Candy Eclipse washing machine blows the circuit breaker
The machine was working fine until the house was rewired, when the old fuses were replaced with circuit breakers. Any attempt to use the machine now trips an mcb, cutting off power to all sockets.
    Scholar:
  • 43 Answers
It's possible that the current rating of the MCB is too low to run your washing machine PLUS all the devices plugged into the other sockets on the same circuit. If possible, try plugging in the washing machine on a circuit with fewer or no other appliances plugged in. MCB's are much faster tripping than circuit breakers and are rated to trip at the current rating on them. Circuit breakers, may carry a current slightly over the rated current which may be why it never happened before. The permanent solutions (if the overloaded circuit is the problem) would be to install a circuit solely for the washer and dryer or install a MCB with a higher current rating. The latter solution is not practical, however, since an overload on lower power devices may never reach the current rating of the MCB creating a hazardous shock potential.
Posted on May 11, 2009
Why does fuse blow when turn shower t warm hot ???
Probably your unspecified device has a heater incorporated and your breaker's amperage is too low for device working for hot water..
Check your electric installation.
If it's ok, your device might have a circuit problem. Check it using proper electronic testers.
Aug 09, 2015 | Washing Machines
The washing machine has stopped working and no lights come on
Hello there
If your washer doesn't seem to work at all, check these:
No power Check to see whether power is getting to the washing machine. Is it plugged in? Has a fuse blown or is a circuit breaker tripped? Lid switch If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it. Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
Aug 07, 2010 | Hotpoint Washing Machines
La9500xtw1 washer won't run. set dial, pulled out, and nothing happens. checked circuit breaker, and there is power in the outlet. where do we start with troubleshooting?
It doesn't work at all If your washer doesn't seem to work at all, check these: No power Lid switch No power Check to see whether power is getting to the washing machine. Is it plugged in? Has a fuse blown or is a circuit breaker tripped? Lid switch If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it. Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
Jan 21, 2010 | Washing Machines
My washer stopped in the middle- and wont turn back on- full of water right before the spin cycle! I have checked the breaker, unplugged it, pulled the knob and tried to recycle it- NOTHING! it is only 7...
Jan 19, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Is there a fuse or circuit breaker i can reset if 220v was put to my washing machine? i was rewiring the breaker panel and got two circuits reversed, the washing machine circuit and the water heater...
Jan 10, 2010 | Washing Machines
Candy GO1482 washing machine blows house fuse
u have an earth fault on mc caused by damp or water across the neutral check for water on electrical components
Nov 18, 2009 | Washing Machines
My washer won't turn on, I checked circuit breaker and plug. Model # MAV4758AWW
Below is information provided by www.repairclinic.com. They also provide repair parts, disassembly procedures and diagrams.
You may also find this to be of assistance;
http://maytag.custhelp.com/app/answers/list
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
No power
Lid switch
Jul 17, 2009 | Maytag Washing Machines
The washing machine doesn't come on when switched on at power point. No lights or sound at all. The fuse to the power point is all good. Machine was working fine the last wash load. Tashina
No power
Lid switch
check out this.
Jul 14, 2009 | Fisher Paykel EcoSmart GWL15
Washer will not turn on. The knob moves but nothing happens when I turn it on. I've checked the breaker, the water, the plug/outlet, and hoses. Everything looks fine. But nothing happens.
No power
Lid switch
May 05, 2009 | Whirlpool LSR9434PQ Top Load Washer
Kenmore 60 series washer
Dec 07, 2007 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
704 people viewed this question
Top Washing Machines Experts
