Question about JVC AV-48WP30 48" Rear Projection Television
Jvc the green color is out of line
  • 1,139 Answers
I am going to assume by out of line you mean that you have a green image besides the original image, or that the green image is somewhat distorted. If possible can you supply a picture? However based on your description you may have a convergence problem which is quite common in these types of televisions (projection TVs). You will have to have the Convergence Correction Amplifier ICs changed out the part number of the ICs are STK392-110. There are lots of resources on the net that explain how to change these components out so there is actually no need to retype it here just go to google and type in STK392-110 installation. This is of course if you have a background in electronics, if not I would advise that you have a TV repairperson come to your house and troubleshoot and replace thes malfunctioning components.
I hope this helps,
Thank you,
Posted on Oct 24, 2007
I'm getting green lines all through the picture?!?
You are starting to have problems with the light engine. LCA90563- Light Engine w/Color Wheel (No Lamp) for JVC HD-56G786
clear1x1.gif There is currently one in stock at for $329.95
May 21, 2011 | JVC HD-56G786 56" Rear Projection HDTV
Need a wiring diagram for a radio on a 93 Explorer. The speaker wires in my truck are Green, Purple with white stripe, yellow, blue w/white stripe, Lt. Blue , Orange w/white strip, brown, and red w/white...
Constant 12V+ Green/Yellow
Switched 12V+ Yellow/Black
Ground Black
Illumination Blue/Red
Dimmer n/a
Amplifier Remote Blue
Antenna Right Front
Front Speakers 5" x 7" Doors
Left Front (+) Orange/Green
Left Front (-) Blue/White
Right Front (+) White/Green
Right Front (-) Green/Orange
Rear Speakers 5" x 7" Rear Doors
Left Rear (+) Pink/Green
Left Rear (-) Brown/Yellow
Right Rear (+) Orange/Red
Right Rear (-) Black/White
THanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 08, 2009 | JVC KD-G210 CD Player
I need to know the color codes are on a jvc kdg110
most jvc have the same wiring is switch power,red is power,yellow is memory and gray set front right speaker,white set front left, the purple set rear right and green set is left rear. the blue wire is the remote out to your power amp to turn the amp on.,or a power antenna.
the speaker wires sets have a dotted line and a solid color.
the dotted line is the(-) terminal on the speaker
Sep 04, 2009 | Car Audio & Video
How to wire car speaker to JVC CD Receiver.
Hello anstrayer,
On your JVC wiring harness the speaker wire colors are:
Left front (+) - White
Left front (-) - White/Black
Right front (+) - Gray
Right front (-) - Gray/Black
Left rear (+) - Green
Left rear (-) - Green/Black
Right rear (+) - Purple
Right rear (-) - Purple/Black
You can download a the manual from Crutchfield. A complete wiring diagram with color codes is on page 41.
Hope this helps.
May 31, 2009 | JVC Car Audio & Video
Green tint on Samsung Television
Hi sbatsch,
Not to worry - this problem is very common with projection TVs and is easily fixed:
The reason for the green shadows (and the resulting wrong colors) is that the three color tubes (red, green, and blue - the three colors of light that combine to form all the other colors) are not lined up exactly - this lining up is known as "convergence." You can fix convergence automatically or, if it doesn't work to your satisfaction, manually. Here's how:
1) Press MENU.
2) Go down to CONVERGENCE (using the up and down arrows)
3) Select it (usually with the left or right arrow)
4) Go down to AUTO and select it - the process should take about a minute.
If this doesn't work, then try manually:
2) CONVERGENCE (as above)
3) Select MANUAL
4) Using the number keys, SELECT, and the arrow keys, adjust the alignment of the different color crosses - the goal is to make them appear white (meaning that the red, blue, and green are exactly aligned on top of one another).
Here's a link to the JVC user manual that will explain the manual convergence adjustment in more detail.
I hope this helps - please let me know if I can be of any further assistance.
Dec 11, 2008 | JVC AV-48WP74 48" Rear Projection...
Green color convergence
make sure you hooked everything up properly and that all connections are tight
Aug 26, 2008 | JVC AV-56WP74 56" Rear Projection...
JVC HD52Z585 green lines / remote service menu
The green screen you read about is a solid color only when you select digital input. If you are getting green lines in any other input the reset will have no affect at all.
You will need to have the TV serviced, there is a possibility that the service center can use the reset jig to correct this. But it could be more serious.
Apr 29, 2008 | JVC HD-52Z575 52" Rear Projection...
Vertical color lines
Here is a picture of my TV problem, the green horizontal line is from the camera flash. thanks for the help.4d2ca33.jpg
Jan 15, 2008 | JVC AV-48WP30 48" Rear Projection...
Picture color
have JVC AV-32F702 TV. It's picture color is very red. unable to adjust colors through menu. Channel numbers are also in red now instead of normal green. any suggestion? please check red color cathode circuit 1 check red output from ic to red cathode ckt 2 check voltage on r output ckt& ic or tr. 3 check loose contact in red cathode ckt 4 check crt base for loose. 5 loose connector 6 chroma ic thanks
Sep 09, 2007 | JVC AV-32F702 32" TV
JVC AV-48WP30 48" Rear Projection Television Logo
67 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
