I need to solve this problem help me please
When you install Rosetta Stone it puts its language files in a different folder. When you uninstall the program the language files are left intact and are never touched. If a problem occurs and one of the language files becomes corrupt and unreadable you're going to get that error 9119 every time when you try to re-install your language pack. Each language level has THOUSANDS of files in hundreds of sub-folders. Each file in those sub-folders has an hexadecimal name of 40 or more characters in length. So good luck trying to find the corrupt file(s). Also, because the file or files are corrupt, they can't be read or deleted. You're going to have to perform chkdsk on your hard drive to recover the bad sectors...eventually. The quickest and simplest way to fix your Rosetta Stone problem is to rename the folder where it puts its language files to something else. On an xp system the default name is "C:\Documents and Settings\All Users\Application Data\Rosetta Stone". I changed mine to "C:\Documents and Settings\All Users\Application Data\Garbage Files". That way when Rosetta Stone goes to install its language files it will recreate the folder cleanly instead of trying to overwrite the old folder and its corrupt files. That will solve your problem. You can then run chkdsk at your leisure. Good luck and spread the word.
SOURCE: When Rosetta stone installation tells me to put in
You can get the fixed file and details here:
http://support.rosettastone.com/ics/support/default.asp?deptID=14006
SOURCE: rosetta stone won't recognize my logitech headset
Make sure that your device is set as your default device by making sure that there is a green check mark next to the device. If not, right click and select "set as default device" (or something like that... I have vista and not win7)
If that does not work, right click on the headphones and go to "Properties" then go and under the "General" tab, change the name of the device to "Microphone HS" For some reason, Rosetta Stone does not recognize the headset unless it has the word "Microphone" in its name... Kinda stupid if you ask me. Hope that helps...
SOURCE: Rosetta Stone Microphone Not Found
This worked for me:
1) Right click on the Rosetta Stone icon in the Start menu
2) Click the "Compatibility" tab
3) Set it to run in compatibility mode with Windows Vista SP2 (mine was defaulted to run in XP compatibility mode, which seemed to be the problem)
4) Start the program again, if you are lucky all mics will now show up
