Question about Uniden PC78ELITE 40-Channels Base CB Radio
Power was reversed now radio keeps bowing fuse and will not come on
The power was hooked up backwards on a uniden 76xl cb can you tell me how to fix or where the pertection diod is on radio
  • 126 Answers
Most cb radios have protection diodes that are made to burn out to save the radio in this situation. Usually you can replace them with a rectier diode between 1n4004 and 1n4008. They can be purchased at Radio Shack, or if you need more stuff, you can get them from Parts Express. This unit is the same as a cobra 29. If the pc board layout and numbering is the same, then the protection diode number is D23, which is located in front of the pa speaker jack on the main pcb. If you need more help, feel free to email me at rollincbmods@yahoo.com.
Dean
Rollin CBs
Posted on Jan 26, 2008
  • 1 more comment
  • Dean Pitts
    Dean Pitts Jan 26, 2008
    Rectifier, not rectier
  • Dean Pitts
    I can possibly gain access to one of these radios, if a customer of mine still have it. If so, I will open it up and find the actual number of the diode for you.
  • Dean Pitts
    Dean Pitts Jan 27, 2008
    I opened up and looked in a 76XL today, and I was correct. It is exactly the same as a Cobra 29. The protection diode is number D23.
    Genius:
  • 1,139 Answers
Hello hubcap,
When the power was reversed this shorted out one of the components, possibly an Operational Amplifier. This tells me that there is no diode protection and possibly the circuitry is exposed directly to the input power supply. The fix would be to find the shorted component with the use of a schematic and a multimeter. Once you correct the shorted component then if possible you can add diode protection by putting a diode (forward biased direction) in the path of the positive line.
Again you will need a schematic, and a multimeter to work on this problem.
I hope this helps,
Thank you,
Shuttle83
Posted on Oct 15, 2007
I need to know ! How do I make my Maxon MCB 45W Louder ....What do i have to do in my radio to make my transmit louder....Thank you!
I know you don't want to hear this, but the Maxon radio you own, and many similar radios (Cobra 19, Midland CB-1, Midland NT-CB-1001LWX, Uniden PRO-505XL, etc) are on the bottom of the performance list. These are for those who just need a crappy radio for the summer time traveling, and about keeping the cost as low as possible. Here are a few of my favorites that have good-LOUD audio: Galaxy, Connex, General Lee, and some of the older Uniden radios like Grant XL, PC-76XL or older Cobra 29 LTD, 25 LTD models.
Please stay away from Stryker radios, Magnum radios, Northstar radios and any radio which has a NITRO-KNOB. These are ticking time bombs. In other words, they WILL fail and it wont be an easy fix either. Most Strykers and Magnums have PCB Chip failures. They are next to impossible to replace. And finally, don't be so quick to buy the pretty radio with all the flashing lights either.
Mar 21, 2013 | Radio Communications
Magnum delta force radio . while connecting my power wires in my truck i touched the the two of them together .radio went dead.what could be the problem .can i fix it myself.
You can say you hooked it up backwards,it blew the diode inside,this would be hard for you to fix without the right equipment.Please don't change the fuse in line and keep tring it because the more times you do the more chance you're giving it to take out more components.Take it to a shop and tell them what you did,It can be fix so don't let them tell you other wise.I own my own shop.
Jun 27, 2011 | Magnum DeltaForce CB Radio
Midland 38 keeps blowing fuses think maybe the polarity is reversed is this repairable
Once its been hooked up backwards you have to change your diode in the radio,please do not keeping changing the fuse all you're going to do is mess the radio up worst,take it to a shop and let them repair it,and yes it is fixable if they tell you other wise get your radio and go to another shop.
Jun 03, 2011 | Ranger Virage VX-38 Base CB Radio
When I plug in power cable it pops fuse
This radio has been hooked up backwards you have to change the resistor in the radio if you keep changing the fuses and turning it on it will do more damage to the radio there is no easy fix you have to change out the part.
Aug 12, 2010 | Cobra 29 LTD CB Radio
I have a Uniden 76xl. It was putting out about 7 watts and I added a rfx 75 kit. I used the CBTricks.com instructions for 78 series radios, to the letter. The radio was stock and everything was intact...
D8 is a polarity protection diode. you have hooked something up incorrectly. I would go over what you have done, and do not try using the radio until you fix it. If you haven't already, you are going to have to replace D8.
Mar 03, 2010 | Uniden PC78ELITE 40-Channels Base CB Radio
I have a uniden pc68ltw cb radio and it keeps blowing the 2amp in line fuse i tried a 5amp but still blows the fuse.i hooked it into another truck to test it but still blew the fuse. something wrong with...
have you been using the uniden pc68ltw cb radio without the fuse blowing before?
If the uniden pc68ltw cb radio has not been blowing fuse before, then might be a problem from the radio. This problem should be a power related problem.
The fuse blowing means there is excess of current. So while your trying to refuse, thicken the wire.
Best regards.
Feb 23, 2010 | Uniden Radio Communications
My uniden pro510xl when hooking it up imediately blows the fuse like a dead short but if i hook up another radio it will work fine
The radio was probably wired backwards at some point. There is a reverse polarity diode inside that must be replaced to fix this. If you have continued replacing fuses and plugging it back in, there may be further damage such as finals or audio amplifier chip as well. you will need to take the radio to a qualified repairman for service. If it is simply the reverse polarity diode, your bill should not be more than an hour's labor charge.
Feb 06, 2010 | Uniden PRO510XL 40-Channels Base CB Radio
I have a TRC 458 cb.... it keeps blowing fuses
It may have been reversed polarity on turn on. This can short out the polarity diode and then cause fuses to blow. This is a protection circuit so do not keep trying new fuses as the reverse surge can go into the radio deeper and damage it beyond repair.
Feb 02, 2010 | Radio Shack Radio Communications
Radio wont light up
Check the inline power fuse first/or replace it! If that does'nt work then next make sure the radio is in the operating possition on the switches labeled>cb/pa< to cb mode. If this does'nt work then you may have a wire from your power plug inside the radio broken loose or a blown diode. If in fact the wire is connected inside the radio the diode would be my next guess. This happens when the polarity of the radio is reversed(hooked up backwards). This can be fixed relativley easy at your local radio shop for about 30$. Good Luck.
Dec 18, 2008 | Cobra 29 WX NW ST 40-Channels Base CB...
It's a two way cb radio and i need to know were i can send it or take it to get it working, it'a old a motorola cb bcb97110 fcc data cb1133 warr. no 250- A103202 921 please do'nt tell me i have to fix it...
hi when you try to connect power to radio does it keep blowing fuses ,iff so remove the bottom panel/cover from the radio at the back of the radio where the power terminals enter the board you will see a black diode with a silver strip this is what we call a reversed or dummy diode remove this and your radio should work ok make sure to replace with new one you can find these in most cb radios goodlyck
Apr 16, 2008 | Superstar SS-121 120-Channels Base CB...
Uniden PC78ELITE 40-Channels Base CB Radio Logo
204 people viewed this question
Top Uniden Radio Communications Experts
Steve
eradiostore
eradiostore
Marvin
Marvin
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
