Question about ViewSonic VX922 19" Monitor Flat Panel
Monitor has no picture
Hello--
I have a fairly new Viewsonic 20" LCD monitor.  It's less than a year old.  We were doing some electrical work & hit the wrong breaker by accident while I had my computer running.  I rebooted & the monitor tries to start but stays black.  None of the wires or cords have been moved but I have checked them.  If I shut off the monitor, turn it back on, the blue power light comes on.  If I move the mouse & then right click I get a message "no signal analog" but that shortly disappears & it goes into sleep mode with an orange light.  I've never gotten any type of message like that before.
Is there any hope?
Christine
    Scholar:
  • 116 Answers
Yes! :)
Your monitor is not the problem. Check all the connections from the back of the monitor, to the computer.
"No Signal Analog" means your monitor is working perfectly, however is not receiving signal from the computer.
Didnt find any loose cables?
Try unplugging everything. Leave it unplugged for at least 5 minutes. You need to give the system time to drain all the excess power.
Again your monitor is fine, blue light > No signal > orange light is totally normal for your montior.
Posted on Oct 13, 2007
Tried to turn on computer today and monitor is hissing and not coming on.
wmtc348, If monitor screen is black, then most likely the problem is internal to the unit's "switchmode-power-supply/ cold-cahtode-fluorescent-lamp inverter power supply. You didn't state the "date of manufacture" from the rear of unit which is very important to give good better diagnosis. Do some reading in my (louie12fix) and (12fixlouie) Fixya profile and those of "budmrtn" and "buddymc" for more info on doing possible DIY or contracting out the repair work if unit is less than 4 years old. See if Viewsonic has a cash+old unit "swappout" program for your model. Also view some of the many DIY lcd monitor video clips that you will find on YOUTUBE to help you make "fix or trade for new" decision! DIY is $10 to $60 Contract repair is $40 to $90 depending on age and total hours of use unit has on it! Do some reading and view some videos first, before you do anything else!!! 12fixlouie
May 24, 2010 | ViewSonic VA712B 17" Flat Panel LCD...
I am using a Viewsonic VX2235WM monitor for photo editing
Hi!
Its actually normal. That normally happens to some monitor models at the 6500K setting. Try a higher one.
I hope this helps.
Jubert
May 18, 2010 | ViewSonic VX2235wm LCD Monitor
Viewsonic monitor -- VX2235wm LCD
avintagedish, Possible problem w/unit power supply. Go trade it in on new a new wide screen so the electronics technician in the repair area of the store can (with a little luck) put less than $10 in parts into your unit and maybe have a nice VX2235WM to give to his 10 year old kid to play games on. I sure hope you have a valid warranty!! You should verify that VX2235WM does same at KNOWN GOOD pc!!! Swap-in a KNOWN GOOD monitor to prove pc is OK!!! Read my FIXYA profile and learn "flashlight test" for "rude an crude" test of "switch-mode-power-supply" status. Follow the links you find there to other web sites for more info. Check to see if ViewSonic has a cash+old swapout for factory refurbished unit for premature failed units! I'm lmistyrel over on aim. and 12fixlouie on FIXYA good luck in your quest to fix unit. It can be fixed. Just do your research FIRST! So you don't get ROOKED if you contract out the work. Read, read, and read some more!! Visit YOUTUBE for video clips of LCD monitor repair and disassembly. FYI.
Bye for now.
Feb 05, 2010 | ViewSonic VX2235WM Monitor
LCD shows only Gray when turned on.
You should try VGA and/or Digital Video output.
Aug 08, 2009 | ViewSonic VG2030wm LCD Monitor
Screen flashes on then goes dark
It sounds like you have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of the monitor. If you are good at electronics repair/soldering you can usually fix the problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Aug 04, 2009 | ViewSonic VX910 19" LCD Monitor
ViewSonic VG2021m powers on, shows video for 1 second before fading to black. Power light is still on and mouse can be moved to other monitor.
It sounds like you have a monitor with a common problem. After a few years some LCD monitorswill blow a power supply. The problem is caused by parts calledcapacitors overheating in the confined space of the monitor. If you aregood at electronics repair/soldering you can usually fix the problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should workfine. The capacitors do need to be installed with the correct + and -connections, note the stripe on the old one and insert the new one thesame way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping.
Buddy
Corporate Computer
www.ccl-la.com
Jul 07, 2009 | ViewSonic VG2021m LCD Monitor
ViewSonic VG2021m - hard to wake up from sleep mode for a few weeks. Now screen flashes on for a second and goes back to black. Anyone else have this problem?
Check your connections first. Make sure your video card is not loose. See if you can ge to your setup screen. Pressing del or F1 during startup. If you can get to your startup screen with no problem, then it may be your video driver. If it still does the same thing try the monitor in another computer. If it works, it's your video card, if not it's your monitor.
Jul 06, 2009 | ViewSonic VG2021m LCD Monitor
I have 2 2006 VX910 LCD display monitors no display at all
You have a monitor with a common problem. After a few years some LCD monitorswill blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of he monitor. If you are good at electronics repair/soldering you can usually fix he problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping. I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Jul 03, 2009 | ViewSonic VX910 19" LCD Monitor
My viewsonic monitor is not working
Considering the price of monitors versus the cost of repair. It would cost less to replace the monitor.
Mar 12, 2009 | MPC Computers Viewsonic E771 17 in.CRT...
Monitor is on but disply id black
Having a similar problem.  When I turn my monitor on, the picture tries to come on, but then goes black.  After several times, I may get lucky and the picture will hold.  Is my monitor about ready to give up the ghost?  Mine is a few years old as well.
Jun 22, 2008 | ViewSonic VA520 15" Flat Panel LCD Monitor
ViewSonic VX922 19" Monitor Flat Panel Logo
601 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
