Question about Panasonic Toughbook CF-73 Notebook
Black screen on my laptop
Hi, 2 seconds after i push the start button, i get 1 long bit and 2 short bip. The screen stay black. The computer is running but the screen stay off. I cannot do anything, even not do to the Bios.
Laptop black screen
You turned on your laptop and horrors upon horrors, the screen is BLACK! You see that the laptop has power but besides that nothing is happening.
I want you to know that there is a very good chance you can get out of this situation quickly and without any cost. This fix works on all brands of laptops:
• 1) TAKE OUT YOUR LAPTOP BATTERY
• 2) REMOVE YOUR AC ADAPTOR CORD, that's the wall power, remove it.
• 3) NOW HOLD DOWN THE POWER BUTTON FOR 30 SECONDS
That will drain any static electricity that has built up on your laptop system board and many times fixes the problem of a black screen.
After the 30 seconds re-connect your laptop to the wall power and hit the power button normally and see if the laptop comes back up.
Replace your battery.
or if wont start
Here are the fix steps:
1. Turn off your computer
2. Disconnect every wire from it (including power)
3. Disconnect the battery from the bottom of the computer.
There will be two tabs labeled 1 and 2.
4. Re-plug in the power wire. (the battery should not be in the computer)
5. Turn on the power. The screen will work. Choose start windows normally. (if you get that screen)
6. Go to Control Panel -> (Mobile PC) -> Power Options -> Under Balanced choose change plan settings
7. Choose Change advanced power settings
8. Find Processor power management and change the minimum processor state from 5% to 100% for each On battery and Plugged in.
9. Click Apply then OK
10. Shut down you computer.
11. Disconnect the power cord.
12. Re-install the battery on the bottom of the laptop, plug in the power cord, and restart the computer.
Aug 08, 2013 | Computers & Internet
My hp compaq nc600 laptop wont turn on just an ornage light comes on, black screen and fan for 10 seconds then dies?
In the first instance you need to check your power lead. Exchange it for another one that you know works.
Apr 09, 2013 | HP Compaq nc6000 Notebook
My HP DV4000 beeps when I press the power button and the screen will stay black.
This POST error code maybe -
one long, two short beeps
  • System board failure
  • Video adapter problem
  • LCD assembly failure
Dec 04, 2012 | HP Pavilion dv4000 Notebook
Sa1, screen black I can here the cd and HD working but screen stays black. how can I fix? M series gateway. laptop
Please perform the following steps to resolve the issue:
Power drain process:
1. Shut the computer down.
2. Disconnect the AC adapter and remove the battery.
3. Press the power button down for about 30-60 seconds.
4. Reconnect the AC adapter and the battery.
5. Restart the computer.
Alternately you can test your Notebook power by removing and inserting the Memory and Hard-Disk iin their locations.
May 25, 2010 | Computers & Internet
Acer Aspire one screen stays black
i have this problem 2 days ago.. and this works on me... maybe on your's too you may need to flash your bios. why need to flash the bios.. ? 1. had the black screen of death. or deleted the bios how to flash the bios: STEP 1.download the AA1 BIOS from this link: http://www.acerpanam.com/synapse/data/7117/documents/AS1_BIOS_3309.zip 2. extract the file 3. rename the file 3309.fd to zg5ia32.fd 4. put zg5ia32.fd and FLASHIT.EXE onto the usb drive now, start the process STEP 2 A. make sure the power cable is in B. the laptop is turned OFF C. Plug the usb stick in! STEP 3: Press and HOLD down the FN and ESC key together then press the power button, while holding the buttons release the power button and continue holding FN and ESC for about 5 seconds release the buttons and the power light will start to blink let the laptop run and DO NOT PRESS anything this can take upto 8 mins when it's done the laptop will restart. this works on me... good luck.. and i hope it will help you.....
Jun 15, 2009 | Acer Aspire One PC Notebook
Screen turns black suddenly
Hi guys!
I think your problem is one of the following:
1- AC Device or Batteries.
2- RAM.
3- Graphic Card.
So, plz check them by order.
I hope this problem is solved.
Nov 04, 2008 | HP Compaq Presario V2000 Notebook
HP dv6000, laptop will not start up, screen stays blank and the lights and fan turn off about every 20secs and it just keeps doing the same thing over and over again, sounds like its starting up then OFF,...
Hi civic-95-uk ,
Try performing power drain steps on thenotebook:
1) Remove the AC adapter and battery from the notebook.
2) Press the power button and hold it for a minute.
3) Reconnect the AC adapter, battery and try starting the computer.
Even if the issue is same then perform Hard drive self test from BIOS.
1. Turn on the notebook and press F10 immediately. Which will lead you to the BIOS setup screen.
2. Click on Diagnisis and choose hard drive self test. Perform both the short test and long test.
Sep 09, 2008 | HP Computers & Internet
Panasonic Toughbook CF-73 Notebook Logo
212 people viewed this question
Top Panasonic Computers & Internet Experts
micky dee
Computer Repairing
Computer Repairing
Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
