I need to solve this problem
When you install Rosetta Stone it puts its language files in a different folder. When you uninstall the program the language files are left intact and are never touched. If a problem occurs and one of the language files becomes corrupt and unreadable you're going to get that error 9119 every time when you try to re-install your language pack. Each language level has THOUSANDS of files in hundreds of sub-folders. Each file in those sub-folders has an hexadecimal name of 40 or more characters in length. So good luck trying to find the corrupt file(s). Also, because the file or files are corrupt, they can't be read or deleted. You're going to have to perform chkdsk on your hard drive to recover the bad sectors...eventually. The quickest and simplest way to fix your Rosetta Stone problem is to rename the folder where it puts its language files to something else. On an xp system the default name is "C:\Documents and Settings\All Users\Application Data\Rosetta Stone". I changed mine to "C:\Documents and Settings\All Users\Application Data\Garbage Files". That way when Rosetta Stone goes to install its language files it will recreate the folder cleanly instead of trying to overwrite the old folder and its corrupt files. That will solve your problem. You can then run chkdsk at your leisure and delete the Garbage Files. Good luck and spread the word.
SOURCE: Problem: Rosetta Stone msg: 1117
Try my steps:-
1.If you know removing installed programs from MAC, then please remove this application named-Rosetta Stone.
2. Now, remove all the cables & wires if your hardware audio device & turn off your computer.
3. Reconnect all the cables & wires & start your computer.
4. This time, reinstall the audio driver.
If this doesn't work, then you may try these ones:-
METHOD 1: Perform Step 1 to 3 again & install a different audio driver instead of Rosetta Stone.
METHOD 2: (This is only if METHOD 1 is also not working) Try your mic in any other MAC by installing Rosetta Stone in that system.
Note: You may search for a different audio driver at http://www.download.cnet.com/. Here search in mac column.
For any more support or any questions in future, you are the most welcome to contact me at [email protected].
