Question about Acer Aspire 5315 Notebook
Grey cable loose from monitor( lid)
Ive got a grey cable running from monitor which is loose and dont know where its from can you help. Acer aspire 5315
Hi, when iturnon my laptop (acer aspire 7720 17')
Its better to send the laptop to the manufacturer for a repair as we find it as a genuine issue with either the board or with the monitor. There could be no issue with the OS and looks like its a genuine hardware problem. Good Luck.
Mar 14, 2010 | Acer Aspire 7720 Notebook
Acer aspire 4715z monitor problem
Hello
Thank you for using
FixYa for your problem
Tricky to say without not opening it up.
Sounds like one of the wires has come loose or it can be something more. press down by the left hinge, cables come through there and by pressing you can see if it is a loose connection
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Nov 30, 2009 | Acer Aspire 5600 Series 5630-6951 Laptop
Hdmi to panasonic tv no desktop display only
I can help with getting your desktop onto your TV, but sound from your computer through HDMI can be much trickier.
If you only see a background picture on your TV, then your desktop has been either "extended" or "stretched" onto it. It is essentially a second independent monitor and you can drag applications over to it to see them.
To view your desktop and start menu on your TV, you need to run ati catalyst and "clone" your TV with your computers monitor. Do this by right clicking the picture of the second monitor in the catalyst display manager and choosing "clone". Now your tv and your monitor act as one.
Although i tried 3 different ati cards with hdmi outs that claimed to pump audio through hdmi, none of them worked for my HP PC. You will need a grey widget adaptor between your computer and the hdmi cable. In the end though, there's a conflict between my sound card and ATI's HDMI audio that cannot be resolved. So I run a digital SPDIF signal instead through an rca cable and get 5.1 dolby at my amp that way. Good luck.
Sep 20, 2009 | Acer Aspire 3000 Notebook
How do i connect my acer 5738 laptop to my tv
First of all your TV should support both HDMI and VGA.
If it does lets start with HDMI as you will get audio through the HDMI cable.
Connect the HDMI cable to the TV and set the source on the TV to HDMI using your remote control, connect the other end to the laptop, hold down Fn and hit F5 to toggle between screens.
See if that helps and let me know how you get on.
Good luck
Aug 21, 2009 | Acer Aspire 5720-6661 Notebook PC
My Aspire 3680 laptop screen cannot appear properly
Try removing the plastic above the keyboard and wobbling the cable going to the monitor. Is the backlight appearing to work at all?
Apr 23, 2009 | Acer Aspire 3680 Laptop
Acer laptop
It may be the video memory on the system board. Or it may be a loose/bad LCD cable.
Hook up an external monitor and see it it does the same on it. If it does it's the video memory, if it does not, then it is a loose cable or the LCD itself.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Apr 11, 2009 | Acer Aspire 5100 3010 Notebook
Acer Aspire 9303WSMi - 17" LCD Screen is showing coloured static..
More like the LCD Inverter Board..a loose connection would not cause that, unless you pulled the video cable by openening and closing the lid, but again that too is highly unlikely..
Jun 03, 2008 | Acer Aspire 9300 Notebook
Monitor on Acer staying gray
have you tried to the "function+8" (or the number to transfer the signal to a monitor) when you are on the laptop with grey screen?
Did you said that grey, means that there is light on the laptop, but no colors, or that tha screen is not turned on?
Jan 09, 2008 | Acer Aspire 3000 Notebook
Acer AL1916W monitor
The AL1916W's native resolution is 1440 x 900. See if your display settings can produce that resolution.
Sep 22, 2006 | Acer AL1916W 19" LCD Monitor
Acer Aspire 5315 Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
