Question about Pentax *ist DL Digital Camera
Bad USB conection?
Hey there,
My camera has been working fine for me, but I just tried uploading photos onto the computer and the computer doesn´t recognize that anything is plugged in.  The camera is on, the cords are all connected...could it be that my USB cable has gone bad?
  • engella09 Oct 13, 2007
    I´ve tried it on 5 different computers and haven´t had any success.  I did test the ports with a different device, and they worked.  I´ve uploaded photos on these computers before, so that´s why I´m confused as to why suddenly I can`t...
  • 101 Answers
It's not likely the cable went bad.  Do you have more than one USB port you can try? do you have other USB devices to test the port? did you reboot?
Posted on Oct 13, 2007
Bad USB conection?
If your camera's driver is not installed, it will not work.
Make sure you go to the manufactures site, and download the correct driver there.
However, if your driver IS installed, then yes, your USB cord might have gotten bad.
Thank you.
Nov 26, 2007 | Pentax *ist DL Digital Camera
Every time I try and upload pictures onto my computer using my Nikon s4000, the pictures are extremely distorted, but look completely fine on the camera itself. I use the chord that came with the camera to...
this is a very odd problem, I have the same camera and it works fine, your best bet is to buy a usb SD memory card dongle. they are about 14 dollars, this will solve your problem with the photos, but I don't know why your camera won't work properly with the cable., have you tried it with the cable on your friends computer?
Mar 11, 2011 | Nikon Coolpix S4000 Digital Camera
I have a new computer,my finepixviewer was installed on my old one worked fine. I have down loaded my finepix Cd onto new computer. It has insalled ok but will not conect to server to down load extra...
Did you try contacting Fujifilm online support? This may be because you have not registered from the new computer to whatever program you are trying to connect. If your problem is about running the software already installed, why not consider using third-part software to download, and edit your photos. picasa for example.
Please rate fixya answers
Mar 10, 2011 | Fuji FinePix A500 Digital Camera
Bad USB conection?
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Feb 11, 2009 | Pentax K100D Digital Camera
Uploading pictures
I use a standalone cardreader, that i plug via USB to my computer. This solution works very fine.
Feb 29, 2008 | Canon PowerShot S500 IXUS 500 Digital...
Bad USB conection?
I assume that you are using Win.XP,
- did you check; System Properties>Hardware>Device Manager
Is there anything like yellow exclamation etc, especially on the USB section?
- Is it BIOS USB function enabled? Maybe disabled by accidentally.
- You said nothing working through USB, all ports are same?
If this ocurred all of a sudden, than I think you have a software problem.
I have a K100d, its been seven months now and ~6500 photo. My USB cables&fittings are fine, I always using USB port to transfer photos, no problem at all.
I hope your problem will be solved in a short time.
Sincerely
-halotheracer-
Feb 05, 2008 | Pentax K100D Digital Camera
Sony cybershot
Hi cozzyalice,
I may have a solution on uploading your photos.try to re-install your digital camera softwere drivers. that will let your computer identify the usb.
Jan 16, 2008 | Sony Cybershot S650 Digital Camera
Is the problem occuring in the USB, Memory Card or the Camera?
hello, i have the same camera, the LCD is not bright i can barely see the LCD, any of you have any idea how to fix it wihtout having to send it back to warranty? i checked al the settings and they are right the LCD should be working well.
i will really appreciate your help.
Dec 26, 2007 | Sony Cyber-Shot DSC-T5 Digital Camera
Uploading images to laptop
By default, Windows uses a 32bit FAT when formatting which is NOT compatible with most cameras. I'd suggest sticking to using the camera menus for formatting a card, unless the camera can't format one (then, if you must use a PC for formatting, make SURE you select FAT as the File System Type). I'd also recommending formatting again with the camera menus before using a card if you ever do need to format one with a PC. As for your problem with the laptop seeing the card, it could be any number of things. It's more likely related to the USB drivers. Many users report intermittent problems with USB connectivity after upgrading to SP2. A frequent solution that sometimes works is removing all devices drivers related to USB (My Computer, Properties, Hardware, Device Manager). Then, rebooting and letting Windows find and reinstall the drivers again. Sometimes, updating these drivers can work, too. You may also be seeing a conflict between other USB devices and drivers. For example, sometimes HP Printer Monitor software conflicts with USB connectivity to other devices. You may also want to try a different USB Port. If all else fails, consider a Card Reader (they're very inexpensive now -- you can probably pick up a USB 2.0 card reader for around $20.00 locally). With a laptop, you may also want to consider a PCMCIA based reader.
Sep 12, 2005 | Samsung Digimax V4 Digital Camera
Pentax *ist DL Digital Camera Logo
147 people viewed this question
Top Pentax Cameras Experts
mohamed salim shaikh
Jerry Greenberg
Jerry Greenberg
Are you a Pentax Camera Expert? Answer questions, earn points and help others
