Question about Whirlpool RF315 Dual Fuel (Electric and Gas) Kitchen Range
F2 Error on Whirlpool Dual Fuel Range
I'm not sure what the model type or number is, but I have a dual fuel range by whirlpool. Stove top is gas, oven is electric, controls for oven and timer/clock is on the top panel. Any time the machine comes on, it gives "F2" error message and beeps incessantly. I don't know what it means or what to do. We bought it without a manual. Have unplugged and replugged numerous times, even left it unplugged overnight, and still isn't fixed. Help!
  • brennanparke
    brennanparke Jan 27, 2013
    did you ever find resolution to this? Our stove is doing the same thing.
I was baking and the stove suddenly changed to Maxi Broil and then to ERR F2EO Stuck Key. I cannot seem to change it by start or off or even turning the unit off and then back on. Any suggestions? Thanks.
Posted on May 29, 2009
HI, a mouse has eaten the insulation between the ovens, can this be replaced?
Yes. Use your model number and call a parts supplier, they can help you find the right piece of insulation... Range Stove Oven Insulation WPW10208653
May 13, 2016 | Rangemaster 110 (Dual Fuel) Dual Fuel...
F9 error code while cleaning oven
F9 = oven door lock failure
Check wiring to door lock switch (the wire harness may be connected wrong). Check for stuck lock switch. If that looks good, replace the lock. What is the complete model number? Look in the oven door area.
Feb 14, 2013 | Whirlpool SF315 Dual Fuel (Electric and...
My oven when turned on goes to F1 and the heat is like broil...only the top burner comes on????
Hello,Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacement of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper)
F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
F1-E0 EPROM Error - Electronic Range Control (ERC).
F1-E1 EPROM Error - Electronic Range Control (ERC).
F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
“9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire)
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal check sum error.
Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
Thanks
May 28, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Have a Viking range, gas top, electric oven, neither work.
Check connector block where electric is brought into stove for loose or burnt wires. Check Breaker in house power box. Push the breaker firmly to off and then return to On position. Read owner's manual to see if ignitor circuit has a fuse and check said fuse.
Sep 12, 2009 | Viking 30" Dual-Fuel Range, VDSC3054B...
Whirlpool Gas Range Ignitors Not Clicking
We are sorry to hear of the problem with your Whirlpool appliance. We would recommend having a local certified technician in your area properly diagnose and repair the issue you are experiencing. Please email us at Whirlpool_Reviews@Whirlpool.com with your name, phone number, address and the model and serial number for your oven.
Apr 06, 2017 | Whirlpool SF315 Dual Fuel (Electric and...
Thermador range electric model ref 30
in pre heating the oven it does not go beyond 250 degrees. what could be the problem. I have a thermador 30 inch dual-fuel range (rdf30).
Feb 16, 2008 | Thermador RDF30 Dual Fuel (Electric and...
Switching from gas to oven
Your model stove is dual fuel. Which means that the burners on the top of your stove are run using gas, and the bake and broil (and possibly a warming draw) are run using electricity. So if you are cooking on the top of your range you are using gas, and if you cook in the oven you are using electicity
Nov 03, 2007 | GE J2B915SS Dual Fuel (Electric and Gas)...
Whirlpool RF315 Dual Fuel (Electric and Gas) Kitchen Range Logo
851 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
