan's shaft to give it proper lubrication and smooth, quiet rotation of the blades.
http://www.techrepublic.com/article/quiet-noisy-computer-fans-with-a-drop-of-oil/5034842
Aug 06, 2013 | Computers & Internet
Tip
Tips to secure your computer from overheatingTips to secure your computer from...
<span>There are some simple ways that make you aware about your problem regarding computer overheating.</span><br /> <br /><span><br /></span><br /><span>1. </span><span>The Cabinet fan and processor fan inside the system keeps the computer cool and free from dust. So keep these fans working on.</span><span><br /></span><br /><span><br /></span><br /><span>2. </span><span>Always keep your computer clean inside for stop a computer from overheating. </span><span><br /></span><br /><span><br /></span><br /><span>3. </span><span>For stop your computer from overheating always put it to sleep mode when it's not going to be in use.</span><span><br /></span><br /><span><br /></span><br /><span>4. </span><span>If you are using a laptop, you can prevent it from overheating by purchasing a cooling pad, and do not put it on a restricting surface like your pillow or bed.</span><span><br /></span><br /><span><br /></span><br /><span>5. </span><span>Always try to put your computer in cool place from preventing from overheating.</span><span><br /></span><br /><span><br /></span><br /><span>These steps will prevent your computer from overheating successfully.</span><br /><span><br /></span>
on Dec 24, 2010 | Computers & Internet
Tip
How to prevent laptop and Deskto from overheating.
overheating[overheating]"overheating""best computers""computers laptop"
First of all you need to keep your work space clean at all times so that dust and debris do not get into your unit.
Also you need to maintain airflow a routine maintenance of your machine will keep the unit in order.
If you computer is overheating first thing you do is open the case and clean out the dust.
Also you need to replace the Thermal compound under you heat sync where you cpu is.
  1. First you want to do is take off the cpu fan.
  2. Then you want to wipe the access thermal compound off.
  3. Then you apply the thermal compound by adding one dime size drop in the middle of the cpu (do not spread with fingers)
  4. Then you want to put back on your fan and heat sync.
This will keep your system at normal operating temperatures I would suggest you do this once ever 3 months at the most.
gps, home theater systems, home theater, tv repair, computer repair, laptop, repair, computer, laptops, home, computers, desktop, pc, parts,printers,refills,printhead,plunger
on Dec 02, 2009 | Computers & Internet
My 7535G is running very very hot and keeps turning off
clear the dust from the fan and heatsync... i use a hairdryer on cold and blow the fan underneeth the laptop for about 5 mins and mine stoped overheating!
Feb 28, 2011 | Acer Computers & Internet
I have an '01 Jeep Grand Cherokee that also keeps overheating when I stop but then runs fine when traveling. We do not have water mixed in the oil (we thought I had a cracked head gasket) and are told it...
Your electric fans are attached to the radiator,you would be wise to have the dealer check this out,they can access your computer and make the fans turn on with there computer,could be engine temp switch,fan relays,fan fuses,fan motors,that way your not just throwing parts at the problem
Dec 24, 2009 | 2001 Jeep Grand Cherokee
My computer turns on and off
Try moving it to another room and see what happens ,it could be interference.
also vacuum the air vents on the laptop.
It sounds like a hardware problem ,if it still has warranty then you should take it back
May 11, 2009 | Toshiba Satellite A205-S5804 Notebook
I've had a bad dust problem and my cpu fan began making a loud whirring noise and finally the computer shut down altogether. Took the cover off totally cleaned out the dust and turned the power back on....
If the computer detects overheating or fan failure it will shut down automatically. If you replace the fan you should be fine. Remove your old fan and try to get one that connects the same way, some of them connect directly to the heat sink, others to the motherboard.
Apr 16, 2009 | Sony CPU FAN CPU Fan
Cuts off unexpectively
In the control panel, there is an icon for power settings. Set the fan for maximum cooling. Make sure the exhaust ports on the computer are blown out. Don't use the computer on a soft surface.
Feb 20, 2009 | Acer Aspire 9410 Notebook
Keeps shutting down 5150inspiron
thermal shutdown.... it's overheating and you need to make sure the fan is working and clean out the dust and dirt
Robert
Jan 19, 2009 | Dell Inspiron 5150 Notebook
Overheating
have u checked and cleaned the fan a lot of lint and other debris can get inside a computer and clog up the fan canned air works great for this if fan is not working make sure that the fan's wire is still hooked up if it is and the fan is still not working you may need a new fan please keep me posted ok best regards mike
Aug 11, 2008 | ABS Computer Technologies Awesome 1300...
Toshiba Satellite A205-S4617 Notebook Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
